Question about Panasonic Car Audio & Video
I have a Panasonic RD525LEN and one of the back lights had gone on the right left hand side. Can these be replaced?
  • 1462 Answers
SOURCE: Maytag UXT5230AD Kitchen Hood - Right Hand Light Cycles On and Off
probaby just the bulb holder
Posted on Mar 20, 2007
  • 4 Answers
SOURCE: Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Posted on Jul 17, 2008
SOURCE: panasonic th37px60
Just taken mine in for repair and was told this. "After checks to Switching and Data flow to PDP, Suspect the Plasma display panel to be at fault
which also may well have caused damage to the buffer and logic boards."
I am presently trying to get currys to replace it as it 18 months old.
Forgot to say was quoted £1200 to fix!!!!
Posted on Aug 01, 2008
SOURCE: black strip down the right hand side on my viera plasma
Hello
black strip down the right side its about 2 inches wide there are also red and green flashing lights that is defective shorted capacitor at power inverter board section that was 300uf 200volts.
Angel
Thanks...
Posted on Aug 02, 2009
  • 18 Answers
SOURCE: Trailer lights have two wire out of each fixture
One wire is for the brake/directional filament and the other wire is for the tail light. The fixture should be grounded when it is attached to the bracket. To test which is which (the brown wire is USUALLY the ail light) make sure the fixture is grounded and touch a hot wire to each of the wires coming from the fixture. Watch to see which wire lights up the brighter filament and this is the brake/directional light. The dimmer filament if the tail light. Brakes lights and directional lights are both the same filament. Wen the brakes are applied, both lights are activated. When a direction light is turned on, it simply flashes the brake light filament.
Posted on Apr 04, 2010
Radio lights up but why no audio?
if the speakers are 10 years or older they might need replacing
Feb 01, 2016 | Cars & Trucks
Only the right side of my Panasonic Plasma TV (TC-P50UT50) is displaying. The left is is black with some white flickering lights. Sound and video on the right side are perfect.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Oct 01, 2015 | Panasonic Viera 50" Class 1080p Full HD 3D...
The entire left-hand side of my TV is black...
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 16, 2014 | Televison & Video
Pedal slipping
Chances are the right hand clutch sprocket is failing. You can replace just the right hand side or the whole drive hub assembly. I usually find if the right hand side is gone, the left hand side is not too far behind. I will provide a link for the product I am referencing. Drive Hub for Stairmaster Steppers 4000PT 4400CL 4600CL 4400PT 4600PT...
Feb 26, 2014 | Stairmaster 4600 Cl Cordless Freeclimber
2 cylinders not running
i would actually replace the caps and leads on side not working, a bad connection may still spark when not under pressure, then test coil before i think about cdi
Feb 17, 2013 | Motorcycles
Right hand brake light not working vp commodore.bulb has been replaced but still no go
I assume the left hand brake light works.
First check that you have replaced it with the correct bulb. Make sure it is the same as the left hand brake light bulb.
Sounds silly but different bulbs will fit the same socket, but not work.
Make sure no one will push the brake pedal and see that contacts are clean and there is spring pressure behind the contact in the socket. If all the above is okay then you probably have a wiring problem.
Either the earth wire, usually black, is damaged or not connected to earth (body work) .
Or the power wire from left hand side light is cut or damaged. Check the colour of the wire on the left hand brake light. It will be the same for the right side.
If you have a trailer plug follow the wire from it back to where it connects to the cars original wiring. The problem could be at that connection.
Good luck
Feb 17, 2013 | Cars & Trucks
Panasonic plasma TH-42pz700 has left hand side of screen distorted
The set uses two boards to drive the screen --one for each half or side.
Different names are used like sustain or in LCD sets inverter.
Apr 02, 2012 | Panasonic Viera TH-42PX80U Plasma TV
My screen has gone darker , Where is the contruct, light dark controll
It's usually on the up,down,left,right arrow keys that are on the front right hand side of the keyboard.They have blue sun type symbols on them. You press and hold the Fn key, that's on the front left hand side, and then press one of the arrow keys to lighten or darken the screen
Oct 16, 2009 | Acer Aspire 5630 Notebook
Panasonic microwave...
Without HV test equipment it is quite difficult to determine if it is the magnetron or inverter.
5 years is a little short for magnetron failure but it appears that this is about all you can expect these days from a magnetron - the best I have seen was 11 years. I have not seen an inverter failure as yet (although I am not a full time repair man). The main reason I suspect it is the magnetron is the short time period from start to stop - it is typical of magnetron failure in Panasonic microwaves.
As regards door hinge side, that is one of the great unknowns. I suspect it comes from most people being right handed but even refrigerators could be specified as right/left hand hinged originally and now can be changed by customers.
Nov 08, 2008 | Panasonic NN-T990SA Microwave Oven
Car Audio & Video Logo
127 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
