I have and hpdeskjet 960c printer. The amber light over the symbol for the ink cartridges is blinking. I replaced both the black and color cartridges. The light is still blinking and the printer won't print when I send a print command from my computer to the printer. Any suggestions how to get the printer to print? It ran perfectly 2 days ago. The problem occurred on my first print job yesterday.
  • 70 Answers
Open the top cover and allow the print cradle to move to one of the icons this indicates what the problem might be
it either shows that the cartridge is not inserted properly or the incorrect cartridge
or may be low on ink.
remove the cartridge and reinsert
if all else fails replace with new cartridges
Posted on Oct 02, 2008
I have replaced black ink on a hp deskjet 960c and the red light keeps flashing
I see you replaced the Black in on your HP printer but the light keeps on blinking still.
Make sure that you remove the silicon film from the ink cartridge before installing in the printer, if that file is not removed the contact to the printers ink will not detect the ink cartridge at all.
Also try to remove all the ink cartridges and install all of them at the same time , this is to reset the printer from detecting all the printer ink cartridges.
I hope this helps
Oct 26, 2011 | HP DeskJet 960c InkJet Printer
I put new print cartridges in my 960c printer. They are hp 78 for color and 45 for black and white. my orange ink light will not stop blinking. It is not printing
I have an HP DeskJet 1220C that has been working fine for two years now. All of a sudden it can only print in pink and black. It is driving me crazy. I have tried the following without any success:
1. Replaced the cartridges twice
2. Aligned and cleaned the cartridge from the
computer
3. Soaked the cartridge head in hot water,
and made sure that all three colors will bleed
out of the head
4. Cleaned the cartridge contacts with an eraser
5. Cleaned the cartridge contacts on the printer
with a brush
Is there a cure, or is it time for a new printer?
Aug 25, 2011 | HP DeskJet 960c InkJet Printer
DeskJet 960c InkJet Printer: where do i find my ink level for hpdeskjet 960c?...
us the utility to choose tools, service my printer, and click the tab with the ink levels on it.
May 16, 2010 | HP DeskJet 960c InkJet Printer
My HP Deskjet 960c was out of black ink I replaced the cartridge and now the ink light is blinking and will not print.
Check if you replaced it with the correct ink cartridge or return to supplier for a replacement.(Also ask your supplier to test it)
Apr 24, 2010 | HP DeskJet 960c InkJet Printer
ORANGE LIGHT IS BLINKING AND PRINTER WILL NOT PRINT
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
If I have helped please rate my post...I will always do my best to help
Sep 11, 2009 | HP Laser Jet 1320 Printer
Replace ink cart and amber light still blinks
Usually if the Amber light is blinking with a new cartridge, that cartridge has bad electronics.
Try replacing the cartridge with another or the old one, if the light goes out it was just a bad cartridge.
Sep 10, 2009 | HP DeskJet 932c InkJet Printer
Orange blinking light at cartridge icon
The Amber light is designated as the "Ink Error" light. With regards to a 960C Hewlett Packard or almost any inkjet printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Sep 10, 2009 | HP DeskJet 960c InkJet Printer
Rhinotek color cartridge not recognized in my HP printer. what can I do?
Non-HP cartridges often give troubles in HP printers. Probably the best thing you could do is just use HP cartridges.
May 05, 2009 | HP DeskJet 960c InkJet Printer
Nothing will print; blinking amber light
Are you out of ink? when you open the lid to the printer while it is turned on look at were your ink cartridge stops and that will tell you if you are out of colour or black ink. Which light is blinking the one on top of the paper symbol or the one on top of the ink symbol. It may be that your cartridge either black or white just need to be taken out and put back in I found that if I wiped the bottom of the ink cartridge where sometimes you get build up that it would work again or give it a shake but make sure you cover up the bottom were the ink comes out before you shake it. Hope this helps!
Nov 15, 2008 | HP DeskJet 920c InkJet Printer
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
265 people viewed this question
k24674
