Question about Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher
Whirlpool Silent Partner 1 Dishwasher running too long in wash cycle
I just bought a brand new dishwasher and hooked it up yesterday. It ran in wash cycle for more then 1 hour 30 minutes , got tired of hearing it run and drained it. I had a old one that if I recall only ran about 45-60 minutes total. This new model is suppose to be a energy star product, how in the heck can it be saving money running so long?
And whats up with paying so much for a appliance and you dont even get the hoses or electric cord anymore. $425 for washer, $18 for hoses, $10 for electric cord.(Husband even went to lowes to buy a cord and they said they didnt sell them, he asked do the cords come with your dishwashers?, they said NO...Stupid huh?) I find this to be totally unexceptable, and a BIG rip off. The maker can buy these parts a lot cheaper then we can, so why not add the parts for a few bucks and keep the customer from running all over town trying to find the parts that should of been with the product to begin with. I don't know about you all, but I'm about feed up with companys nickel and diming us to death.
Just need to blow off some steam....... Grrrrrrrrrrrrr
  • 457 Answers
I feel sorry for next guy who sells you another appliance :)
Posted on Mar 01, 2010
Whirlpool Quiet Partner II Dishwasher is banging during fill cycles. I have to run the sink faucet to stabilize the pressure. Do I replace the inlet valve or the hose, or is it some other part? It used...
Sounds like you may need to call someone who can repair it because built in dishwashers are harder to fix if its a valve.. may need a new dishwasher if you say its getting worse..
Mar 19, 2015 | Whirlpool Dishwashers
Whirlpool quiet partner II stops running or won't complete it's was cycle, sometimes is will wash for a few minutes and stop or it will stop before the water even starts to flow.
I had the same problem with my dishwasher. After hearing that the motherboard was the problem I decided to take a closer look. There were two capacitors (1000 microfarads, 6.3 volts) that looked a little suspect. The tops of capacitors should be flat...these looked like soda cans that had been left in the freezer. Got on eBay, located the capacitors for roughly $3 and $4 shipping, for approx total of $10. Soldered the two new capacitors into the motherboard and put it back together. As soon as I closed the door, the dishwasher started draining the water. When I ran a Normal cycle it completed successfully. Saved myself over $120!
Aug 02, 2013 | Whirlpool Gold Dishwasher with Quiet...
Brand new whirlpool dishwasher starts on own
Because you cheated and filled it manually, it may be that the second running was actually resetting the programme. Do a normal wash, and if it does it again, contact the maker for advice.
May 10, 2017 | Whirlpool WDF750SAYB Gold Series...
RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher- whirlpool (silent partner I )
Sounds like you are not getting water I'd check the water valve first.
Jan 28, 2009 | Whirlpool Dishwashers
Ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Bosch sgi45e12gb/22 dishwasher won't stop
hey you..I have a whirlpool dishwasher too that would not
stop the wash cycle...it would run for 2-3 hours,
and then run thru the whole wash cycle again!
so..I had a whirlpool factory trained repair man come to
the home. He ran a diagnostic and it was 100% good,
so he called Whirlpool headquarters spoke to them;
said...........every 250 hours the dishwasher will
RE-CALIBRATE itself! running for 4-4 1/2 hours
straight, in order to re-calibrate itself. I was
interupting this by opening the door before it had
run the full 4 -41/2 hours of it's self-maintenance program.
Perhaps that your dishwasher is doing too?
p.s. always make sure you get a repairman that
is factory trained in your specific brand, otherwise
you'll waste $$$ money with a repairman who doesn't
have access to the corporate tech's and direct access
to their parts/inventory.
good luck with your dishwasher!
mine is the whisper quiet with computer control on front
of the door.
Apr 11, 2008 | Dishwashers
Whirlpool d/w is stuck on wash cycle
Is it filling and emptying at the same time???? If not could be a heat problem. How long do you leave it running for?
Jan 03, 2008 | Whirlpool 24 in. DU1050SS Built-in...
Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher Logo
204 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
