Question about Brother MFC 7840W Printer
How to print an envelope
Do you have a picture or something that allows a person to follow the directions for printing envelopes. I opened the back of my printer for manual feed but nothing happens. I need a better explanation on how to feed an envelope into the printer. Most printers allow you to print envelopes by sliding the paper holder to the size of an envelope. This printer just says manual feed, one person posted something about a tray and opening the back, what does this mean? Are they saying the manual feed is the tray and by opening the back it will feed it into the printer for an envelope? Please someone help me understand how to make this work.
SOURCE:
Rubec
  • 42 Answers
SOURCE: Can't print from the MP tray?
When you print labels or envelopes you need to select the correct tray from the print menu. (File print or ctrl P) or the printer will think the normal paper tray is being used.
You can force the printer to change the tray after the print has been sent by pressing the continue button on the printer, just make sure that the normal tray has no paper in it.
Posted on May 11, 2008
  • 25 Answers
SOURCE: My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Posted on Aug 14, 2008
PABLOCSA
  • 1124 Answers
SOURCE: I have a HP Photosmart
You will find how here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu03053&cc=us&lc=en&dlc=en&product=3204464
Posted on Nov 18, 2008
edmacias
  • 70 Answers
SOURCE: I'm trying to print envelopes with my hp psc 1315
I would recommend you re-orientate your envelope going into the printer by placing it flap up, right flush but with the widest side in fist (or horizontally as per your description). Below is my attempt of the envelope as it should be placed in the paper tray (all in bold characters): _________ |\ /| | \ / | | `...' | |__/___\__|In your document editor it should be orientated like a normal document.Best luck,Ed(In case the drawing is not very clear, click here an the way to put the envelope IN the aper tray should be like the 1st drawing)
Posted on Nov 22, 2009
Ranglo
  • 1194 Answers
SOURCE: envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Posted on Feb 20, 2010
How to load envelopes in a canon mg3250 printer
Hi
Please find below a fairly comprehensive guide to using envelopes on your machine
The address is automatically rotated and printed according to the envelope's direction by specifying with the printer driver properly.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif You can only print on envelopes with the computer.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Do not use the following envelopes. They could jam in the machine or cause the machine to malfunction.
- Envelopes with an embossed or treated surface
- Envelopes with a double flap
- Envelopes whose gummed flaps are already moistened and adhesive Prepare envelopes.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Press down on all four corners and edges of the envelopes to flatten them.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the envelopes are curled, hold the opposite corners and gently twist them in the opposite direction.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the corner of the envelope flap is folded, flatten it.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Use a pen to press the leading edge in the inserting direction flat and sharpen the crease.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif The envelopes may jam in the machine if they are not flat or the edges are not aligned. Make sure that no curl or puff exceeds 0.1 inches (3 mm). Load envelopes.
(1) Open the front cover gently, and extend the paper support.
(2) Use the right paper guide (A) to slide both paper guides all the way out.
(3) Load the envelopes in the center of the front tray WITH THE ADDRESS SIDE FACING DOWN.
The folded flap of the envelope will be faced up on the left side.
Push the envelopes all the way to the back of the front tray.
Up to 5 envelopes can be loaded at once.
(4) Slide the right paper guide (A) to align the paper guides with both sides of the envelopes.
Do not slide the paper guides too hard against the envelopes. The envelopes may not be fed properly.
Do not overload envelopes by stacking until the top of the stack touches the paper guides. (5) Open the output tray extension.
Open the paper output tray.and extend the paper output support.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Be sure to open the paper output tray when printing. If not open, the machine cannot start printing. After loading envelopes
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image003.gif Select the size and type of the loaded envelopes on the print settings screen of the printer driver. You may find it easier to download the manual from here
Canon PIXMA MG3250
and install it on your desktop for future reference
Cheers
Nov 13, 2014 | Canon PIXMA MG3250 All-in-One Inkjet...
Why brother mfc 7360n printing envelopes wrinkle paper
Do U mean wrinkle the envelopes?,,,,I can solve some MFC-9840-CDW issues, but the 7369N is a guess. Read your manual or do a google search.....There maybe a setting in the 7360N that adjusts printing for card stock and envelopes....
Jul 01, 2014 | Brother MFC-9840CDW Laser Printer
Canon printer MX310 works fine, but I have never used before to print envelopes. Once i set it for a particular envelope, where do I insert the blank envelope. Have tried every conceivable...
canon.gifPrinting an Envelope
For details about how to load an envelope into the printer, see the user's manual.
The procedure for performing envelope printing is as follows:
1. Fold down the envelope flap.
2. When loading the envelope in the rear tray, orient the envelope so that the flap is on the left and the folded surface is facing down.
3. Open the printer driver setup window, and select Envelope from the Media Type list on the Main tab.
4. Click the Page Setup tab, and select Youkei 4, Youkei 6, Comm. Env. #10, or DL Env. for Page Size.
5. Select Landscape for Orientation.
6. Click OK.
When you execute print, the information is printed on the envelope.
Jul 21, 2011 | Canon PIXMA MX310 All-In-One Printer
Envelopes are properly loaded into the special Envelope tray, but print upside down. We have changed every setting we can find, but either jams or prints upside down. I found a link that indicates a...
Try this!
I am hoping that you are trying to print envelopes from a microsoft word document right?
Open the document and go to the tools area and open envelopes and click the button option to save the envelope as a copy in the document.
This should show a picture of an envelope above your document and/or letter written. Highlight the text on the envelope and edit your font. Change the direction of the font to upside down.
Then print the envelope only by clicking on the picture of the envelope on the screen and then choose "file" and "Print" and then change the setting to "current page only" and choose "ok" to begin printing.
Load the envelopes the same way that you are now (with the printing upside down in the printer).
Print one copy and see if this solves your problem.
If not, repost your problem and I will help you solve this.
Sep 27, 2010 | Office Equipment & Supplies
Need to pring envelopes on my konica Minolta hub 350 printer
Place envelopes in either drawer 1 (top drawer) or the by-pass tray. Generally, the envelope is placed side to be printed down. (On the printer you can set up custom envelope sizes.)
Select Print. Click 'Properties' for the printer. In the resultant dialogue window, set the printer to print to the 'envelope' print path.
Click OK, click Print. (test print direction first)
Check your printed envelope. You may need to change the orientation of the envelopes to print with the opening at the top.
Jul 30, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How do I print an envelope from the Canon MP150
  1. Do the following
    Open the paper support and extend the paper support extension.Open the paper output tray. Set the paper thickness lever to the right side for envelopes.Load envelopes in the auto sheet feeder with the print side facing up. Check the printing direction.Set the envelope in the direction of the arrow.Set the envelopes to the right side of the auto sheet feeder.Pinch and slide the paper guide to the envelope's left side .
May 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Won't print envelopes in black
First you need to change the settings in the software you are trying to print the envelope. Open the program (for example MS Word), go to the option from which you print envelopes and labels. Set the font color to black, not "automatic", and in Word, click "default", which sets the color as black rather than allowing the printer or its software to select the wrong color. Then try to print on the envelope and let us know if you are able to print the envelope in black only.
Apr 13, 2009 | Lexmark X4270 All-In-One InkJet Printer
Why cant i print envelopes
Well that depends, additional info would be great.
Here's an example:
PRINTING ENVELOPES from Microsoft Word
The envelope should be fed into the printer using the short side, all the way to the right, flap to the back and to the left.
Please follow the steps below to print envelopes in Microsoft Word:
1. Open Microsoft Word.
2. Click on TOOLS, then ENVELOPES AND LABELS.
3. Ensure the ENVELOPES tab is selected. Click on the OPTIONS button.
4. Select your envelope size under ENVELOPE OPTIONS (ie: #10).
5. Select PRINT OPTIONS.
6. Under FEED METHOD, from the six options available select the FOURTH icon from the left. Select FACE UP.
7. Ensure CLOCKWISE ROTATION is selected.
8. Under ENVELOPE OPTIONS, ensure you choose the correct envelope size (ie: #10).
9. Click OK, then PRINT.
The envelopes should print correctly now.
Sep 11, 2008 | Kodak Office Equipment & Supplies
Envelope printing
You need to insert the envelope in the manual feed area and open the exit door at the back this allows the envelope to go straight through the printer hopefully limiting creasing. Check the envelope settings in windows make sure that you are using the correct size and feed selection.
Thanks J
Feb 03, 2008 | Brother HL-2040 Laser Printer
Dell A920 won't print envelopes
I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
Dec 02, 2006 | Dell A920 InkJet Printer
Brother MFC 7840W Printer Logo
James Cagle
James Cagle
Jim Keysor
ctnozil
