Question about Nokia N95 Cellular Phone
NOKIA N95 LCD SCREEN
PLEASE CAN YOU HELP I HAVE A NOKIA N95, WHEN SWITCHING ON THE PHONE THE SCREEN IT WORKS BUT IS BLANK AS CAN RECIEVE CALLS AND MAKE CALLS I HAVE REPLACED IT WITH A NEW SCREEN THINKING IT WAS THAT BUT NO.
HOW CAN YOU HELP ME
This is shahid from Orissa. I had read your problem, I thought it is a software problem. In my opinion went to nearest Nokia Care it must be helpful to You. For further details contact : 09853922874. Thanks................
Posted on Oct 03, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 147 Answers
I htink the problem of your phone is the Connector that connects your LCD or monitor to the motherboard of your phone. There might be bended pins or the pins are bended and can't reach your phones monitor......that's why it can't transmit images to your screen, cause as what you have said you have replaced your LCD with a new one.If you found out that the pins are bended and can't be place to its usual position, better buy a new one for a good output.
By the way, u can find the connector that I'm saying right at the bacb of your LCD but it's not a part of the LCD, it is consists of several pins grouped together.
Try to check it, some of it might have been bended to much...notify me if it works or not,..
If it does work please rate my solution...Thank you!
2 Suggested Answers
issaconan
  • 115 Answers
SOURCE: blank screen on nokia n95
in you case, there is two probabilite :
- the screen
- the nape
and yhe nape is the moste probabilite, it's a small nape for the connexion betwen the screen and the mothercard.
in all the case this intervention need a professionnel intervention, i don't advice you to do it by your self if you are note.
good luck;)
Posted on Nov 20, 2008
I have lost the ability to recieve or send text messages and check call log
firast remove the sim and memory card then fortmat the phone using this method
first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
then try it your problem was solved
Oct 20, 2010 | Nokia N95 Cellular Phone
N 95 screen is blank
Its your flex cable. its a ribbon that links the lower part to the upper part. just replace it because it should be having some broken part.
Regards
Feb 10, 2010 | Nokia N95 Cellular Phone
N95 screen blank
check the flexible cable and lcd.
Dec 16, 2009 | Nokia N95 Cellular Phone
My Nokia N95 clicks when i slide it up, and screen blank
not broken.. flux cable is either dislodged or broken. ur set is fine.. it wont cost much.. get a new one.. chinese one is even cheaper
Sep 06, 2009 | Nokia N95 Cellular Phone
After taking care of my expensive mobile phone Nokia n95 8G for just 7months it turn to blank screen can't received a call or even make a calls or txt. its blank totally disappointed.
the white screen is caused by a broken crystal diode in the lcd screen. replace the lcd screen either at an authorised nokia centre, phone store or buy the lcd screen online and install the parts yourself- tools are provided with the purchase and its a simple DIY task. you'd spend $300+ at nokia centre, $200-$250 max if at a phone store alternatively you'd spend $100-$150 max if you DIY.
cheers.
Aug 03, 2009 | Nokia N95 Cellular Phone
Nokia n95 8gb lcd is blank but i hear it's turning on
if its blank you have to replace the lcd screen with a new one.
sometimes it maybe a flex cable problem which occurs in some slide phones.
at mobile phone repair stores, the cost of an original lcd screen replacement is usually $150-$200, though sometimes an original lcd screen may not be fitted into your device but rather a hong-kong made one which is similar to the original but is less brighter and a little less sharper.
if you take it to a nokia care centre to replace the lcd screen you may have to pay over $250.
you can just buy an lcd screen off ebay, replacing the lcd screen yourself isnt hard with the tools provided. you just have to take the ribbon cable from the old lcd screen and insert the new lcd screen and plug in the ribbon cable for it.
the reason for original Nokia n95 8Gb lcd screens being so expensive to repair/replace is that it is also the same lcd screen used for the Nokia N96.
cheers.
May 30, 2009 | Nokia N95 Cellular Phone
Nokia n95 8gb blank screen
hi the main problem is not in ur display screen. the lcd is ok. but inner connections might have got damaged.
Jan 19, 2009 | Nokia N95 Cellular Phone
Blank screen on nokia n95
- the screen
- the nape
good luck;)
Nov 20, 2008 | Nokia N95 Cellular Phone
My nokia n95 its got a blank screen plz help
it's you flex, the ribbon that connects your board and lcd.. it maybe lifted... or you have to change the flex if there's a cut.. bring it to the center to replace or re attach it could be loose too...
Apr 18, 2008 | Nokia N95 Cellular Phone
Please help me with my nokia n95
its your flex (the ribbon that connects to u'r board and lcd.. it maybe disconnected, or it is broken have cuts.. it can be re attach or replace the flex..2nd it could also be u'r lcd, but i'm sure it's u'r flex... bring it to the pro's.
Nokia N95 Cellular Phone Logo
159 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
