Question about GoVideo Go Video DVD/VCR Combo
Spindle motor Need source for go video spindle motor. Number on motor CL968U 3703A
  • GoVideo Master
  • 5,568 Answers
Probably not much help , but . . .
- These fail rarely; most go to the great recycling place in the sky before that motor fails.
- Obviously, you have better access than I, but I have seen many more failures of the electronics that control the motor than bad motors.
- That motor was probably made by an outside company but ferreting that out could be tough as  GoVideo does not seem to have a website any more.
One final note; the last part of the number you listed, '3703A' could very well be the date code and may mean '37th week of 2003.'  That number structure is quite common on Asian components.
Posted on Oct 02, 2008
Spindle motor replacement
The output transistor or IC is dead. Fix it before, it is very strange the motor broked. You must measure volts in that transistor. If no volts, then look for stabilicer alimentation. Thanks.
Aug 26, 2014 | Toshiba SD-330E DVD Player
Tip
DVD PLAYER REPAIR (NO DISC ERROR)
Before you attempt to repair your DVD Player yourself, make sure that you have necessary tools and test instruments like philips screw drivers, multimeter, soldering iron, soldering lead, soldering pump, etc...
This is a DVD/MIDI Player with a "no disc error" upon loading any disc that played before...
Watch this VIDEO
First I've loaded it with disc and observe the movement of the optical lens and the spindle motor. First thing I've noticed that the spindle motor didn't oscillate upon spinning and it's spin slowly unlike the normal RPM...
I've suspected the spindle motor was already bad but still to be confirm...
Unscrew the disc holder plate from the assembly to keep away the magnet touching the spindle motor, this may affect the reading and spinning of the motor upon testing with the multimeter.
This is how it looks like after removing the disc plate holder in the assembly. Spindle motor is secured with 2 small screws in the lens assembly.
Pull-out the connectors from the main board to see the underside of the tray.
You may test the spindle motor with your multimeter set in resistance measurement (ohms X1) even connected to the small board.
Bad motor will read either less than 5ohms(shorted winding) or infinity (open winding) and will not spin.
Good motor will read more than 50 ohms(depends the size) and will spin upon testing. Watch this VIDEO.
Onced you've confirmed that the motor was already faulty, unscrew it from the lens assembly.
Replaced the spindle motor with new one. Before you install the new motor make sure that the clearance of the disc holder is the same as the old one. Compare first the clearance because if it is to high the optical lens will not read the disc same if it is to low....
After replacing the motor re-insert all the connectors to the main board.
I've load same disc which does not read a while ago and observe what will happen. Observe the disc and the sound oscillation from the spindle motor in this VIDEO.
Hope that the above information, pictures, and video will help you fixing your DVD player yourself.
Thanks for visiting Fixya.
Have a nice day!
Jdvillanueva
on Apr 18, 2011 | Bose 3 2 1 GSX System
The light on the dvd player won't turn green any more.I can't get it to play any more. If I did get it to play it would say bad disc the light is now yellow not red are green any more.
hi,
You dvd have problem with its spindle motor. Spindle motor is one on which the CD rotates. If the winding of the spindle motor become short this problem can occur. you can see the spindle motor in the center of the mechanism. spindle motor will not cost a lot. Just replace the spindle motor your problem will solved.
ok
May 06, 2011 | Cyberhome CH-DVD 300 DVD Player
MILWAUKEE 4253-1. HOW TO REMOVE THE SPINDLE #47 ON THE PARTS LIST. AFTER THE CHUCK AND GEAR CASE IS REMOVED FROM THE MOTOR.
The spindle is pressed into the bearing in the nose of the gear case. You usually need a hydraulic press to get them out. If the spindle gear, woodruff key and spacer come out easily (it may need a little prying pressure) you may be able to tap the spindle out with a dead blow/rubber hammer or with a piece of wood on the end of the spindle. If you hit the spindle directly with a metal hammer you can mushroom the end and it won't fit in the needle bearing in the service diaphram.
Mar 22, 2011 | Milwaukee Tool 4253 1 Drill 1/2 Mag Motor...
My gamepad dose not vibration
It may be that the weights on the spindle motors have fallen off, or the spindle motors have become faulty. If your controller rattles when shaken, the chances are that the weights on the spindle motor have fallen off. I hope this helps. Good luck.
Sep 17, 2010 | Video Game Consoles & Games
I need help on how to replace bit on router craftsman style
You didn't state the model number. The older Craftsmen routers had a red lever lock on the top of the router, one position allows the spindle to turn, the other position locks the spindle. Here's the instruction for the older style routers:
  1. Unplug the tool.
  2. To lock the spindle press the red button in and slide it to the locked position.
  3. Unlock the height adjustment knob.
  4. Raise the router motor using the height adjustment collar until you can get a wrench onto the collet nut.
  5. Loosen the nut until it turns freely.
  6. The bit may still be locked in the spindle, tap it gently (not on the blade!).
  7. The bit will come loose in the spindle and can be removed.
  8. Replace the bit, tighten the nut snug but don't use excessive force.
  9. Unlock the spindle, returning the red lever/button to the free position.
  10. Adjust the height of the bit as you wish, then lock down the motor using the locking knob.
Mar 19, 2009 | Craftsman Tools & Hardware - Others
Ps2 slim spindle dont spin
If your spindle has stopped spinning, it will most likely be 1 of 2 problems. Either your spindle motor has burnt up, or even though it is very unlike, a lead wire that supplies the power to the spindle has became disconnected. Now, if the case it the burnt up spindle motor, there are hundreds of motors for every kind of PS on, of course, E-Bay. If the problem is for some reason, a soldered wire has broken from the motor. It is very simple to re-attach the lead with a quick touch from a soldering iron. I hope this has helped.
Jan 02, 2009 | Sony PlayStation 2 Slimline Console
PS2 Slim
SURE !!! www.richspsxparts.com
Dec 04, 2007 | Sony PlayStation 2 Slimline Console
Maybe a second belt or pully.
If that spindle you are talking about is the motor shaft, then the motor is bad. Usually the belt goes from the brush roll to the motor shaft. It may help if we knew brand and model number.
Dec 04, 2007 | Vacuums
GoVideo Go Video DVD/VCR Combo Logo
195 people viewed this question
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
