IPod is locked and won't move with menu or arrow keys. I have unlocked the switch at the bottom, but still won't move.
  • 68 Answers
Let the battery discharge fully then restore with latest firmware
Posted on Oct 02, 2008
How to unlock a jcv s1465 screen
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
Feb 26, 2013 | Insignia Televison & Video
Tip
Amazing shortcuts
Getting used to using your keyboard exclusively and leaving your mouse behind will make you much more efficient at performing any task on any Windows system. I use the following keyboard shortcuts every day:<br /><br />Windows key + R = Run menu<br /><br />This is usually followed by:<br />cmd = Command Prompt<br />iexplore + "web address" = Internet Explorer<br />compmgmt.msc = Computer Management<br />dhcpmgmt.msc = DHCP Management<br />dnsmgmt.msc = DNS Management<br />services.msc = Services<br />eventvwr = Event Viewer<br />dsa.msc = Active Directory Users and Computers<br />dssite.msc = Active Directory Sites and Services<br />Windows key + E = Explorer<br /><br />ALT + Tab = Switch between windows<br /><br />ALT, Space, X = Maximize window<br /><br />CTRL + Shift + Esc = Task Manager<br /><br />Windows key + Break = System properties<br /><br />Windows key + F = Search<br /><br />Windows key + D = Hide/Display all windows<br /><br />CTRL + C = copy<br /><br />CTRL + X = cut<br /><br />CTRL + V = paste<br /><br />Also don't forget about the "Right-click" key next to the right Windows key on your keyboard. Using the arrows and that key can get just about anything done once you've opened up any program.<br /><br /><br />Keyboard Shortcuts<br /><br />[Alt] and [Esc] Switch between running applications<br /><br />[Alt] and letter Select menu item by underlined letter<br /><br />[Ctrl] and [Esc] Open Program Menu<br /><br />[Ctrl] and [F4] Close active document or group windows (does not work with some applications)<br /><br />[Alt] and [F4] Quit active application or close current window<br /><br />[Alt] and [-] Open Control menu for active document<br /><br />Ctrl] Lft., Rt. arrow Move cursor forward or back one word<br /><br />Ctrl] Up, Down arrow Move cursor forward or back one paragraph<br /><br />[F1] Open Help for active application<br /><br />Windows+M Minimize all open windows<br /><br />Shift+Windows+M Undo minimize all open windows<br /><br />Windows+F1 Open Windows Help<br /><br />Windows+Tab Cycle through the Taskbar buttons<br /><br />Windows+Break Open the System Properties dialog box<br /><br /><br /><br />acessability shortcuts<br /><br />Right SHIFT for eight seconds........ Switch FilterKeys on and off.<br /><br />Left ALT +left SHIFT +PRINT SCREEN....... Switch High Contrast on and off.<br /><br />Left ALT +left SHIFT +NUM LOCK....... Switch MouseKeys on and off.<br /><br />SHIFT....... five times Switch StickyKeys on and off.<br /><br />NUM LOCK...... for five seconds Switch ToggleKeys on and off.<br /><br />explorer shortcuts<br /><br />END....... Display the bottom of the active window.<br /><br />HOME....... Display the top of the active window.<br /><br />NUM LOCK+ASTERISK....... on numeric keypad (*) Display all subfolders under the selected folder.<br /><br />NUM LOCK+PLUS SIGN....... on numeric keypad (+) Display the contents of the selected folder.<br /><br />NUM LOCK+MINUS SIGN....... on numeric keypad (-) Collapse the selected folder.<br /><br />LEFT ARROW...... Collapse current selection if it's expanded, or select parent folder.<br /><br />RIGHT ARROW....... Display current selection if it's collapsed, or select first subfolder.<br /><br /><br /><br /><br />Type the following commands in your Run Box (Windows Key + R) or Start Run<br /><br />devmgmt.msc = Device Manager<br />msinfo32 = System Information<br />cleanmgr = Disk Cleanup<br />ntbackup = Backup or Restore Wizard (Windows Backup Utility)<br />mmc = Microsoft Management Console<br />excel = Microsoft Excel (If Installed)<br />msaccess = Microsoft Access (If Installed)<br />powerpnt = Microsoft PowerPoint (If Installed)<br />winword = Microsoft Word (If Installed)<br />frontpg = Microsoft FrontPage (If Installed)<br />notepad = Notepad<br />wordpad = WordPad<br />calc = Calculator<br />msmsgs = Windows Messenger<br />mspaint = Microsoft Paint<br />wmplayer = Windows Media Player<br />rstrui = System Restore<br />netscp6 = Netscape 6.x<br />netscp = Netscape 7.x<br />netscape = Netscape 4.x<br />waol = America Online<br />control = Opens the Control Panel<br />control printers = Opens the Printers Dialog<br /><br /><br />internetbrowser<br /><br />type in u're adress "google", then press [Right CTRL] and [Enter]<br />add www. and .com to word and go to it<br /><br /><br />For Windows XP:<br /><br />Copy. CTRL+C<br />Cut. CTRL+X<br />Paste. CTRL+V<br />Undo. CTRL+Z<br />Delete. DELETE<br />Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE<br />Copy selected item. CTRL while dragging an item<br />Create shortcut to selected item. CTRL+SHIFT while dragging an item<br />Rename selected item. F2<br />Move the insertion point to the beginning of the next word. CTRL+RIGHT ARROW<br />Move the insertion point to the beginning of the previous word. CTRL+LEFT ARROW<br />Move the insertion point to the beginning of the next paragraph. CTRL+DOWN ARROW<br />Move the insertion point to the beginning of the previous paragraph. CTRL+UP ARROW<br />Highlight a block of text. CTRL+SHIFT with any of the arrow keys<br />Select more than one item in a window or on the desktop, or select text within a document. SHIFT with any of the arrow keys<br />Select all. CTRL+A<br />Search for a file or folder. F3<br />View properties for the selected item. ALT+ENTER<br />Close the active item, or quit the active program. ALT+F4<br />Opens the shortcut menu for the active window. ALT+SPACEBAR<br />Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4<br />Switch between open items. ALT+TAB<br />Cycle through items in the order they were opened. ALT+ESC<br />Cycle through screen elements in a window or on the desktop. F6<br />Display the Address bar list in My Computer or Windows Explorer. F4<br />Display the shortcut menu for the selected item. SHIFT+F10<br />Display the System menu for the active window. ALT+SPACEBAR<br />Display the Start menu. CTRL+ESC<br />Display the corresponding menu. ALT+Underlined letter in a menu name<br />Carry out the corresponding command. Underlined letter in a command name on an open menu<br />Activate the menu bar in the active program. F10<br />Open the next menu to the right, or open a submenu. RIGHT ARROW<br />Open the next menu to the left, or close a submenu. LEFT ARROW<br />Refresh the active window. F5<br />View the folder one level up in My Computer or Windows Explorer. BACKSPACE<br />Cancel the current task. ESC<br />SHIFT when you insert a CD into the CD-ROM drive Prevent the CD from automatically playing.<br /><br />Use these keyboard shortcuts for dialog boxes:<br /><br />To Press<br />Move forward through tabs. CTRL+TAB<br />Move backward through tabs. CTRL+SHIFT+TAB<br />Move forward through options. TAB<br />Move backward through options. SHIFT+TAB<br />Carry out the corresponding command or select the corresponding option. ALT+Underlined letter<br />Carry out the command for the active option or button. ENTER<br />Select or clear the check box if the active option is a check box. SPACEBAR<br />Select a button if the active option is a group of option buttons. Arrow keys<br />Display Help. F1<br />Display the items in the active list. F4<br />Open a folder one level up if a folder is selected in the Save As or Open dialog box. BACKSPACE<br /><br />If you have a Microsoft Natural Keyboard, or any other compatible keyboard that includes the Windows logo key and the Application key , you can use these keyboard shortcuts:<br /><br /><br />Display or hide the Start menu. WIN Key<br />Display the System Properties dialog box. WIN Key+BREAK<br />Show the desktop. WIN Key+D<br />Minimize all windows. WIN Key+M<br />Restores minimized windows. WIN Key+Shift+M<br />Open My Computer. WIN Key+E<br />Search for a file or folder. WIN Key+F<br />Search for computers. CTRL+WIN Key+F<br />Display Windows Help. WIN Key+F1<br />Lock your computer if you are connected to a network domain, or switch users if you are not connected to a network domain. WIN Key+ L<br />Open the Run dialog box. WIN Key+R<br />Open Utility Manager. WIN Key+U<br /><br />accessibility keyboard shortcuts:<br /><br />Switch FilterKeys on and off. Right SHIFT for eight seconds<br />Switch High Contrast on and off. Left ALT+left SHIFT+PRINT SCREEN<br />Switch MouseKeys on and off. Left ALT +left SHIFT +NUM LOCK<br />Switch StickyKeys on and off. SHIFT five times<br />Switch ToggleKeys on and off. NUM LOCK for five seconds<br />Open Utility Manager. WIN Key+U<br /><br />shortcuts you can use with Windows Explorer:<br /><br /><br />Display the bottom of the active window. END<br />Display the top of the active window. HOME<br />Display all subfolders under the selected folder. NUM LOCK+ASTERISK on numeric keypad (*)<br />Display the contents of the selected folder. NUM LOCK+PLUS SIGN on numeric keypad (+)<br />Collapse the selected folder. NUM LOCK+MINUS SIGN on numeric keypad (-)<br />Collapse current selection if it's expanded, or select parent folder. LEFT ARROW<br />Display current selection if it's collapsed, or select first subfolder. RIGHT ARROW<br /><br />
on Jan 10, 2011 | Computers & Internet
Tip
Windows keyboard shortcuts
CTRL + C = copy
CTRL + X = cut
CTRL + V = paste
Keyboard Shortcuts
explorer shortcuts
notepad = Notepad
wordpad = WordPad
calc = Calculator
internetbrowser
For Windows XP:
Copy. CTRL+C
Cut. CTRL+X
Paste. CTRL+V
Undo. CTRL+Z
Delete. DELETE
Select all. CTRL+A
To Press
Display Help. F1
on Dec 24, 2009 | Computers & Internet
Ipod is disabled
Attach a USB connector to the iPod and plug it into a USB connection on a computer for power, or into a stand alone USB charger plugged into a power strip for electrical power.
Pick up the iPod. Move the "Hold" switch at the top of the iPod to the "Locked" position so that an orange color appears by the switch. Return the switch to the "Unlocked" position.
Repeat this process.
Press and hold the "Home" button and the button at the top right corner together if using a fifth generation iPod, iPod Nano, iPod Mini or iPod with a click wheel.
Press and hold the "Menu" button and the "Play/Pause" button together if using an iPod Touch. Press and hold the "Menu" button and the "OK" button together if using an older iPod.
Continue holding the buttons together until the screen flashes and then displays the iPod name and the Apple logo.
Release the buttons.
Wait as the iPod resets itself and turns itself back on.
or
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC.
Open the iTunes application by using the dock icon on a Mac or the start menu on a PC.
Click on the name of your iPod under the "Devices" list in the main iTunes window.
Click on the "Sync" button to create a connection between the computer and the iPod.
Click on the eject symbol after the syncing process is complete, and then unplug your iPod from the computer.
The lock code has been reset; when you go to disable the iPod again, you will be prompted to choose a new four-digit code.
hope this helps
Sep 15, 2012 | Computers & Internet
My lock code my phone k800 is lock
You may try by following instructions....
Warning: Do not enter any wrong unlock unlock codes on your Sony Ericsson K800 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Sony Ericsson K800 mobile phone without any SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear,
(or you will have displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
If your Sony Ericsson K800 mobile phone does not have a left arrow button/key(e.g. Sony Ericsson W950i) and on a few phones(not all) that have a "JOGDIAL" you must press the "down arrow" key/button instead of the "left arrow" key/button for step 2 & 4. We mean by "Down Arrow" to direct the Jogdial down! In the Sony Ericsson W950i and some other models, the down arrow button/key would be located on the side of the phone.
Apr 18, 2010 | Sony Ericsson K800i Cellular Phone
Tip
Windows XP Shortcuts
Copy. CTRL+CCut. CTRL+XPaste. CTRL+VUndo. CTRL+ZDelete. DELETEDelete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETECopy selected item. CTRL while dragging an itemCreate shortcut to selected item. CTRL+SHIFT while dragging an itemRename selected item. F2Move the insertion point to the beginning of the next word. CTRL+RIGHT ARROWMove the insertion point to the beginning of the previous word. CTRL+LEFT ARROWMove the insertion point to the beginning of the next paragraph. CTRL+DOWN ARROWMove the insertion point to the beginning of the previous paragraph. CTRL+UP ARROWHighlight a block of text. CTRL+SHIFT with any of the arrow keysSelect more than one item in a window or on the desktop, or select text within a document. SHIFT with any of the arrow keysSelect all. CTRL+ASearch for a file or folder. F3View properties for the selected item. ALT+ENTERClose the active item, or quit the active program. ALT+F4Opens the shortcut menu for the active window. ALT+SPACEBARClose the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4Switch between open items. ALT+TABCycle through items in the order they were opened. ALT+ESCCycle through screen elements in a window or on the desktop. F6Display the Address bar list in My Computer or Windows Explorer. F4Display the shortcut menu for the selected item. SHIFT+F10Display the System menu for the active window. ALT+SPACEBARDisplay the Start menu. CTRL+ESCDisplay the corresponding menu. ALT+Underlined letter in a menu nameCarry out the corresponding command. Underlined letter in a command name on an open menuActivate the menu bar in the active program. F10Open the next menu to the right, or open a submenu. RIGHT ARROWOpen the next menu to the left, or close a submenu. LEFT ARROWRefresh the active window. F5View the folder one level up in My Computer or Windows Explorer. BACKSPACECancel the current task. ESCSHIFT when you insert a CD into the CD-ROM drive Prevent the CD from automatically playing. Use these keyboard shortcuts for dialog boxes: To PressMove forward through tabs. CTRL+TABMove backward through tabs. CTRL+SHIFT+TABMove forward through options. TABMove backward through options. SHIFT+TABCarry out the corresponding command or select the corresponding option. ALT+Underlined letterCarry out the command for the active option or button. ENTERSelect or clear the check box if the active option is a check box. SPACEBARSelect a button if the active option is a group of option buttons. Arrow keysDisplay Help. F1Display the items in the active list. F4Open a folder one level up if a folder is selected in the Save As or Open dialog box. BACKSPACE If you have a Microsoft Natural Keyboard, or any other compatible keyboard that includes the Windows logo key and the Application key , you can use these keyboard shortcuts: Display or hide the Start menu. WIN KeyDisplay the System Properties dialog box. WIN Key+BREAKShow the desktop. WIN Key+DMinimize all windows. WIN Key+MRestores minimized windows. WIN Key+Shift+MOpen My Computer. WIN Key+ESearch for a file or folder. WIN Key+FSearch for computers. CTRL+WIN Key+FDisplay Windows Help. WIN Key+F1Lock your computer if you are connected to a network domain, or switch users if you are not connected to a network domain. WIN Key+ LOpen the Run dialog box. WIN Key+ROpen Utility Manager. WIN Key+U accessibility keyboard shortcuts: Switch FilterKeys on and off. Right SHIFT for eight secondsSwitch High Contrast on and off. Left ALT+left SHIFT+PRINT SCREENSwitch MouseKeys on and off. Left ALT +left SHIFT +NUM LOCKSwitch StickyKeys on and off. SHIFT five timesSwitch ToggleKeys on and off. NUM LOCK for five secondsOpen Utility Manager. WIN Key+U shortcuts you can use with Windows Explorer: Display the bottom of the active window. ENDDisplay the top of the active window. HOMEDisplay all subfolders under the selected folder. NUM LOCK+ASTERISK on numeric keypad (*)Display the contents of the selected folder. NUM LOCK+PLUS SIGN on numeric keypad (+)Collapse the selected folder. NUM LOCK+MINUS SIGN on numeric keypad (-)Collapse current selection if it's expanded, or select parent folder. LEFT ARROWDisplay current selection if it's collapsed, or select first subfolder. RIGHT ARROW
on Sep 11, 2007 | Microsoft Windows XP Professional With...
Locked
you may try the following tips.....
Warning: Do not enter any wrong unlock unlock codes on your Sony Ericsson Z300A mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Sony Ericsson Z300A mobile phone without any SIM Card,
If your Sony Ericsson Z300A mobile phone does not have a left arrow button/key(e.g. Sony Ericsson W950i) and on a few phones(not all) that have a "JOGDIAL" you must press the "down arrow" key/button instead of the "left arrow" key/button for step 2 & 4. We mean by "Down Arrow" to direct the Jogdial down! In the Sony Ericsson W950i and some other models, the down arrow button/key would be located on the side of the phone.
Feb 06, 2010 | Sony Ericsson Z300a Cellular Phone
It will come on to the main page but the click wheel won`t move
Look on top of the ipod to see if the switch color is orange, which means the ipod is locked.  Switch the thing the other way to unlock.  Also, make sure you got the latest software updates for the ipod to fix click wheel sensitivity issues.  You can also do a reset- push the center button and menu button at the same time until the apple logo appears.  Then you can release your death grip on the thing.  Take the thing back to the store if your within your warranty and have them deal with it if you still got problems.  Cheers.
Nov 24, 2009 | Apple iPod MP3 Player
Guide
General keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+C (Copy)
  • CTRL+X (Cut)
  • CTRL+V (Paste)
  • CTRL+Z (Undo)
  • DELETE (Delete)
  • SHIFT+DELETE (Delete the selected item permanently without placing the item in the Recycle Bin)
  • CTRL while dragging an item (Copy the selected item)
  • CTRL+SHIFT while dragging an item (Create a shortcut to the selected item)
  • F2 key (Rename the selected item)
  • CTRL+RIGHT ARROW (Move the insertion point to the beginning of the next word)
  • CTRL+LEFT ARROW (Move the insertion point to the beginning of the previous word)
  • CTRL+DOWN ARROW (Move the insertion point to the beginning of the next paragraph)
  • CTRL+UP ARROW (Move the insertion point to the beginning of the previous paragraph)
  • CTRL+SHIFT with any of the arrow keys (Highlight a block of text)
  • SHIFT with any of the arrow keys (Select more than one item in a window or on the desktop, or select text in a document)
  • CTRL+A (Select all)
  • F3 key (Search for a file or a folder)
  • ALT+ENTER (View the properties for the selected item)
  • ALT+F4 (Close the active item, or quit the active program)
  • ALT+ENTER (Display the properties of the selected object)
  • ALT+SPACEBAR (Open the shortcut menu for the active window)
  • CTRL+F4 (Close the active document in programs that enable you to have multiple documents open simultaneously)
  • ALT+TAB (Switch between the open items)
  • ALT+ESC (Cycle through items in the order that they had been opened)
  • F6 key (Cycle through the screen elements in a window or on the desktop)
  • F4 key (Display the Address bar list in My Computer or Windows Explorer)
  • SHIFT+F10 (Display the shortcut menu for the selected item)
  • ALT+SPACEBAR (Display the System menu for the active window)
  • CTRL+ESC (Display the Start menu)
  • ALT+Underlined letter in a menu name (Display the corresponding menu)
  • Underlined letter in a command name on an open menu (Perform the corresponding command)
  • F10 key (Activate the menu bar in the active program)
  • RIGHT ARROW (Open the next menu to the right, or open a submenu)
  • LEFT ARROW (Open the next menu to the left, or close a submenu)
  • F5 key (Update the active window)
  • BACKSPACE (View the folder one level up in My Computer or Windows Explorer)
  • ESC (Cancel the current task)
  • SHIFT when you insert a CD-ROM into the CD-ROM drive (Prevent the CD-ROM from automatically playing)
  • CTRL+SHIFT+ESC (Open Task Manager)
Dialog box keyboard shortcuts loadTOCNode(2, 'moreinformation'); If you press SHIFT+F8 in extended selection list boxes, you enable extended selection mode. In this mode, you can use an arrow key to move a cursor without changing the selection. You can press CTRL+SPACEBAR or SHIFT+SPACEBAR to adjust the selection. To cancel extended selection mode, press SHIFT+F8 again. Extended selection mode cancels itself when you move the focus to another control.
  • CTRL+TAB (Move forward through the tabs)
  • CTRL+SHIFT+TAB (Move backward through the tabs)
  • TAB (Move forward through the options)
  • SHIFT+TAB (Move backward through the options)
  • ALT+Underlined letter (Perform the corresponding command or select the corresponding option)
  • ENTER (Perform the command for the active option or button)
  • SPACEBAR (Select or clear the check box if the active option is a check box)
  • Arrow keys (Select a button if the active option is a group of option buttons)
  • F1 key (Display Help)
  • F4 key (Display the items in the active list)
  • BACKSPACE (Open a folder one level up if a folder is selected in the Save As or Open dialog box)
Microsoft natural keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • Windows Logo (Display or hide the Start menu)
  • Windows Logo+BREAK (Display the System Properties dialog box)
  • Windows Logo+D (Display the desktop)
  • Windows Logo+M (Minimize all of the windows)
  • Windows Logo+SHIFT+M (Restore the minimized windows)
  • Windows Logo+E (Open My Computer)
  • Windows Logo+F (Search for a file or a folder)
  • CTRL+Windows Logo+F (Search for computers)
  • Windows Logo+F1 (Display Windows Help)
  • Windows Logo+ L (Lock the keyboard)
  • Windows Logo+R (Open the Run dialog box)
  • Windows Logo+U (Open Utility Manager)
Accessibility keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • Right SHIFT for eight seconds (Switch FilterKeys either on or off)
  • Left ALT+left SHIFT+PRINT SCREEN (Switch High Contrast either on or off)
  • Left ALT+left SHIFT+NUM LOCK (Switch the MouseKeys either on or off)
  • SHIFT five times (Switch the StickyKeys either on or off)
  • NUM LOCK for five seconds (Switch the ToggleKeys either on or off)
  • Windows Logo +U (Open Utility Manager)
Windows Explorer keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • END (Display the bottom of the active window)
  • HOME (Display the top of the active window)
  • NUM LOCK+Asterisk sign (*) (Display all of the subfolders that are under the selected folder)
  • NUM LOCK+Plus sign (+) (Display the contents of the selected folder)
  • NUM LOCK+Minus sign (-) (Collapse the selected folder)
  • LEFT ARROW (Collapse the current selection if it is expanded, or select the parent folder)
  • RIGHT ARROW (Display the current selection if it is collapsed, or select the first subfolder)
Shortcut keys for Character Map loadTOCNode(2, 'moreinformation'); After you double-click a character on the grid of characters, you can move through the grid by using the keyboard shortcuts:
  • RIGHT ARROW (Move to the right or to the beginning of the next line)
  • LEFT ARROW (Move to the left or to the end of the previous line)
  • UP ARROW (Move up one row)
  • DOWN ARROW (Move down one row)
  • PAGE UP (Move up one screen at a time)
  • PAGE DOWN (Move down one screen at a time)
  • HOME (Move to the beginning of the line)
  • END (Move to the end of the line)
  • CTRL+HOME (Move to the first character)
  • CTRL+END (Move to the last character)
  • SPACEBAR (Switch between Enlarged and Normal mode when a character is selected)
Microsoft Management Console (MMC) main window keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+O (Open a saved console)
  • CTRL+N (Open a new console)
  • CTRL+S (Save the open console)
  • CTRL+M (Add or remove a console item)
  • CTRL+W (Open a new window)
  • F5 key (Update the content of all console windows)
  • ALT+SPACEBAR (Display the MMC window menu)
  • ALT+F4 (Close the console)
  • ALT+A (Display the Action menu)
  • ALT+V (Display the View menu)
  • ALT+F (Display the File menu)
  • ALT+O (Display the Favorites menu)
MMC console window keyboard shortcuts loadTOCNode(2, 'moreinformation');
  • CTRL+P (Print the current page or active pane)
  • ALT+Minus sign (-) (Display the window menu for the active console window)
  • SHIFT+F10 (Display the Action shortcut menu for the selected item)
  • F1 key (Open the Help topic, if any, for the selected item)
  • CTRL+F10 (Maximize the active console window)
  • CTRL+F5 (Restore the active console window)
  • ALT+ENTER (Display the Properties dialog box, if any, for the selected item)
  • CTRL+F4 (Close the active console window. When a console has only one console window, this shortcut closes the console)
Mar 29, 2009 | Microsoft Basic Keyboard 1.0A PS/2 KEMIBA
Operate an ipod
To get it unlocked: Find a black (or silver) oval switch on it. Move the switch to the left and orange will appear. Your ipod will be unlocked.
To scroll through things: Move your finger around the black circle.
To select something: Press the center black button.
To shut your ipod off: Hold down the pause button (button on bottom of scroll circle) for three seconds. Then switch the hold button to the right to lock it.
To pause something: Press the pause button (button on the bottom of the scroll circle).
I hope my solution was helpful. Please rate it.
Jan 17, 2008 | Apple iPod nano
87 people viewed this question
 Grubhead
Grubhead
