Question about Dryers
Kenmore Series 80 electric dryer - need a diagram or breakdown of how to replace the belt & pulleys.
  • Anonymous Mar 23, 2014
    Changed belt and the pulley mechanism came diagram to get it back in. Does anyone have a diagram as I'm sure I don't have it correct? Thanks
    Where would I get a diagram of pulley set up for the dryer belt? Changed the belt and now can't get it back together correctly.
  • 943 Answers
Hi. i will send you to .repair clinic. go to dryers and belt diagrams. sorry i cant send you one. if you have any trouble, get back to me the appliance doc
Posted on Oct 02, 2008
Does a kenmoore 80 series have glides
go here and you can see the parts in your dryer,if the model isn't a maytag pye2300ay then just put your model number in there and it will show you,kenmore doesn't make anything,you go by the model number if it starts with 110. it's a whirlpool,if say 417. it's frigidaire made but the maytag model you sent has rollers and i would say if you have a kenmore 80 series it has rollers,you can buy a kit that comes with the rollers,belt and belt pulley
Nov 14, 2013 | Maytag PYE2300AY Electric Dryer
How do I take the top off of a Kenmore 80 Series?
You remove the back panel that is how your get to everything. once the back panel is removed you will be able to put the belt and the idler pulley on. Please rate
May 24, 2010 | Kenmore 64852 Electric Dryer
I have a kenmore 80 series electric dryer. It gets
If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Thanks for choosing fixya...Regards, Joe
Nov 13, 2009 | Cars & Trucks
I have my kenmore 80 series dryer apart, and i am replacing the belt. having trouble configuring the belt around the pulley and motor, since the belt cannot actually go into the pulley, its sealed. help.
Kenmore dryers are configured in several different ways as far as the location and routing of the dryer belt. For drawings of how the belt is configured on your dryer, go to and click on the "Repair Help" link. On the following page locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to the Kenmore section and refer to diagrams H, B, or K. If you are not certain, please post back with your complete model number (located on a nameplate around the door opening) and I can determine for you. I hope this helps you.
Oct 23, 2009 | Kenmore 62622 Electric Dryer
Pulley fell off while reassembling kenmore dryer 80 series
the pulley goes right beside the motor pulley,the belt goes under the big pulley and onto the motor pulley-mike
Mar 03, 2009 | Kenmore 659 Electric Dryer
KENMORE SERIES 80 DRYER..The Tensioner use it or not and how?
To fit the new belt, you will need the idler pulley (tensioner)...
The idler pulley fits in the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Place the belt (grooves inward) around the drum. Pull the belt through the middle of the idler pulley from the left side. Once the belt is pulled through the idler pulley, pull it around the motor pulley (this should force the idler pulley to "open up" and add tension).
If you still need help, I will try to provide you with a diagram shortly.
Mar 02, 2009 | Kenmore 62622 Electric Dryer
I have a Kenmore Series 80 dryer and the belt broke. The pulley came off and I don't know where it goes or how to put it back on. I also don't know the routing diagram for the new belt. Please help ASAP I...
it goes on the shaft of the electric motor the belt goes around the drum should be a set screw on pulley reattach to shaft tighten then looosen bracket on motor apply tension and tighten you may have to go to the hardware st ore and get another screw if yours is lost as a tip apply red loctite to the threads to prevent it from vibrating loose they have that at the hardware store or auto store
Jan 15, 2009 | Kenmore 62622 Electric Dryer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Idler pully
there has to be a spring on the idler to keep it pulled against the belt
Mar 01, 2008 | Kenmore 62622 Electric Dryer
Dryers Logo
737 people viewed this question
Top Dryers Experts
