I connect my two vcrs and i press record but then when i push play on the recored tape its just black
  • 68 Answers
Are you connecting via scart? If so the VCR doing the recording has to be set to Line 1 or AV1 this can be done on the remote by selecting the source button or using the channel up and down buttons in the display the channels 1,2,3 etc will go to L1 or AV1 you should then be cable to copy assuming the video is copyright free if not Macrovision protection will prevent copying.
Posted on Oct 02, 2008
How can I make sure my Samsung SSC-1280 & SSC17WEB are recording? how can I view the recordings?
Regular rca cables should work. Connect from "video out" on the vcr to your monitor.
Oct 17, 2014 | Televison & Video
My VCR won't work when I push play. It shows the blue screen just goes black when I push play.
It sounds like it is working, and you just weren't recording a signal. Try playing a prerecorded tape.
May 31, 2014 | Televison & Video
Some good news v c r will now play , after playing a head cleaning tape but will not recored could this because the new goodmans digital box has takenover control because i can not get any stations with...
You don't specify what make the VCR is! Could it be an analogue machine? And if you are in the UK all the analogue stations have been switched off! So there's no signal! For the VCR to operate you need to connect it to a second digital box and record the box signal via a scart lead with the video set to AV setting. Some digital boxes have two tuners and will put out a signal for both the TV and VCR.
Jan 01, 2013 | Televison & Video
Recording
I'm going to venture a guess that what might have happened is you changed the mode of recording. VCRs record in either short play, or long play, or even super long play. As the length of playtime goes up, the quality goes down, because for short play, a 6 hr tape will record only two, whereas a 12 hour tape will record four hours. More information is stored on the tape, so the quality of picture and sound increase, but a longer movie could be cut off. You can adjust the play-length with the sp/slp buttons on your remote control.
Jul 19, 2009 | Toshiba W522 VHS VCR
How can I record TV show? What buttons do I push?
Well my friend, you have many variables that can cause this issue. Here is a list.
  1. Check the tape record prevention tab to see if it is not missing that will cause it NOT to let you record. Put a piece of scotch tape over it if you wish to use that tape.
  2. Make sure it plays back. If it does not play back, it might not record.
  3. Turn the TV on, look for Audio and "Video Out" and connect it to the INPUT Video Out and Audio Out. You cannot use the TV to power the VCR. The power plug must be connected to the wall outlet.
One of these should solve your issue.
E
Mar 02, 2009 | GE Televison & Video
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
Wont Record
Usually when a tape starts to play automatically this means that the tab on the back of tape has been removed to stop others recording over it check the tab little black tab in a recess on back edge of tape if this is missing you can put a bit of sellotape over the whole to blank it off this will tell the video tape is ok to record on.
However if the tab is still in place the try putting a small bit of tape over it also to raise the clearence slightly then put back in video and try to record if this still dont work then the mechanism that detects the tab has failed these can be replace but usuall parts are hard to come by now as they no longer make vcrs any more but let me know ok i can assist you further just check tabs in place even try raising it with a bit of card stuck over tab with tape this might make the tab switch work if it has wonr down abit let me know ok.
As you look form back of tape the tab is bottom left hand corner check its flush with the tape if not use sellotape to repair let me know the outcome ok
Feb 15, 2008 | Televison & Video
I have a Sony SLV-EZ717
It sounds like the taped program was recorded on a different speed. The other VCR that you are playing the taped program may not have the speed needed to play it correctly.
Next time when you record a program try to make sure you use a speed that will be compatible on both VCRs.
For example a tape that last 120 minutes, using the different speeds will give the following recording times.
SP means "Standard Play" >>>> 2 hours
LP means " Long Play" >>>>> 4 hours
ELP means " Extra Long Play" 8 hours
Older VCRs have all the 3 speeds but newer ones only have SP and ELP.
Hope this helps.
Jan 25, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
VCR RECORDING
make sure it has a signal going into it and that you can see it on your TV (put the VCR in vcr mode by pushing the vcr/tv button) , put in a tape and hit the record button. (some vcrs you push the record and play buttons at the same time)
Dec 31, 2007 | Televison & Video
Panasonic VCR pv-7451: No sound in "normal" mode
Are these prerecorded tapes or ones that you recently recorded? Or are they all normal audio tapes?? Try a pre recored and turn off the HI fi audio and thats an easy thing to do as put it in normal and mono.. Get back to us so we can assit. Not enough info as could be 100 things.
Jun 28, 2006 | Panasonic PV-7451 VHS VCR
Televison & Video Logo
Top Televison & Video Experts
