Question about Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Calypso Elite Top load - water discharge question
I have a strange problem and not sure where to go with this. The washer has been working fine until recently when I notice there is water on the laundry room floor. Had the technician out to check the washer for leaks and everything check out ok. Next I ran a wash load and notice that sudsy water was backflowing from the water discharge outlet pipe in the wall. Had the plumber out to clear the pipe and the problem is still there.
It seem to like during the rinse cycle the water discharge from the washer is too much for the outlet pipe to manage. Since the plumber had already cleared the outlet pipe, I am just wondering if there is a water regulator on the washer that might be causing the water to discharged at a higher rate than normal? This only happened within the last 2 months.
Any suggestion would be appreciated.
Why not just discharge into the laundry tub which will allow the water to build up but get away at its own pace through tub drain
Posted on Oct 02, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Stops in the middle of rinsing...leaves some water at bottom-
Calypso...The pumps fail often. They have redisigned one that theres not as many problems with, but if you still have the original, this is deffinatly the problem. As far as clothes getting stuck, the U-Joints wear out and cause too much play allowing things to get stuck. Total for this repair parts + labor will usually run about 500-600. There was a class action lawsuit for this machine and they no longer make it.
Mar 08, 2009 | Kenmore 24032\24036 Top Load Washer
Calypso kenmore elite water level low sometimes
something is clogging recirculating pump inspected both pump that should fix
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Calypso GVW9959K Top Load Washer Logo
116 people viewed this question
Dan Webster
Dan Webster
Sal De
