Question about Sony Handycam DCR-DVD105 DVD Camcorder
Camcorder disc footage not viewable
I have a sony dvd camcorder dvd105. I have used a tdk DVD+RW to record holiday footage. I have taken the disc out of the camcorder to watch on my dvd player, but nothing played. I put the disc back in the camcorder but now the only option it gives me is to format the disc, I assume this will wipe it. How do I get my footage back ???
Hope you can help
    Master:
  • 763 Answers
Try to put it on your dvd rom of computer and see if its working. if you can see the files on your computer, then burn it in nero sofware. so that i will watchable by your dvd player. hope that helps!
CHARCOIS
Posted on Oct 03, 2008
It is sony dcr-dvd105. i shot 5 minutes. if i finalize the 5 minutes, i basically lose the rest of the dvd, am i right? is there a way only finalize the 5 minute and transfer to pc and still be able to use...
I'm glad to inform you that it is possible to record additional scenes after finalizing when you use DVD -RW and DVD +RW discs.
When using finalized DVD -RW(VR mode) disc, you can record additional material on the disc without any additional steps.
Other case, you can unfinalize the discs using [UNFINALIZE] option under DISC SET Menu.
Please let me know if you require any clarifications.
Thanks for understanding.
Mar 15, 2011 | Cameras
It will not load certain dvd discs
Below is a list of discs that should or should not be used with the DVD recorders.
DVD-R
4x can be used
8x will result in a disc error.
DVD-RW
2x can be used
4x will result in a disc error.
The following discs have been tested and are proven to be compatible with our DVD recorders.
MEMOREX DVD-R
FUJIFILM DVD-R
FUJIFILM DVD-RW
IMATION DVD-RW
IMATION DVD-R 2.0
TDK DVD-RW 2X
TDK DVD-R 2X
The following are brands of discs we DO NOT recommend:
MEMOREX DVD-RW
SONY DVD-RW
SONY DVD-R
TDK DVD-RW 4x
TDK DVD-R 4x
Please be aware that a free software upgrade is now available to customers. This upgrade will enable your unit to recognize the (DVD-R 8x) discs. To obtain a copy, please call 1-800-242-7158. Customer service by phone is available 7 days a week 6:00am to 9:00pm pacific time.
In order to receive the upgrade we need to know what firmware version your unit requires. First you need to access the DVD recorders service mode. Turn on the DVD Recorder and the Television, make sure the unit is on the DVD side. You may access the service mode by pressing the CMSKIP button on the remote control. Once you press CMSKIP you must press the numbers 1,2,3. You must do this quickly so it may take a couple tries. The model name will appear on the screen followed by Firmware Version. I need to know the serial number next to FE:
Press the RETURN button to exit screen.
Brian W.
Customer Support
Funai Corporation
19900 Van Ness Avenue
Torrance, CA 90501
1-800-256-2487 Customer Support
1-310-320-0571 fax
Feb 07, 2010 | Emerson EWR20V4 DVD Recorder/VCR
Formatted disc
Doubt it. On a RW disc, the physical state of the "recording gel" is altered when formatting.
Dec 07, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
SONY HANDYCAM DCR-DVD105 ERROR MSG C:13:02
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
Jun 28, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
I want the pictures and video off my DVD-RW on to my computer
Yes, you must finalize to view the dvd in a stand-alone dvd player.
No, battery doesn't have to be charged but the camera does have to be plugged in to do finalizing.
After, finalizing the disk, and you are in fact using DVD-RW (re-writable) disks, yes you can un-finalize them within the Canon camera to record more video.
I have used the same 3 rewritable disks on my Canon over and over again to record many hours of footage.
Apr 30, 2009 | Canon DC210 DVD Camcorder
Sony Handycam disc error when i try and finalize it
what type of disc--r -rw +rw? try to finilize in someone elses camcorder if possible and see if it reads it-does it play in camcorder still?
May 06, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
"no disc" on screen with disc inserted correctly
Dear Kweku88,
Please check your camera with another mini-DVD. actually camera detects dvd with its dvd-lens. there is no other sensor to sense dvd inside.
Apr 10, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Sony handycam dcr-dvd105
dear tonimo
if you was finish your recording, select menu and choose finalize
it can make your dvd can play in dvd prtable
oke
cropp
Dec 26, 2007 | Sony Handycam DCR-DVD105 DVD Camcorder
Disc Read Error Sony DVD Handycam
I am just throwing these out there as food for thought. Make sure you ended the recording on that other side. If a DVD is left open(meaning more could be written to it) other dvd players have a hard time reading the info. Put in one of the 2 sided disc's that worked. how does the camera recognize the disc? Then insert the troubled disc and see if the disc info is being read the same. i.e. disk size, manufactuer, open/closed? Check for a firmware upgrade for your DVD burner/player(s). Let me know how things work out. Tim
Mar 05, 2007 | JVC VDW14DU Single Unit 2x DVD-RW Storage...
Sony Handycam DCR-DVD105 DVD Camcorder Logo
106 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
