Question about Minolta Office Equipment & Supplies
Minolta cf2001 photocopier, showing error co200.
  • Minolta Master
  • 1,879 Answers
Is there any specific message that goes with the error code ?
Posted on Oct 02, 2008
  • monk3ybidzness
    monk3ybidzness Oct 02, 2008
    WARNING ! codes are model specific - C0200 for your model means different for other models.
    Genius:
  • 3,422 Answers
Problem: CO200
Solution: Add additional drum ground* *Minolta has come out with a factory ground plate. The part # is: 1075-5521-01 Slide open the drum assembly, remove the dv unit, then the drum. The ground plate installs on the REAR drum lock, the arm that holds the drum secure. When you reinstall the drum and close the locking arm, the plate will contact the drum bearing and drum/image unit carriage.
Please don't forget to accept the solution.
    Guru:
  • 1,894 Answers
Try a hard reset.
by plugging off the unit from power for one night and then using it again.
Admin password for minolta cf2001 lost. can you help me? best regards
All Minolta's come from the factory with a default password on the copier of either 12345678 or 00000000
Now if your needing the netwrok password it is usually sysadm or sysadmin
This is all assuming that someone has not changed these to something else since you have had the machine.
Jan 08, 2010 | Minolta CF2001 Copier
Minolta CF2001 has error coode C0060 after clearing a paper jam in the fuser unit.
well the fuser motor is jammed. remove the fuser and replace it. hopefully the motor is not burned out, and or worse the motor took the control board also
Nov 11, 2009 | Minolta CF2001 Copier
Service code c37 appeared on my toshiba photocopier
C37 indicates Abnormal transfer belt cam motor.
U need to perform below checking:
(1) Check if the connector of the transfer belt cam motor is not disconnected.
(2) Check if the transfer belt contact/release switch is working properly.
(3) Replace the transfer belt cam motor.
(4) Replace the LGC board.
Feb 28, 2009 | Minolta CF2001 Copier
Minolta CF2001 C410 error code
To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
Note: after opening the front door, it is in the lower right corner.
2. Insert a suitable object into the hole to actuate the reset switch.
HOPE THAT HELP
LET ME KNOW
Oct 14, 2008 | Minolta CF2001 Copier
Minolta 1080
how the code appeared?
I suppose you worked with the cyan low toner attention untill the machine stopped. in this case you should make an ATDC sensor adjustement! but firstly you should reset the error!
Jul 14, 2008 | Minolta CF2001 Copier
Minolta CF2001 error code C3720
original glass cooling fan motor turning at abnormal timing
Jan 25, 2008 | Minolta CF2001 Copier
MINOLTA CF2001
You need to change the EEPROM for the Black toner.
Look at the link
http://www.hcservicetech.com/konicodes/c350.html
Oct 31, 2007 | Minolta CF2001 Copier
149 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
