Question about Panasonic KV-S2026C Pass-Through Scanner
KV-S2026C not scanning
I have a problem with my scanner. When I turn it on the power light flashes green for a few second then turns red. When I try to scan white it is blinking green it doesn't do anything then the red light comes back. I ahve cleaned the entire unit. I see that this unit has a sensor roller kit. Do you think if I get and install it this problem will be solved. thanks for your help.
billm@mcsj.com
  • billm506 Oct 02, 2008
    Around 2yrs old. Error - ID 3040 no paper
    Yes , I saw that little square sensor window at the paper feed. I cleaned it out but unfortunately it still has the same problem. Where can I get that sensor and I really don't see how to get it out though. Any suggestions ? Is their a parts diagram or schematic on line for this unit ?
    Scholar:
  • 148 Answers
LET ME ASK A FEW MORE DETAILS ABOUT THIS:
1. DID YOU GOT ANY ERROR MESSAGE ON YOUR DESKTOP OR LAPTOP?
2. WHAT OS OPERATING SYSTEM IS CURRENTLY INSTALLED AND YOUR ARE USING RIGHT NOW..?
3. HAVE YOU INSTALLED THE SCANNER DRIVER ON YOUR PC?
4. DO YOU CHECK IF ALL THE CABLE CONNECTION FROM THE SCANNER TO THE PC ARE PROPERLY HOOKED UP AND ALSO CHECK THE POWER SOURCE.?
KINDLY POST ME BACK HERE ABOUT THIS, AND SOME ADD INFO YOU INPUT WILL DO..
KEEP US UPDATED.
Posted on Oct 02, 2008
  • 1 more comment
  • Zander Rovic Ocampo
    Zander Rovic Ocampo Oct 02, 2008
    I JUST WONDER CAN YOU ALSO CHECK IF YOU STILL GOT AN INK INTO THAT UNIT. IT SUPPOSED THAT YOU ARE DOING A SCANNER / COPIER ON THERE..
    LOADS UP MORE PAPER AS THE UNIT CAN HOLD.. THIS ERROR COULD BE ON THE LOADING SENSOR..
    HERE AGAIN,..
    ALL IN ONE PRINTER IS CHEAPER NOW..
    IT IS BETTER TO REPLACE THE PRINTER THAN BUYING A REPLACEMENT INTO THE SENSOR AND AN SCHEMATICS FOR THAT..
    ONLY SUGGESTION, NOT A RECOMMENDATION. ITS ALWAYS UP TO YOU.
    Guru:
  • 1,894 Answers
Does this unit show any error?
how old is this unit> is it under warranty?
  • 1 more comment
  • dewan nafees ahmed Oct 02, 2008
    but paper is there inside right?
    this means that you need to have a check at the sesor at the place where paper is taken feed.
    mostly that sensor is filled with dust or else faulty.
    try cleaning it. else you will have to change it
    our part diagram wont giev you clear idea sir. its best to get a service manual. in that you will find the part number of your defective part.
    now call your company and order for that particular part number.
    work over
    service manual can be got from company. it will be cheap. but owning a service manual will help you a lot in future. so buy one online. it will be useful.
There is a red light error on the scanner and it beleives there is paper in the scanner. I have unplugged and replugged everything. I have reset the scanner and I have also turned the paper feeder to...
I found someone had placed a piece of tape on the cork where the scanner feeds in which was causing the sensor to believe parper was there. When I removed the tape the red light went off.
Feb 24, 2011 | Panasonic KV-S2026C Pass-Through Scanner
My panasonic kv-s2026c has a black line running down the left side when I scan my documents. I have cleaned the rollers, used air canister to see if anything is stuck in there. That didn't help
On the CD that came with the scanner is a directory called "Shading Utility". Copy this folder to your PC. Put a blank piece of copy paper into your scanner. Open up the Shading Utility folder and then double-click on the shadingutility.exe. The password is "GOSHADING" without the quotes. This process will take a few minutes but it will re-align the lens in the scanner which has gotten out of alignment through vibration. This is what is causing the vertical black line on the left side of the page.
Jan 13, 2011 | Panasonic KV S2026C Path-Through Scanner
Red Light on and software says its got paper in the feeder which it doesnt.
Dust on the paper sensors is a common problem with ADF scanners such as this. Look at the paper sensor video on our web site for hints
MyEfact
Dec 17, 2010 | Panasonic KV S2026C Path-Through Scanner
Scanner stopped in middle of scan . green light in front went out. later red light came on. message on screen said that the carriage was locked. I tried turning scanner on and off and green light comes on...
test the power supply to the scanner also test the leads that attach from the power supply to the scanner if its connected to a computer you might have to uninstall it then reinstall it this applies the driver aswell you can do this control panel admistrive tools,computer management,device manager scroll down you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)ECP printer port right click update driver
hope this helps
Oct 27, 2010 | Computers & Internet
Red light continues to flash
Just You can see a Reset Option in your Device just use that Device Then your Problem will be Solved
Please Rate My answer
Aug 12, 2010 | Panasonic KV S2026C Path-Through Scanner
Line in scanned document
Its dirt! It takes just one tiny speck of dirt on the lens to make a vertical line.
We have some scanner maintenance videos;you want to clean the CIS front sensor.
Regards,
MyEfact
May 12, 2010 | Panasonic KV-S2026C Pass-Through Scanner
Scan only in jpg.
If you want to scan in TIFF, you need to scan in monochrome only. (B&W). Change SCanner settings.
S. Mohan, Chennai, India
Feb 05, 2009 | Panasonic KV-S2026C Pass-Through Scanner
Red light comes when powered
Please try the following to resolve your issue:
1. Unplug the USB cable and the AC adapter from the back of the scanner.
2. Toggle the Transportation lock (located on the bottom of the scanner) back and forth 5 times, ensuring that the lock is all the way in the unlock position.
3. Reconnect the USB cable and the AC adapter cable, and then try to scan.
Jan 04, 2008 | Epson 2580 Perfection Photo Scanner
Recognition Issue
what operating system are you using?
Dec 12, 2007 | Panasonic KV-S2026C Pass-Through Scanner
Panasonic KV-S2026C Pass-Through Scanner Logo
471 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
