Question about Zebra Printer 140-751-00000
Zebra 140 thermal printer
The printer does not print. Everything seems to be working properly except the labels come out blank.
  • kbrooks836 Jan 30, 2009
    Having the same issue here. The config prints, I can print a font list.
    But when I go to print labels from crystal reports the correct number of labels come out but the labels are blank.
    This was working earlier this morning. The only thing that has changed is that the computer was shut down. Since being turned back on the labels are blank.
    Scholar:
  • 45 Answers
Hello, mmgarcia10.
I've dealt with Zebra 140's for a lot of years. It's best to start with the easy fixes, so please don't take offense if I ask you to check obvious probelms.
I'm assuming you use a ribbon (as opposed to direct thermal paper). When replacing ribbon, it's easy to slide the spool on facing the wrong way.
Can you verify that the ribbon is loaded with the ink facing down? The back of the ribbon is probably shiny and should face up. The ink side is dull and ink can probably be scraped off by your fingernail. The ribbon on the spindle should unwind clockwise, not counter-clockwise. If you're familiar with cleaning the printhead, this would be a good time; if not skip the cleaning for now to avoid damage.
If the ribbon was loaded OK, the next thing I'd check is the printhead pressure. The are two posts with thumbscrews located above the printhead. The thumbscrews press against springs that in turn apply a small amount of pressure to the printhead. Each post has two thumbsrews that can be tightened toword each other to lock the position. Labels and ribbons can be a little tricky to load, and sometimes these posts can slide to the side by mistake. A good rule of thumb is to position these above the left and right sides of the label. Don't apply too much pressure, or the printhead will wear out faster, and printheads are exensive. If one side prints light and one side dark, give the light side a little more pressure.
If the labels still don't print, turn the printer off and then on (to reset the main board).
I can't remember if the Z140 can print a configuration page or test print if you hold down the Feed button while turning on the power. It's so easy it's worth a try. I know you can print one by navigating through the front panel. If the label doesn't print, it's probably a hardware problem. I've never seen a ribbon cable work loose from a printhead, but if you can find the connector, you can jiggle it a little and press it in to try to reseat the pins.
If the config page prints but labels from your software don't, you could check the darkness setting in you software, and also in the printer driver (right click the printer name, and choose something like Printing Preferences). There's also a darkness setting stored in the printer that can be set through the front panel, but this is often over-ridden by label software.
Hope this helps,
Label_Guy
Posted on Oct 02, 2008
  • John Michael Swan Oct 03, 2008
    Here's a couple of additional ideas, just in case you need them.
    If your software has an option to "Clear Cache", try that.
    In the Printer Preferences (Right Click Printer Name), if your driver has the following options (probably on a tab marked "Options), Check options "Reimage Changed Ojectes Only", "Image Entire Label", "Use Temporary Formats". Try to print, then Uncheck options "Reimage..." and "Use Temporary...", and try to print again.
    Good luck,
    Label_Guy
Hi I am printing barcode labels on a Zebra Tlp2844-Z. I can print resident barcodes in passthrough mode using the old Zebra driver (1.0.0.43) but the barcode does not print using the ZDesigner driver...
Have you tried creating the barcode / label using the ZDesigner software? It is available free on their website and I'm sure you'll find it easy to use. Hope this helps!
Aug 23, 2011 | Zebra TLP 2844-Z Thermal Label Printer
Everytime i turn on my zebra tlp 2844-z it prints 2 blank labels.anyone please help me to solve this problem
Are you using the correct labels?
Direct Thermal Printers use different labels than printers with ribbons.
If you print a label using labels from a ribbon printer in a direct thermal printer they will come out blank.
Jan 28, 2011 | Zebra TLP 2844-Z Thermal Label Printer
Want to reset my Zebra 140XiIII back to factory settings?
I resolved the problem by going into the setup program and then exiting and at that point I was prompted to save my changes and one of the options was to load Default settings. Once I chose this I was able to print on the 4X6 labels correctly, before that the configuration was feeding a label and 1/2 and print across two labels.
May 04, 2009 | Zebra 140XiIII Plus Thermal Label Printer
My printer won't print. It will only produce blank pages.
Usually that means that the labels are missing from the printer. Turn the printer off. Reload the label stock and restart the computer it is connected to. Then it should work properly.
Apr 14, 2009 | Zebra Z6M Plus Thermal Label Printer
Zebra LP2443 thermal label printer wont print
Hi Buck,
What type of labels are you using?
Cheers
Bob
Jan 12, 2009 | Zebra LP 2443 Thermal Label Printer
Zebra 105se blank labels problem
I would say the roller isn't the problem. I had the same problem on many Zebra printers, but often the calibration helped. Then it could do, when printing task label is for larger/longer than the label size is set in the printer system (conflict of software with printer settings after calibration). It could be set too down to bottom in Y axis. Or it could be in the software settings - as action after print - not sure.
Try to open the printer queue while the label is printed and check if the label has proper number of pages or there's 1 page more. If it is the right number - then the problem is on printer side (recalibrate, reflash it). If the number is about 1 higher, the problem is with settings of the label size (barcode software, printer settings) or action after print on PC side.
May 30, 2008 | Zebra 105Se Thermal Printer
Zebra 105 SE Printing Blank Labels
You need the correct driver for the 105Se. The 300 dpi SL driver is not compatible.
Unfortunately, Zebra does not make it's older drivers available online. You will need to locacte someone with the correct driver for whichever version of Windows you are using.
Steve
Feb 13, 2008 | Zebra 105Se Thermal Printer
Zebra 105SE
make sure the ribbon is installed properly. The thermal ribbons are only coated on one side with ink. Make sure the right side is facing the paper. If that is not the issue the thermal head might be bad.
Jun 26, 2007 | Zebra 105Se Thermal Printer
Zebra Printer 140-751-00000 Logo
567 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
