Question about HP LaserJet 3050 All-In-One Printer
Hp laserjet 3050 scans copy with streaks in windows vista
Everything works fine on the printer except the scan function. When I scan something into the computer, the computer copy pops up with a partially scanned page, the rest of the page is streaks. Please help!!!
Hp laserjet printer 3050 reinstall pritner driver.
Posted on Oct 21, 2008
Only scanner problem , horizontal lines appeared during scanning
No PC model stated
no OS stated (opr. system) windows 10?
we can not help you, ever lacking key facts
why not go to your HP support page and load all software
Related to Laserjet 3050
here
https://support.hp.com/us-en/drivers/selfservice/hp-laserjet-3050-all-in-one-printer/1140783/model/1140778
Aug 06, 2017 | HP LaserJet 3050 All-In-One Printer
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
Multifuction hp laserjet 3050 conflict with hp laserjet M1522N
After installing the printer software you need to program scanning software.
Below are the steps to program scanning software:
To program the Scan To button:
Select Start/Programs or All Programs (Windows XP)/HP/HP Laserjet 3050, 3052, 3055, 3390, 3392/Scan
Click the Setup to open the Scan To Setup Wizard.
Select the Change the destinations that show up on the all-in-one control panel when I press the <Scan To> button and then click Next .
Check the Allow me to scan by pressing the Scan To button on the all-in-one check box.
Choose the destination by moving them from the PC window (the left window) to the All-in-one window (the right window).
NOTE: The All-in-one window might contain items set up by other computers that are connected to the all-in-one. You cannot make changes to these items.
Click Update .
To Create a destinations:
Follow steps 1-2 from the above steps.
Select Create a new destination with settings that I will specify and then select Next .
Select the Save it to my computer and then press Next .
Select the scan preferences and then select Next .
Select the scan destination folder and file format type and then select Next .
NOTE: If you wish to use a custom folder for your scan destination, you will need to create the folder prior to this setup wizard in order to browse to it.
Select the quality level you would like the file to be saved as.
Name the new destination on the computer, check the Send this new destination to the all-in-one check box, and enter a name for the display on the all-in-one. Then select Next .
Confirmation allows you to verify your settings. Select Save .
Once the new destination has been saved, the new destination will be configured as one of the Scan To destinations on the printer.
May 15, 2009 | HP LaserJet 3050 All-In-One Printer
Scan and copy lines
using PRT screen and menu find clen function and try if this feature will fix the issuw.
Change the cartridge if no results.
Jan 30, 2009 | HP LaserJet 3050 All-In-One Printer
I have a HP LaserJet 3055. I bought it when I was using XP but I now have a new computer using Vista. I have downloaded and installed from HP the installation setup program for Vista - followed all the...
As i understand that you u r able to print and copy fine which ensure that there is no issue with the connectivity and scanning device.
However next troubleshooting comes in picture is software as per you have mentioned that yoiu have downloaded and installed the complete software couple of times still the issue persists.
In that case we need to Programn Scan to option in the printer software and on your all in one.
HP LaserJet 3050, 3052, 3055, 3390 and 3392 AiO Printer series - How to Program the Scan To Button and Create New Destinations
Information
The Scan To button must be programmed before it can get used. However, some destinations are programmed by default if the all-in-one is directly connected to the computer.
Details
Click Update .
Dec 21, 2008 | HP LaserJet 3055 All-In-One Printer
Hp laserjet 3050 scan problem
You should go to HP.com and look for a TWAIN scanner driver the works for that printer in Vista.
Jun 14, 2008 | HP LaserJet 3050 All-In-One Printer
3050
when we copy or scan we get lines at both side throught
the paper
Apr 15, 2008 | HP LaserJet 3050 All-In-One Printer
Hp laserjet 3050
make sure u go to the HP site and download the latest version of HP operating software or u will need to contact HP support
Dec 30, 2007 | HP LaserJet 3050 All-In-One Printer
Streaking
Check the scanning glass bar. If you scanned something that had whiteout on it, a lot of times some of the whiteout will get on the glass and will cause streaks in the prints. Clean it with alcohol.
Oct 16, 2006 | HP LaserJet 3015 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
425 people viewed this question
Seeker5211
Seeker5211
