Question about Samsung SlimFit TX-S2783 TV
ANTENNA TERMINALS I HAVE TO REPLACE THE ANTENNA TERMINALS IN THE BACK OF THE TV. THE CABLE CONNECTION HAS BROKE OFF. HOW DIFFICULT IS IT TO REPLACE THE ANTENNA TERMINALS
    Champion:
  • 252 Answers
You need to take off the antenna so that can solder the antenna terminal inside the tuner.
Posted on Oct 18, 2008
Looking for cable with analog on one end and coax on other end
Since you're going to be soldering anyway, these are available on ebay. Just keep your wire as short as reasonable.
The other way is just grab a short f-type to f-type coax (standard TV coax cable) , and cut off one end. Then unweave the shield and solder into a bundle with a short wire to the TV antenna ground.
Sep 11, 2016 | Westinghouse Televison & Video
The antenna connection broke off
If the cracked portion is on the cable then you need to get the cable recrimpted with another connector. You can do this yourself but this needs a special tool. Ask your cable provider to get the proper connector reapplied.
Dec 28, 2013 | Sanyo DP32649 31.5 in. TV
Replace motorized antenna with a standard antenna on a 2004 Sonata
Antennas come with the cable
Remove the broken one first ,then
all your questions will be answered
Feb 08, 2013 | Hyundai Motor 2004 Sonata
My cord on my rca tv pronge broke off can i fix it
Would not be difficult I assume you mean antenna plug? Radio Shack would have the fitting but you would likely have to pull the back cover off to cut and replace would need soldering.
Jan 10, 2013 | Televison & Video
Antenna in port connection broke off the tv
You can purchase the whole main pcb for the tv, but this would be costly with arts and abor. You could order just the part you broke called the Tuner but, you would need to know how to solder to take off the old and put on the new one which is time consuming. The cheapest and easiest way is to if you do not have cable or sattelite and just have an over the air antenna, get you a converter bx with the composite outputs "red,yellow,white" and connect that to your tv. Thats the cheapest and simplest work-around fix. Good luck!
Jun 29, 2012 | Sylvania Televison & Video
I believe I broke the antenna connection on my Mintek TV.
Definitively you broke the connector. Look in the internet the web site of Mintek. But since for a technician is not a big deal to fix, you can take that TV to ANY repair service, because is very easy to do it. I strongly recommend that.
Nov 20, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
RCA D52W17 ANTENNA/CABLE ANALOG INPUT
are you looking for this part?
http://www.partstore.com/Part/Thomson/RCA/264658/New.aspx?ModelMfgName=Thomson&ModelBrandName=RCA&ModelNumber=D52W17BYX1
if so, just make sure your model number is on the listed devices.
Nov 11, 2008 | RCA D52W23 52" HDTV CRT TV
Need an antenna block for a Sanyo DS25390
Was the block a cube about 1" ? You should be able to salvage one from an old tv. This block is used to isolate the antenna/cable from the "hot" chassis inside your tv. If you should find a used block ,make sure it does this. If you get one that gives you a direct connection to the chassis, your antenna/cable connector would give you a shock and probably burn out something in your tv when the cable is connected. Some of the Sanyo's have this connector made on to the tuner. If this is the case you'd have to either put a new coax connector in the tuner OR replace the tuner. Stargazer
Jan 23, 2007 | Sanyo DS25390 TV
Samsung SlimFit TX-S2783 TV Logo
205 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
