Configuration error code purple - Computers & Internet
  • Anonymous Mar 31, 2009
    Dear friend;cv1284
    great very very very thanksssssss.....
1. Load the system recovery disk into CD-ROM
2. Press F10 repeatedly at boot screen to load the Recovery Menu
3. Press R for the recover console
4. Select "Advanced Options"
5. Press Alt + D to bring up the command prompt
6. type "cd h:\" to enter the root directory
7. type "dir /w" to view the directory in wide view
8. open the master.log file (or something along those lines), this should bring up a prompt asking you what program to open it with, you should only be able to select notepad.
9. open the file with notepad and when it appears select the File>Open
10. in the file name box type in "C:\hp\bin\configcheck\run.py"
11. once the file opens clear the contents and select save as then save the file as run.p_
12. close the notepad program
13. delete the original file by typing "del C:\hp\bin\configcheck\run.py"
14. reboot system
After a reboot the windows screen might flash a few times and take a little longer to load, be patient and you should be able to continue with the windows set-up without that damned code purple error message.
Posted on Nov 20, 2008
  • 4 Answers
I dont have a recovery cd it is bulit in how do i open the master.log... the folder that im in is c:\minint\system32\
how do i go tp C:\Hp\bin\configcheck\run.py ??? please help
Posted on Apr 14, 2011
System has detected a configuration error
Your windows may not be genuine...
Mar 27, 2013 | Computers & Internet
How to fix code purple error
"code purple"? In what kind of computer?
Dec 24, 2012 | HP Hewlett Packard Pavilion A6200N PC...
The code purple shows up on my computer hp desktop
The following error message opens after the PC is started after a recovery: Your system has detected a configuration error. Please call your Customer Care Center number, located in your Warranty and License information, for technical support. (Code Purple) contact hp tech support...meder's tv service Figure 1: Code Purple error c00372799.jpg
Aug 29, 2012 | HP Computers & Internet
for windows XP:
- Get into C:\hp\bin\CheckConfig\cfgchk.bat
- Rename the file "run.py" to "run.p_" or just delete it. (That's the file that verify the hardware configuration for the OEM version)
- Then reboot!
for vista:
- Get into C:\hp\bin\CheckDMI folder
- Rename the file "CheckDMI.cmd" to "CheckDMI"
or
- Edit the file and change the "0" (zero) value (there is only one in the whole file) for "1" value...which means that the hardware configuration respect the terms of the OEM contract.
- Then reboot!
Sep 19, 2010 | Computers & Internet
Code purple error after system recovery on windows xp how can i fix im a green hand but follow clear instructions very good
There is no way to fix a Code Purple error on an HP computer.
Basically what has happened is that there is a Hard Coded Information "Tattoo" on the motherboard that tells the computer what hardware should be on this machine.  The Hard Code and the hardware do not match.  It is kind of a known fault by HP.
But there is some good news.  No matter long your computer has been out of warranty, this problem IS covered.  The wrong hardware was put into your machine and no matter when this error occurs, HP will support it.
Call HP's tech support and when you speak to a Technical Agent, you let them know you got the Code Purple Error, and they should immediately escalate your call to their Hardware Specialists and set up a service repair where they send you a box and paid shipping label to ship your computer to one of their repair facilities where they will fix it and send it back to you at no cost.  Call 1-800-HP-INVENT.
I used to work for HP tech support and we would see a Code Purple case about once every few months, even on computers 3+ years old.
Mar 26, 2010 | HP PC Desktop
Configuration error on windows xp code purple
if its a code purple error on ur hp computer and its a blue screen error message then the issue is with the motherboard of your computer...and in this case nothing can be done.If your computer is only 4 to 5 years old or less than that call to HP they will replace your free of cost,HP's phone number is 18004746836
Nov 28, 2009 | HP Pavilion m7560n PC Desktop
Unable to reinstall DVD backups after HP SYSTEM RECOVERY failed
Code "purple" means you and your computer are done. It is an unrecoverable error that means you need a new system. However, I have found a couple of postings that claim to know a fix. I can not verify these methods, I do not own a HP or other type of prefab PC (custom is the only way to go). Anyway, here are the links, good luck.
http://h30434.www3.hp.com/psg/board/message?board.id=HardwareDPC&message.id=6115
http://forums.techguy.org/windows-nt-2000-xp/469752-code-purple-configuration-error-hp.html
http://forums.techguy.org/all-other-software/644163-code-purple-advice.html
May 16, 2009 | HP Computers & Internet
I have a code puple on my HP PC a350n..HP says they won't fix it. I thought there was a law suit about this and they Have to fix it. But, I just want to know if ANYONE can.
Code Purple is about the weirdest error you will see reinstalling XP, and it is almost exclusively an HP/Compaq problem.
These companies placed a special system identifier on the motherboard by a process called 'tattooing', and the system recovery routines look for this signature before allowing the install.
It is actually quite easy to bypass this signature check. Here are two entries from an online thread expaining how:
Code Purple can be bypassed by accessing and renaming the file run.py to run.p_. The file is found at c:\hp\bin\configcheck\run.py"
To access the "C:" drive to rename the file:
1. Boot the system with a Win Xp Original Disk.
2. When you have to select "Enter" to reload or "R" for Recovery Console select "R".
3. Select the "H:\minint" Drive to bring up the System
4. At the "H:\minint" prompt, change to the "C:" prompt
5. Change directory to the "C:\hp\bin\configcheck"
6. Rename the file with the command "ren run.py run.p_"
7. Reboot the machine and there should be no "Code Purple" error.
The full thread can be read here:) Note how far it goes back!
http://www.techimo.com/forum/applications-operating-systems/50892-xp-configuration-error-code-purple.html
Please post comments on your progress and results or contact me for more instruction on how to accomplish this.
Jan 04, 2009 | Computers & Internet
Computers & Internet Logo
2,971 people viewed this question
David Payne
David Payne
