Question about SanDisk Sansa c150 MP3 Player
Computer won't detect Sansa C150
I plug my player into the usb port, and the only thing it does it tells me to plug it into a highspeed port. The player says it is MTP Connected yet I cannot access any files, it doesn't even show up in My Computer area. When it is switched to MSC, none of my files are there either. Player plays fine, it just won't let me delete or upload anything new. I tried resetting the player, and nothing changed.
  • 758 Answers
What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it connected on the back USB>>>
And if that doesnt work try to obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
Posted on Oct 03, 2008
When I plugin the Sansa C150 in to my Laptop USB drive, its not being recognised at all. Recently I have reformatted my Windows XP. Looks like the drivers for the same are missing, can some one tell me where do I get them.
Posted on Oct 27, 2008
I just bought the usb connector for the sansa sandisk c150 mp3 player and my computer will not recognize it when I plug it in.
Make sure it is the right thing.
I tried to use an extension cable for
mine and It won't work with it.
I don't understand it!
No ext fine, use ext no fine.
It could be the wrong cable/connector.
PLEASE RATE YOUR ANSWER
Aug 13, 2011 | SanDisk Sansa c150 MP3 Player
Sansa m240 files won't show up on computer
Uninstall/remove the mp3 player from the device manager of windows while its plugged into you computer and unplug afterwards from your usb port and plug it back in, windows now sees a new device and starts installing it.
Go to the configuration panel\system and click at the tab hardware and klik at the button device manager.
This should solve the problem.
Succes.
Aug 31, 2009 | SanDisk Sansa m240 MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
I know its a silly question but can anyone please tell me the step-by-step process to transfer songs to my sansa c150 MP3 player......... Thanks
  • Step 1:Free a USB port on your desktop computer. Now, grab the USB cable for your SanDisk Sansa MP3 player and connect the player to your computer.
  • Step 2:Wait for your computer to find and recognize the player. This may take a few moments. Once you receive a confirmation message, open your computer and scan the icons for the SanDisk MP3 player.
  • Step 3:Open the SanDisk Sansa MP3 player on your computer. The music files that you currently have saved to the player’s memory are displayed.
  • Step 4:Open a folder containing music files that is stored in your desktop computer’s memory. Scan the files for songs that you want to transfer to the SanDisk Sansa MP3 player.
  • Step 5:Left-click on a song file and drag to the SanDisk Sansa window. Drop the file and let your computer complete the transfer. The transferred file appears at the bottom of your music list.
  • Step 6:Unplug your SanDisk Sansa player from your computer. Turn the player on and allow the file transfer to update to the internal memory of the MP3 player.
Tips & Warnings
  • When properly connected, the SanDisk Sansa MP3 player displays a USB Connected message on its LCD screen.
  • The music files in the SanDisk Sansa MP3 player will have different icons next to their filenames which will tell the file type at a glance (MPEG, MPEG layer 3 or WMA, for example).
  • Some songs feature copyright protection which may interfere with your ability to transfer music to the SanDisk Sansa MP3 player.
Jan 27, 2009 | SanDisk Sansa c150 MP3 Player
Computer does not detect Sansa c150
This model is no longer made but sansa can areplace it for you. Go to their website and call tech support for your area.
Oct 28, 2008 | SanDisk Sansa c150 MP3 Player
Scan disk c150 strucked...
Did you follow the instructions for the firmware update? (holding the select button while inserting the USB cable) The firmware s/w SHOULD detect the device by itself, regardless of existing drivers. You may want to use the firmware image linked here
Oct 05, 2008 | SanDisk Sansa c150 MP3 Player
Not Doing Anything Sansa c150
go to my computer when it is plugged up and delete the music from the harddrive of the player.
May 16, 2008 | SanDisk Sansa c150 MP3 Player
Sansa c150 Problem
It sounds like you may have some other removeable storage in your computer...try to rename all removeavble disk to something else...they would be listed under my computer...then you want to clear the history and caches under windows media player...by clicking on tools, options....go under privacy..clear the history and caches..hit ok..and plug your device to a 2.0 usb ports...that should solve the problems you are having..if that doesnt work uninstall your device from the device manager and reinstall it back again...
Oct 04, 2007 | SanDisk Sansa c150 MP3 Player
Open Questions:
SanDisk Sansa c150 MP3 Player Logo
357 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
