Question about Philips Magnavox DVD/VCR Dual Player
Disc stuck i used my satlite remote to be used for my dvd/vcr player. But when i tried to use it it does not work . so i tried to reuse my old remote for the player and it will only work with the vcr not the dvd player. I have a disc stuck in the player. I would like to just go back to my old remote to be used for both the vcr/dvd player. how do i reset the remote back to the original setting. i have the magnavox dvd/vcr Model# MWD2205. i wish now i didn't try to use my satlite remote . can someone please help with this problem.
  • 68 Answers
Usually to reset remote remove batteries and short the + and - terminals together or leave batteries out for about ten minutes this should get rid off any programmed codes.
Posted on Oct 02, 2008
How to get the progressive scan mode off the dvd
try this first turn on the dvd now check on the disc tray there is no disc on it now push the stop button for ten seconds good luck
Feb 02, 2010 | Zenith XBV442 DVD Player/VCR
My coby-514 dvd won't open up when the open/close
disc is stuck, remove cover screws and carefully remove the disc, do not force the unit, once the disc is out use the remote to close the unit, then use remote to open and use a different disc press play and hopefully it will work, try to avoid not using the remote for all functions,including open-close. do not push tray in manually.
Dec 10, 2009 | Coby DVD-514 DVD Player
Won't work with the same kind of discs i've used before
I not sure as to which type of Discs that you are refering to (ie DVD+R or DVD+RW). This player will only recognize 4x (max) DVD+RW and 8x (max) DVR+R discs. If the DVD+R Disc is 16x, the DVD recorder will not recognize it once you start to record. The player will read the blank Disc and give the impression that it will record on it. I have noticed that when a 16x speed Disc is in the Drive, The recordable hours for the disc seems to double. The normal 6 Hour recording length comes up as 12 Hours when you hit the info button. Since the 8x Speed (max) discs are not available any longer, I found it best to use the DVD+RW 4x Discs and make it compatible. I then copy the compatible DVD+RW disc to a 16X DVD+R disc using my computer DVD burner. The DVD+RW disc can then be erased so that it can be reused.
Nov 23, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
DVD IS NOT READIGN DISC
buy new disc ray and disable the old one
Jan 10, 2009 | Toshiba SD-V392 DVD Player/VCR
Problem with old TV
The channel is almost always 3 or 4. Be sure you have the VCR connections correct. Just hook up the TV and VCR alone to start with and try both the VCR and DVD. Also the output of the VCR should show a blue screen.
Dec 17, 2008 | Memorex MT1194 19" TV
Dvd player
you must eject the tape in order for the disc player to work
Mar 30, 2008 | Sanyo DVW-7200 DVD/VCR
Safe
There should be a button on your remote labeled "safe." Press that, and it will turn the safe mode off. It's on the second row from the bottom on my remote.
Jul 15, 2007 | Sanyo DVW-6100 DVD Player/VCR
GoldStar DVD/VCR-progressive scan mode problem...``
Remove any DVDs from the disc player. You should be in Blue Screen mode on the TV...If it says "Progressive Scan Mode" ....make sure there is no DVD in it...close the disc changer and push and hold the "Stop" Button on the player, not the remote, for 5 seconds or longer. This has been proven to work every time!!!
Apr 10, 2007 | Goldstar GBV241 DVD Player/VCR
Insignia DVD Player
Try hitting the "Lock" button on the remote. That solved the problem for us.
Dec 03, 2006 | Insignia IS-DVD1001 DVD Recorder/VCR
Philips Magnavox DVD/VCR Dual Player Logo
167 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
