First I would like to thank you guys for your help, I have not electronics for quite some time until my daughters LCD TV went out and I found this sight and was able to fix it with no problems, so thank you!! I have an Elan 12 channel 100 watt per channel amplifier of which 10 channels are not working. I have the amp opened up but cannot visably see any burnt componets or any "popped Caps". Please help, Thank you.
  • 1 more comment
  • jchprime Oct 02, 2008
    There are no model #'s on the amp itself, I'll see if I can locate the owners manual.It started with one channel going out then my nephew played some very bassy music and nine addition went out
    Found the model, it is the Elan D series, D1200 12 Channel Digital Power Amplifier. thank you for you help.
  • jchprime Oct 06, 2008
    Elan D1200 with 10 channels out. i have the referenced amplifier, one channel went out at first, then my nephew played some very bassy music and 9 more channels went out at once. There are ten channels out currently, not muted. What are some probable fixes? Thanks,
  • 1,512 Answers
I suspect that each of the failed channels operation is limited by either a DC condition to the supply voltages for that channel(may be blown fusibles) a visual check of any fuses is the very first step. If you have a multi meter, this is the first place to start you tests. Checking voltages about the output stages, comparing the two channels that work, to the ones that don't. This may not be easily apparent as there are many channels down. Trace back the speaker output connections for the working chanels to determine where you have good voltages present. There will be much symmetry in the components for the other channels, with a bit of careful measuring, you should be able to locate if missing DC voltages to those stages are causing the problems.
If the DC conditions to each channel look ok, then the next step involves a good working knowledge of power amp stages and speaker protection circuitry. There may be a power output stage failure to each of the missing channels(likely if the amp has had teenager abuse), or the input sourcing/switxching/preamp stages may have failed(not so closely related to the abuse) Purchasing the service manual may be a good option if you are able to follow a schematic diagram, if you are not confident here, then taking the unit to an audio repair man will become your best option. I am happy to answer questions about it for you and render advice if there is something that we can put a point on in the diagnosis. Cheers.
regards
robotek
Posted on Oct 08, 2008
  • Graeme Ross
    Graeme Ross Oct 08, 2008
    It is also posible that the unit has an electronic audio switching IC in the input signal sourcing/matrix circuit of the amp. If there has been excessive audio levels feed into the input stages of the amp,this device may have failed, would explain the problem with the channels random failure as it is one device and could effect all channels.
    It wasnt a bass guitar he hooked up to it was it? :) That could fry it
    Brigadier General:
  • 6,966 Answers
With the indulgence of the others and if I may add...
To my knowledge, it would be improbable that a number of op-amps being low current, would blow simultaneously. In most designs, the op-amps would be 2 or 4 in 1 package and therefore a single failure is multiplied a number of times. It would be more to my thinking that the issue is brought about by:
  • B+ supply to the pre-amp circuitry (likely). Probably a dropping resistor or even a zener diode;
  • logic controller (most likely). Trigger in/out, digital gain control ; and of course
  • the op-amps themselves could be faulty as Abrsvcs has pointed out.
Incidentally, in the absence of a schematic diagram, you could try checking out the spec sheets of the component ICs (op-amps) to give you at least the recommended working voltages.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Scholar:
  • 116 Answers
Try cold soldering on the board of electronics components located in the internal area of the amplifier as you stated that you cannot see any burned components in the device.so cold soldering is the best solution for this type of problem as some of the components gets loosed in the board as the glue gets old in the board.
Posted on Oct 06, 2008
  • 4,234 Answers
The typical failure here is with an opamp chip that is common in many designs. I don't know your specific model, but if you open it up you will most likely see a series of 8 pins ICs that will be either 4558, 4565 or 4570 (as indicated by the markings on the ICs). These are likely blown. Finding which one(s) will be a bit tricky from a remote location, but we can try. Is there any way to post a picture of the boards inside the unit?
Thanks,
Dan
  • ABRsvcs Oct 06, 2008
    I forgot to add:
    In all likellyhood, the first channel smoked the opamp chip for that channel. In the second case, the opamp that buffers the main bus was weakened by the first failure and finally gave up which you saw as channels 2-10 going out. You most likely only have a couple of ICs defective.
    Dan
  • 19,396 Answers
Check first that you are operating the Amp properly, and that the channels are not muted.
Then you will need to test components on board following the diagrams on repair manual.
I will see if I can find any diagram for your model.
Posted on Oct 02, 2008
  • 1 more comment
  • Ginko
    Ginko Oct 02, 2008
    I forgot to mention, I need the details on your model to find the service manual.
    Without a service manual, I can give you only generic hints.
  • Ginko
    Ginko Oct 02, 2008
    If this happened after playing loud music , then probably you have blown the final amp circuit. On transistor or valve amps you blew the valve or the power transistors.
    Your unit has probably an IC as power amplifier for each channel , one or more of this had blown. You test the pico fuse, or the resistor at the base of the amp IC for continuity to find out if the IC is gone.
    Procedure to troubleshoot the problem depend on the specific model.
    If you want to fix it you will probably need the service manual, so that you know what values you must get in return from component, and what diagrams to follow to test an area of the circuit.
    Try to find the model.
  • Ginko
    Ginko Oct 03, 2008
    Hi , unfortunately the schematichs for the D1200 are not available for free download. You can get the D 1200 service manual for $7.50 here
    Do not buy the schematics, buy the complete service manual, it will guide step by sted throught testing the Amp final and replace the defective component.
How do I find driver for my speakers. Disc not available. They stopped working after MS update.
My daughter had the same trouble with her Dell computer. The guy who was reloading Windows found the additional drivers on the Dell website.
The Dell recovery disc supplied with a new machine already contain those drivers.
Feb 22, 2016 | Dell Audio Players & Recorders
The power outage went out yesterday and my tv wont turn on
Most likely it is capacitors on the dm board that have gone bad. This is a fairly common problem and has been addressed on fixya many times. If you know someone who is good with soldering and technically incline or even an honest electronics guy then the repair is quite cheap. If you have any other questions please let me know. if its not the capacitors on the DM supply then its a problem with the whole DM assembly that part usually is around 300$. So you may want to consider purchasing a new tv. Trying the 7 caps on the dm supply board shouldn't cost much if it takes anything more then that. I would sell the tv on craigslist or ebay and recoup as much as you can towards your next tv.
thank you,
lee
Thank you,
lee
Apr 01, 2010 | Mitsubishi WS-55511 55" Rear Projection...
No sound after a year. TV turns on by itself
I used your site to look up a problem awhile back and was helped by a guy who went by, Les Price (missiontracetv@msn.com).
I purchased a Sharp LC-26D4U LCD television and after about 16 month, the sound went on the TV. I could not get anything but popping noises out of the speakers. I hooked the TV up to a stereo and the sound worked only while using the stereo speaker from the stereo, still nothing from the TV speakers.
I searched this problem on your web site and saw a posting in which this Les Price (missiontracetv@msn.com) posted a fix. He stated this unit had a chronic problem with the insulator material used on the heat sink on the ic’s on the AV bd. He stated the unit had to be disassembled and the av bd removed. He stated the insulation on the ic 2502 breaks down and must be cleaned off and that a new insulator, part # PSPAZA663WJKZ must be ordered and used as the insulator pad. He stated there was a Sharp Technical bulletin LCDTV-194, which explained the problem and suggested this fix.
I Goggled the suggested part #, PSPAZA663WJKZ finding and ordering the part from www.electronics-storefront.com. I got a copy of the service bulletin, which had pictures and instructions on the repair.
On 25-Jan-09, I disassembled the TV, removing the back, a metal mount under the plastic back, and three circuit boards, locating the heat sink on the back of the AV board. I left the black sticky residue on the heat sink as the service bulletin suggested and installed the new insulator pad as shown on the service bulletin. I put the TV back together and found the TV volume to work again. I could not believe it worked.
Taking the TV apart made me a little nervous. I am not a repairman, however I do like to, “Tinker” with stuff. There were a lot of screws and wires to keep track of and a little tricky to put back together. If I had to do it again, I would either video tape the disassembly to make sure I replaced everything back the way it was, or at least take a few photos while disassembling.
I just wanted to say thanks for your web site and thanks to Les Price for his help. You both saved me some cash.
I have the same problem with the TV occasionally turning itself on but it only happens once in awhile. Still have not found out why this happens.
Dec 17, 2008 | Sharp LC-26D4U 26 in. LCD Television
Philips hdtv flatscreen for a spa
I was searching some for help with my GTW-L17M103. It too went black. I could not turn it off (power light was green). Thank goodness, I found your solution, except I need a little more help. I opened my monitor, removed the metal cover and found F3. I see what my daughter refers to a little "white bridge" with the letters FA2 or EA2. My questions are: Is this the correct part that needs to be replaced (2 amp fuse)? Where can I buy it? What instrument or tool do I need to replace the part? You mentioned you could not find a surface mount (not sure what that is), therefore you "piggybacked a 2 amp pico fuse on the blown one and it is working great". Where can I get a 2 amp pico fuse? I'm not a hardware guy but I'm not afraid to work on electronics. In advance, I thank you for this great service you provide via the forum.
May 28, 2008 | Gateway LCD17TV 17 in. Television
My 8 yr old daughter thru the remote and broke the screen on my 32in LG lcd tv. All black now, looks like broken glass on left side. Can it be repaired for less than new?
your lcd panel is bad most of the time that is the most expensive part on the tv. cost on a 32inch lcd panel is 650.00 not including labor . this lg panel is not aviable now.sorry.
thanks doctor video leadng edge electronics since 1987
May 11, 2008 | Televison & Video
Samsung 20" LCD Syncmaster 2032MW
Thank you. I got my brain into gear at last and went onto the Samsung site, where I found the 67-page manual available for download. All I have to do now is try to understand the instructions - these do look quite clear, so, hopefully, problem solved soon.
Jill (Bessieboots)
Mar 24, 2008 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Gfm remote code
I have a 26" GFM DVD/TV combo (v7tvdvd26) and used the LG codes listed for my cable box remote. I went through about 3 LG codes until I found one that works.
I've also read that Goldstar and Funai codes might work with GFM.
Feb 03, 2008 | Televison & Video
Sharp Aquos 37 inch. Flat Panel cracked
try contacting these guys
the specialize in LCD parts
hope this helps
thanks for rating
Jan 09, 2008 | Philips 23PF5320 23 in. HD-Ready LCD...
Digital Tv is stuck on a channel
I have found the solution at last :)
Put the TV in standby and press these buttons in order
Info, Menu, Mute and Power on.
You will then see a hidden menu, on line 12 select reset
Bingo :)
Oct 23, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
159 people viewed this question
 Grubhead
Grubhead
