Question about Whirlpool ED5VHGXM Side by Side Refrigerator
Compressor fridge 1956 dead!
I have 1956 Westinghouse fridge vintage but recently the compressor stop and do not want to kick again. It was very hot & look like completly jammed. Can we replace it and if yes, I would like to replace it by something less noisy if it is possible.
Thanks,
  • Whirlpool Master
  • 5,568 Answers
<grin> Not under warranty any more?
Compressors have changed some since that was built but they still do the same basic job; turn a gas into a liquid so that the circulating liquid can remove heat from the unit while expanding into a gas again.
The coolant current units use is also different but serves the same purpose so I would say your old friend can be repaired.
Compressors range from ~$120 to double that (+ coolant cost) and labor is unpredictable since we don't know where you live but it is about a two-hour job. I would guesstimate between $300-$400 US - if it is quoted at lower than that, even better.
If you are in the US, check your local Better Business Bureau website for an honest service company and if more than one is listed, I'd call to get a preliminary bid on the repair.
You might inspect the condition of the gasket since a hardened one that no longer fits flush can cost a couple of bucks a month for lost energy by running the compressor longer than should be necessary.
Posted on Oct 02, 2008
Ok so I have a ge cafe. I recently replaced the motherboard as my controls were all messed up and it was not cooling. Afterwards it worked fine except that there was a howling noise inside of the unit. A...
Correct, condenser coils remove heat from the freezer compartment, thusly they will be hot. Sounds like the compressor is failing and that is probably giving off a squealing sound and stops running until it stops. Then your compressor will overheat and stop running until the thermal protector cools down and allows it to run again. Try replacing the compressor cooling fan.
Oct 15, 2017 | GE Refrigerators
Westinghouse two door fride freezer. The two blue lights are whis is between the first and second shelf is never happened before. They were both on but every time you open the door its stopped but when...
Frankly not sure unless something else going on. Some ice makers have a cut off light that when you open it lights up so ice won't kick out at your door while door open. Could also be a feature : https://www.masters.com.au/product/100399477/westinghouse-side-by-side-fridge-700l-wse7000sf
Motor kick on could be the compressor kicking on because the door is open and all that cold air is coming out and it is now turning on to cool again.
Nov 21, 2014 | Refrigerators
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
Fridge is causing the circuit breaker to trip when plugged in
Hi!!
Your unit is shorted out, check power cord and wiring on lower back of unit.
It may be the compressor shorted out.
If you have a pet, they some times remove wire insulation.
Turn unit so you can see the compressor housing on the bottom of the unit's back, you may need to emove the cover. turn breaker on and check if the small fan and the compressor kicked in. If the compressor did not start, and the breaker tripped again call a service tech to check unit.
Good Luck!!!
Aug 12, 2010 | Westinghouse Refrigerators
First gathered water at the bottom, thought that is was due to something touching the back. Stopped fridge, cleaned it, started it again. Light on but no familiar noice of the engine starting again. Engine...
Don't know the model/brand off the top of my head...
But: If the compressor is warm/hot, but nothing is happening, I ask this:
Even if the fridge is not cooling, is the compressor running, or dead silent?
If silent, but warm, do you hear a "Click" every so often ? Maybe 3 to 5 minutes apart, followed shortly by a 2nd click ?
If so, most likely the compressor has seized, and this is the over-current trip acting (thermal, so it needs time to cool).
Big problem if it is the compressor (expensive).
The only other thing that might cause a similar occurrence, would be if the compressor has a Start capacitor. If this has died, the compressor will not turn - just sit there getting warmer, as the over-current trip acts.
If it was a dead thermostat, the compressor wouldn't get power, and would be cold.
Dec 12, 2009 | Smeg Refrigerators
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Interkool 900 stopped cooling - what to check before calling for service? The unit has worked fine for 4 years. The fan runs, but the unit does not cool the wineroom anymore.
t seems like there is a problem with the thermosat, or the compressor. Its not sensing the temperature being to warm to kick the compressor on and cool it down. OR the compressor itself id dead. Hope I could help.
Wayne
Jun 26, 2009 | Vintage Keeper Interkool 900 Air...
Fridge freezer not cooling
(bad news) Repair man came today and said the compressor has died ;- (
(good news) Westinghouse will replace compressors less than 5 years old with a new one, just ring them with your serial number (inside front door) or supply a receipt and you only have to pay for the labour ;-)
Apr 12, 2009 | Westinghouse Refrigerators
Compressor will not work
  • it may be the compressor, check the temperature of the compressor when it has been running for a while. if it is too hot to touch then it is going bad. the compressor should only get warm not hot.
  • the start switch will also kick out if the compressor is drawing too much amps (even if cold) witch would also be a sign of a bad compressor.
  • another thing that could cause this problem is if the coils under the machine are dirty or the airflow is blocked. this will cause the heat to build up in the compressor and kick the start switch off.
  • compressors don't last as long as they used to.
Jun 29, 2008 | Frigidaire Refrigerators
LG fridge suddenly stopped cooling.
If the fan inside the freezer is running and the compressor behind the fridge is running and is hot to touch, you have a gas problem or the compressor is inefficient. This can only be confirmed by connecting refrigeration gauges to the gas system and should only be performed by a fridge tech.
Nov 04, 2007 | Refrigerators
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
87 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
