Question about JVC Audio Players & Recorders
SOUND CUTS OUT WHEN VOLUME IS PAST 15 - JVC Audio Players & Recorders
    Problem Solver:
  • 47 Answers
Thats to stop you blowing your speakers. you can make your volume louder via the equaliser/surround settings, but you will still not be aloud past the number 15 without it cutting out.
its an EU setting thats on most mp3 players too, so that people wont listen to music too loud, "nanny state".
hope this helps
kev
Posted on Oct 02, 2008
I set the volume to 40. After a little while the volume starts dropping down. If you do not turn the volume back up the volume will eventually go to zero all by it self and turn off the system.
HDMI Audio drop out? - ecoustics.com
www.ecoustics.com > Forum > Home Video Forum > HDTV Forum
Sep 21, 2005 - My Panasonic TH-37PX50U plasma has an audio drop out problemwhen .... The drop out occurs on both TV sound and receiver sound. ... very littlebass effects when playing DVD's through the HDMI cable when I compare it to ....Most noticeable when I turn down the volume control on the set top box (and ...
Dynamic volume problem : Ask Audyssey
https://audyssey.zendesk.com/.../20013893-Dynamic-volume-problem
Apr 8, 2011 - it appens only when dynamic volume is ON (day, evening or midnight) . the audio signal of the TV is on a optical Toslink cable and it ... and so it drops thevolume to make sure the sound will not be too loud. ... April 11, 2011, 12:40 AM .... Setthe audio setting on the receiver to Stereo vice Surround Sound.
How do I stop my surround sound system cutting out? - TV DVD HDMI ...
ask.metafilter.com/.../How-do-I-stop-my-surround-sound-system-cutting...
Jan 21, 2009 - When the volume is at higher levels, all but the center speaker cuts out..... That is why I just turn down the TV's speakers to 0 and listen to things from thereceiver. ... notice that the sound is coming 40ms later or earlier than the video). ...system), and adjust the A-V delay on the receiver until the audio lag is ...
Jan 06, 2016 | Audio Players & Recorders
Reciever works fine until i turn tha volume past
sounds like you have a bad speaker hooked up. This symptom if very common if a speaker is shorted
Aug 27, 2014 | Audio Players & Recorders
Having a problem in turning down the volume both on the unit itself & the remote, can increase the volume both ways but have to wait 15 plus before the remote will turn down the volume. The control on...
The volume control in this unit is most likely an Encoder and these have a nasty habit of getting dirty inside and false reading back to the computer that runs the receiver. In the past , I've had good results opening up the units and spraying what's called De-Oxit D5 into that volume control and rotating the thing a couple dozen times. . De-Oxit can be found on Amazon or Radio Shack
May 26, 2014 | Marantz SR4001
Hi, I have a SR92 which intermittantly cuts out on the right side only. If I quickly flick the volume knob up past about a third the speaker kicks back to life. Doesn't seem to be a pattern to it and I...
Is it on all audio sources or only certain ones? Have you swapped the speakers Left-to-Right to isolate the speaker from the signal chain as a cause?
If it's only an analog source doing it I would suspect a bad audio cable or a switch contact somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Mar 15, 2011 | Marantz SR-92 Mark II Receiver
My sr 870 (marantz is probably about 7 - 8 years old, and have noticed that this issue with loud sounds is getting worse over the years, I have upgradedmy cabling , to the speakers, have upgradedall the...
Something is tripping the safety in the unit.
I'd be checking the output transistors or hybrid chip, and take a good look at the electrolytic capacitors and make sure none of them are leaking or bulging at the top.
Look for signs of heat wear on resistors especially near the output stages.
You may simply have to take it in for service if you aren't electronics savvy.
Mar 01, 2011 | Audio Players & Recorders
I have a Yamaha Reciver HTR 5940 When i turn on the reciver it cuts right off. I checked all plugs speakers etc.. It only stays on like 2 seconds and cuts right off Can you help me
As long as it doesn't blow fuses, you have a cold solder connection on the circuit board. It developed from past heating of the components due to high current - possibly from having the volume turned up too high or a mismatch of speaker impedance. Check the circuit board for the cold connection.
Jan 06, 2011 | Audio Players & Recorders
Overload
Have you checked your wiring connections? Wires could possibly be touching each other making it short out and giving you that "Overload". If not that then I would say it could possibly be a fuse that has gone bad inside. ??? Just some suggestions. The reason I say that it could be the wiring is because when I hook up a system and the wires accidently touch each other it overloads the system past a certain volume. Again I would check my wires first and move on from there.
Dan Colton, Ca
Sep 24, 2008 | Pioneer SX-205 Receiver
Speakers stopped working.
More than likely you have blown outputs, as the sound you hear when you touch the leads to the terminals is the DC offset of the power supply being routed through your speakers...accordianman
Jun 09, 2008 | Aiwa AV-DV75
Sound cuts out above medium volume
This is usually a heat problem. The more volume you ask of an amplifier, the greater the current (electrical) draw, the more current draw the more heat is generated. This is true of ALL electrical/electronic items.
As you describe it, the fuse is not blowing (stays on) so my choice would be a chip heating up and then shutting down. If that's the case (99% probabilty). The only other reason would be if the unit has an overload switch inside, it would react this way. Either way it's still a heat problem and truthfully nothing you can do.
Try this first though:
Is the Denon dusty inside? Dust can create 2 problems-heat and static electricity. Look through any vents you can get at. If the area around the unit is dusty chances are it is dusty inside. The best way to get the dust out is using a can of compressed air unless of course your vacum cleaner has a "blow" port.
In my shop, when heat is supected I use a can of freon th cool down chips, etc to isolate the component. This is not for a "layman" and strongly suggest bringing it into a shop.
One more question. If the unit using a knob for volume-do you hear a scrating noise when you hit the no volume zone? What happens if you go past the point quickly? I ask because sometimes there can be a bad spot on the volume. The volume knob is basically a circular resistor, whether digital or analog so this is a vague possibility (the other 1%).
If you e-mail me the serial number I can check with the Denon engineering department to see if there are any design problems as it may be a covered repair. It never hurts to ask.
Sorry to be the bearer of bad news
Jeff
Jan 09, 2008 | Denon AVR-2803 Receiver
169 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
