Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side
Hi, my G.E. side by side refrigerator (10 years old) has an electrical burned smell and the freezer is losing cold- so far the fridge is ok. Other than that there is nothing unusual. thanks
    Director Badge:
    Uploaded 100 video answers.
  • GE Master
  • 488 Answers
check your main board (located on the back wall of the fridge). pull board out and check back of it, usually one relay legs burns out.
Posted on Oct 16, 2014
  • 943 Answers
Hi. did you clean the coils at the back. remove back panel, clean all coils .because a dirty condenser will cause this
Posted on Oct 06, 2008
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
My GE Profile PSCS5RGXSS refrigerator is heating. The freezer section is still freezing. The unit is less than 2 years old.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 10, 2011 | General Electric Profile PSCS5RGXSS...
HAVE A GE PROFILE SIDE-BY-SIDE REFRIGERATOR ABOUT 10 YEARS OLD THAT NEEDS A GARAGE REFRIGERATOR KIT INSTALLED. IN MY UNHEATED GARAGE AND NOT WORKING IN FREEZING TEMPERATURES. TRIED A 100w LIGHTBULB...
You need to put a heat source in the fridge compartment near the fridge thermostat. Try putting a lower wattage bulb (40w) into the fridge compartment. Or even try this, take the door switch out of the fridge and short the two leads together. Tape the exposed ends with electrical tape and that should provide enough heat to keep your compressor on long enough to keep the freezer cold. Just remember to put the switch back in in the spring and summer months or you will have a real high electrical bill. Hope this helps you.
Dec 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I smell something burning like electrical, what could it be,I unplugged the fridge for now?
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 18, 2010 | GE GDS20SBS Stainless Steel Bottom Freezer...
My G.E Adora refrigerator freezer is not cold enough. Ice cream is melting and refrigerator is at too cold and is freezing food, It is only 5 years old. It is a side by side. Help!
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 18, 2010 | GE Adora (DSF25KGTBG) Side by Side...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
I am having a problem with a GE GSH22JSRE refrigerator. Serial Number ZH203908 Over 5 day period it started to get warmer and warmer until the freezer did not freeze and food spoiled. I read on line as...
do you have any frost on the wall of the freezer? and do you still have your old control board? if yes check in the back of the board if there are any burned connections black connections, and feel free to put your nose on it and smell for a burning smell i dont know how much will it smell now but that is the easiest way to check the board ge side by side fridges have the control board problem which you replaced and the defrost heater if you have a lot frost on the back freezer wall you need a new dual defrost heater if you dont check the new board you put in for burning  if thats ok too check your compressor if its really really hot if it is try cooling it down with some paper towels and cold water put about 5 so so wet towels on top of compressor and 5 on bottom and use a couple to wipe down the middle of the compressor
if you got any questoins feel free to ask  good luck
Jun 08, 2009 | GE GSH22JSRSS Stainless Steel Side by Side...
Maytag model (MTB1950GR) tripped off the power switch and smell
Hi, It sounds like the relay onyour compressor. They will smell when it goes bad. Remove the rear panel on the back of the refrigerator and see if the smell is around the compressor.
Please let me know If I can assist you further.
Vic
May 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile side by side 'fridge
Evaporator fan motor and main Pcb , the fan motor goes faulty and then burns out a resistor on the main pcb at the back.
Aug 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
127 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
