Question about Kitchen Ranges
My oven is locked, after it self cleaned itself. How do I unlock my oven door?
I had this problem but my digital display went blank also. After searching the internet it seems to be a common problem. I changed the FIXED THERMOSTAT . Part # 8300802. It looks like a large watch battery with to electrical connectors affixed with 2 screws. I unplugged the power and shut the gas off. Took off the back metal sheet panel at the back . ( 10 screws ) . I noted which wire went where and replaced it . Put the sheet panel back , plugged it in and turned on the gas and it was good to go. It took 15min. tops. I got the part supplier to print me off a diagram so I knew what I was looking at but if you get the part first you will know soon as you take the back metal sheet panel off. It's the only thing back there.
Posted on Oct 03, 2008
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 | Ovens
Tip
How to CLEAN a Frigidaire Self-Cleaning Oven Step 1Use a plastic spoon to scrape...
Step 1Use a plastic spoon to scrape away any extra spillovers or burnt-on food from inside the oven. Remove as much of this as you can before running the self-cleaning cycle, because any spillovers left in the oven during the cleaning cycle may cause a lot of smoke.
  • Step 2Wipe off the inside of the oven with a rag dipped in soapy water. Be careful not to get any cleaning supplies on the oven door gasket or to disrupt the position of the gasket at all; having a good seal is critical to the success of the oven's self-cleaning cycle.
  • Step 3Clean any soil away from the oven frame and its door liner with a rag dipped in soapy water. Any soil left on these parts of the oven may become burned on during the self-cleaning cycle.
  • Step 4Pull the broiler pan and grid, any utensils, and any tin foil that may have been left in the oven out of it. They can't withstand the extreme temperatures the self-cleaning oven will reach. It's okay to leave the oven racks in the oven.
  • Step 5Make sure the oven door is completely closed.
  • Step 6Press the "CLEAN" button on the control pad. Use the up and down arrows to select the desired cleaning time; use 2 hours for a lightly soiled oven and 3 or 4 hours for a dirtier oven. The oven will lock itself and begin the cleaning cycle.
  • Step 7Wait for the cycle to end and the oven to cool; it will then unlock itself automatically. Don't try to open the oven door before it has unlocked itself.
  • on Apr 07, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Admiral electric range with self cleaning oven
    Hey there gcato1, your problem is actually a protective feature designed to prevent you from getting burned. The self cleaning feature runs at extremely hot temps. Until the temperature reaches a safe level, the oven door will remain latched. Be patient and the problem will solve itself.
    Jan 29, 2008 | Maytag Admiral LER3330AAW / LER3330AAZ /...
    How do i lock the self cleaning ge oven door when i put it on self clean
    If you have a self cleaning oven, the door will lock automatically as the self cleaning begins. Give it some time ,it will happen. When cleaning is done it will take a while for the door to unlock. GOOD LUCK FRIEND.
    Nov 08, 2014 | General Electric GE 24" Single...
    Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
    The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
    May 11, 2014 | GE Ovens
    After self-clean cycle oven door won't unlock
    your lach might have given out on self clean. change it
    Feb 12, 2010 | GE Profile JTP18 Electric Single Oven
    Oven door will not unlock
    Hello,, Some times this will happen after a self clean cycle if the timer did not finish the entire clean. Try to set the clock to start the self clean again then simply end the self clean. This should unlock the door. If the door remains locked. You may check the oven for an error code, or the door latch itself may need to be replaced. One other possible would be to turn off the power to the oven and try to let the oven control reset. leave the power off for about 15 minutes then turn the power back on. That will sometime work aswell. Good luck and feel free to call me if you need more help.
    MIchael Anderson
    Anderson Appliance
    (865)945-3808
    Feb 10, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
    Oven Door Locked
    the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
    Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Cant unlock self clean oven door
    Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method.
    May 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Kitchen Ranges Logo
    193 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
