Question about HP LaserJet 4250n Printer
HP LASERJET 4250 DUPLEX ISSUE
HI,
I HAVE A HP 4250 THAT ONLY DUPLEXES ONE SIDE AND THEN STOPS. WE CHANGED THE DUPLEXER AND GOT THE SAME ISSUE. THEN WE UPDATED THE FIRMWARE AND THAT DID NOT CORRECT THE ISSUE EITHER. CAN SOMEONE TELL ME WHAT WOULD BE MY NEXT STEP?
THANKS
  • KRISTINE26 Oct 02, 2008
    THANKS FOR TRYING; HOWEVER THE HP 4250 DOES NOT HAVE THE HIDDEN BIN LIKE THE 2100,2200,2300,2400 MODELS DO. I STILL NEED HELP!! THANKS AGAIN FOR TRYING. =0)
  • 68 Answers
Only problem ive had with the earlier model not doing duplex was a sheet of paper in the duplexer bin . This is hard to find but if you pull out the paper tray and look in the space where the tray goes up above theres a lever which you can push and it releases the hidden duplex bin which stores the paper at half way through the double pass and if there is any paper in there then the printer will not duplex.
Posted on Oct 02, 2008
Kristine facing the printer on the left side in the back, remove the cover next to the fuser door and look to see in the small square on left side and see if there is a white lever inside the hole. if its missing then the duplexer will not work.
Posted on Nov 11, 2011
I had the same issue and I just followed the solution about the tray leveler posted on http://www.fixya.com/support/t482312-laserjet_4250_not_dupexing and it worked.
Posted on Oct 14, 2008
Error code 69.00
A printer error occurred where X is
detailed below.
0 The duplex mechanism failed
1 The duplex side-adjust failed
________________________________
1 Turn off the printer, and then
turn the printer on to
continue.
2 Reseat the duplexer (make
sure that the printer is turned
off).
3 Perform a service test. See
page 213.
4 Perform a paper-path test.
See page 213.
5 If the error persists, replace
the duplexer (make sure tha
Apr 22, 2013 | HP LaserJet 9050 Printer
Hi I hv installed hp laser jet 1320 printer in my system but print on both side option is not shown in printer property
Do you have the 1320D or just a 1320. Only the D version will duplex automatically. The base version requires you to manually duplex. If you are sure you have the duplex version, then check the settings in the print driver and make sure it shows that the duplex option is installed. The driver often defaults to no duplexer.
Jul 05, 2011 | HP LaserJet 1320 Printer
Auto Duplex Unit Not Working Model: HP LaserJet 2420dn I am using Windows XP and installed "HP LaserJet 2420 PCL 5e" driver. It is connected via internet and when I try to print double...
You need to go into the print driver on your Windows machine and go to the Device settings tab. One of the settings is to set whether the unit has a duplexer or not. It does not always set automatically.
Jun 23, 2011 | HP LaserJet 2420dn Printer
I have a HP Color Laserjet 3600DN. The initial problem was no duplex printing. It wasn't pulling the paper back down. I replaced the duplex transfer belt. No luck. I then replaced the duplex reverse...
I've worked on these printers for years and I never heard of a "duplex transfer belt".
Sounds like you broke a wire or missed plugging in a connector.
Probably a bad Duplex Feed Drive assembly or bad DC Controller.
Jun 01, 2011 | HP LaserJet 5000gn Printer
MY PRINTER hp laserget 4250 dtn is displaying 57.4 error when I turned it on, what can I do? I am ofetn requested to suitch off and then to switch on but it fails to mark " Ready"
57.4 Main fan error
Hi I hope this will help
The text come from the hp manual
good luck Ian
Q2431-90912 Chapter 7 Troubleshooting 287
57.X
PRINTER ERROR
To continue turn off then on
or
57.3
EP FAN FAILURE
or
57.4
MAIN FAN FAILURE
A printer fan is not functioning.
X Description
3 EP cartridge fan, right side
(LJ 4300 only)
4 Main cooling fan, left side
Turn the printer off and then on.
57.3 Cartridge fan error (F2)
1. Reconnect the connector
between the fan and the
DC controller PCA
(location J78).
2. Replace the fan. See "Cooling
fan (right side;
HP LaserJet 4300 series
printer only)" on page 170.
3. Replace the
DC controller PCA. See
"DC controller PCA" on
page 181.
57.4 Main fan error (F1)
power supply.
2. Verify that the ribbon cables
are fully seated in the
connectors on the
DC controller PCA.
3. Replace the fan. See "Main
cooling fan (left side)" on
page 168.
4. Replace the power supply.
See "Power supply" on
page 188.
5. Replace the
page 181.
57.7
DUPLEX FAN FAILURE
The cooling fan in the optional
duplexer is not functioning.
1. Turn the printer off and then
on.
2. Replace the duplexer.
Mar 25, 2011 | HP LaserJet 4250dtn Printer
HP LaserJet 4250 PCL 6 - Cannot get Duplex disabled
Try turning Duplex off at the printer. See if that does what you want.
Jun 23, 2010 | HP LaserJet 4250dtn Printer
How to fit Duplexer unit HP 4250
Look at the back of the printer. Right above the back of the paper tray, there should be a piece of plastic that pulls out.. The duplexer slides into that gaping hole.
Oct 28, 2009 | HP LaserJet 4250tn Printer
How to enable duplex printing in hp laserjet 4250
This unit needs to have a duplex unit installed if you want to duplex. If the back of the unit is "flat" you do not have a duplexer installed.
the duplex unit slides into the back of the printer between the back door and the paper tray. when installed you will have a bulge on the back of the printer about 7 inches tall and the width of the printer that sticks out about 5 inches.
after installing the dupelxer you may need to enable it in the print driver under properties then the advanced tab you should see a spot for advanced settings.
Jun 07, 2009 | HP LaserJet 4250n Printer
Laserjet 4250 not dupexing
Had this same issue on my 4250dtn. The solution in my case was that both paper trays were set to "custom". This is a small lever on the right side toward the back of the paper tray. Even HP was stumped on this. Hope this helps.
Apr 01, 2008 | HP LaserJet 4250n Printer
HP LaserJet 4250n Printer Logo
2,015 people viewed this question
Seeker5211
Seeker5211
