Question about Brother HL-2040 Laser Printer
Brother printer problem
I have a brother 5250DN printer, anytime i try to print I see red flashing light.
Can anybody help?
  • kommando Oct 10, 2008
    Please i have an 8860 brother multifunctional printer but the "Fax" function does not work properly.
    When you send a fax, it takes about 45 mins to go and sometimes it doesn't go at all Can u help me solve this problem?
    Commando
  • 70 Answers
Manual Feed Command.
1. Press the Job Cancel button to cancel the print job. Delete the print
job in the print queue on the computer. You can quickly access the print queue by double clicking the Printer icon in the task
tray or dock.
2. Turn the printer power switch OFF on the right side of the printer.
Check that the front cover is closed.
3. Turn the printer power switch ON while holding down the GO button
until the Toner, Drum, and Paper LEDs are lit.
4. Release the GO button. All LEDs will be off.
5. Press the GO button 8 times. The green Status LED will flash briefly
while the printer is reset. After the printer is reset the Status LED
will be lit green.
6. Print the Print Settings by pressing the GO button three times. If
the Print Settings pages do not print and the Paper LED is on again skip
to the next section - No Paper in the Paper Cassette.
If the Print Settings pages print, the problem is isolated to printing
from your computer. The Paper Source of the Brother printer driver or
program you are printing from may be set to MP Tray or Manual, instead
of Auto Select, Tray 1, or Tray 2 (if the optional paper tray is
installed). To check the Paper Source setting of most programs, click
File and Page Setup or Page Layout. You may need to click the Paper
Source tab or Paper tab depending on your software application. Verify
that in the Paper Source section does not list MP Tray or Manual. Choose
Auto Select, or another relevant source such as Tray 1. Click OK. Try printing the document again.
No paper in the paper cassette.
1. Pull the paper tray completely out of the printer.
2. Insert the letter or legal size paper into the paper tray with the
top edge of the paper first and the print side down. Make sure that the
paper is flat in the tray and below the maximum paper mark. If using a
paper size other than letter or legal, the paper should be loaded in the
MP Tray. The MP Tray can print on paper from 2.75 in. by 4.57 in. up to8.5 in. by 16 in.
3. While pressing the blue paper-guide release lever, slide the paper
guides to fit the paper size. Make sure that the guides are firmly in
the slots. For legal size paper, press the lever located at the back of
the tray and pull out of the back of the open tray.
4. ReinstalI the paper cassette back into the printer. Press the GO
button. If the alarm clears, no further troubleshooting is needed. If
the alarm continues, follow the steps below.
Paper Jam at Paper Pick-up.
1. Turn the printer power switch OFF on the right side of the printer.
2. Remove the paper cassette from the printer.
3. Elevate the front of the printer slightly to locate the jammed
paper.
4. Gently remove the jammed paper.
5. ReinstalI the paper cassette back into the printer.
6. Turn the printer power switch ON. If the alarm clears, no further
Posted on Oct 02, 2008
I've installed a new drum AND a new toner cartridge. have followed all directions to reset the drum and the light still flashes and I can't print, this is for a brother HL-5250DN printer
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Jul 20, 2010 | Brother HL 5250DN Laser Printer
Brother 5250dn and all light are blinking
That series of lights indicates a main circuit board failure. You will need a shop to replace the main logic PCB. Could be caused by anything, static shock, bad input power from power strip or power failure, just plain CPU failure. If it's under warranty, 1 year since purchase, you need a Brother service center, out of warranty a new printer would cost less than repair.
Feb 02, 2010 | Brother HL 5250DN Laser Printer
Hi - I have a Brother HL5250DN with the paper light flashing but there is paper in the tray and now it wont print - can you help??
Is the Status light also red? This could mean other things than being out of paper. It could be a paper jam (most commonly anyway). Get a flashlight out and inspect it for jams.
Jan 13, 2010 | Brother HL 5250DN Laser Printer
Drum and error light are on - got new cartridge - installed as directed - blue light will not stay on - printer will not print - red and orange lights will not go out
I can't recall the buttons on Brother laser printers but leaving the cartridge door open and pressing and holding down one of the buttons for about 5 seconds will clear the drum light error.
I've done this to clear the same error on aBrother HL5250DN laser printer.
If this doesn't work please post your printer's model number.
Sep 21, 2009 | Brother HL 5250DN Laser Printer
All the Lights are flashing on my HL 5250DN
If printer is blinking all the LEDs then try to turn off the power switch, wait a few seconds, and then turn it back on and try to print again. If all the LEDs are still blinking, press Go and Job Cancel buttons together and let me know what LEDs stay on.
Jun 23, 2009 | Brother HL 5250DN Laser Printer
Red light flashes on and off after a new drum was put in the Brother HL5250 printer
Try to reset the drum! Open front cover and pres the go botton till al lights are on in orange then releace it and close the cover !
Jun 19, 2009 | Brother HL 5250DN Laser Printer
Yeah, I have the HL-5250DN printer. The light
Hi there -
The reason the drum light keeps flashing is that you have to "reset" the machine after you've installed a new drum. To do this, I believe all you have to do is make sure the printer is on and then push and hold down the "GO" button a few seconds and then the flashing will stop. This will "reset" the printer to recognize you've installed a new drum. I'm going from memory on that, but I believe that's correct. It's a really simple solution. Good luck!
May 15, 2009 | Brother HL 5250DN Laser Printer
All lights on solid, not flashing, wont print
Recommendation: See HL-5240/HL-5250DN USER'S GUIDE: Section (4), Control Panel: LEDs, (light emitting diodes) starting on pg. 44.
Apr 14, 2009 | Brother HL 5250DN Laser Printer
Brother HL5250DN red status light, no printing even with driver reinstall
I had this exact same problem
I just had mine repaired at an authorized Brother service center...It was the "Main PCB Assy". or the "main board. Total cost with tax....$100.
I'll try another brand before I buy Brother again.
Oct 27, 2008 | Brother HL 5250DN Laser Printer
Printer will not print.
Please click on this link: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000070/faq000170_007.html?reg=us&c=us&lang=en&prod=hl5250dn_all
Apr 22, 2008 | Brother HL 5250DN Laser Printer
Brother HL-2040 Laser Printer Logo
635 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
