Question about Canon DR 2080C Path-Through Scanner
Missing the disc
I have a Canon DR-2080C scanner in my office. The disc has been lost in a move and my computer cannont install the scanner without the disk. Where can I pick up a new disc, or can I find the information on line?
    Sergeant:
  • 268 Answers
Well the good news is you don't have to pick up a disc :-) . You can actually download the driver for the scanner here (the driver is the software that allows the computer to see the scanner)
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=7181
On that page you want the second one down (2080INF.exe)
Here is what you are going to need to do:
  1. Download that file
  2. Double Click on the file and then hit "Run" followed by "Unzip"
  3. Click the "Start" button
  4. Click "Control Panel"
  5. Double Click "Scanners & Camera's"
  6. On the left menu (it is the blue menu on the left) select "Add Imaging Device"
  7. A wizard will now come up , click "next"
  8. It will now ask what kind of scanner/camera you want to install, on the bottom right is a button that reads "Have Disk" ; click that
  9. Hit "Browse"
  10. Navigate to the folder where you un-zipped the original download to. By default it went to "C:/DR208C/INF" - In that folder you will see a file named "CANODR2K" , double click it.
  11. Hit "Ok"
  12. Select how it is connected (USB or SCSI)
  13. Finish the wizard
And thats it! Now your scanner is installed on the computer and you can scan......
Also on the original CD is a software called "Capture Perfect" , which is the software that is used for actually scanning with your scanner , you can download that here: http://www.softpedia.com/get/Multimedia/Graphic/Graphic-Capture/Capture-Perfect.shtml
Posted on Oct 02, 2008
  • Canon Master
  • 19,396 Answers
Here you can download the drivers from Canon here Canon U.S.A: Support
Note, the scanner is not compatible with Vista, drivers for Vista are not available.
I have a Canon DR-2080C. Black line appears on the front page but when a scan as duplex it is not on the back page. How do I fix?
The top module has dirt stuck and bottom module is clean. Please clean the scan module with Isopropyl alcohol. For emergencies take a drop of cologne on a piece of cloth and wipe the area that is dirty.
S. Mohan
Mar 09, 2012 | Canon DR 2080C Path-Through Scanner
How can i get capture perfect software for my canon dr 2080c?
Go to their official webpage, and try to find software... or just download this Driver Update Software for XP Vista 7 8 and make the update. I hope I have helped. Have a nice day
Paul
Jan 18, 2011 | Canon DR 2080C Path-Through Scanner
Is there a canon dr 2080c driver for Windows 7?
look in optional updates in windows. thats the cool thing with 7
Dec 26, 2010 | Canon DR 2080C Path-Through Scanner
Line appearing on document
Clean the glass thoroughly with a damp cloth.
S. Mohan
Sep 30, 2009 | Canon DR 2080C Path-Through Scanner
Same problem Microsoft document scanner cannot see scanner
did you change o/s //some cases you need a different driver/check their home page(cannon)//oz
Aug 06, 2009 | Canon PIXMA MP530 All-In-One InkJet...
I recently set up a new DELL optilplex 760. When I go to install my Canon DR-2080c I get an error stating "Device Not Found". I've uninstalled and reinstalled many times but still no luck. Can anyone help...
Have you installed device driver? It is just not enough if you install scanning software. Also trya different USB port o a different USB cable.
S. Mohan, India
Jun 04, 2009 | Canon DR 2080C Path-Through Scanner
Canon DR-2080c - Replacing rollers
Check for a switch on the scanner that is made to feed single pages or multiple pages. If it is on single page it can multi jam all the time.
As far as the rollers go there is a pick up roller, separation roller, and a feed roller. You can clean them with rubbing alcohol to see if its indeed the tires that are bad. The exchange kit has all three tires in it that are user replaceable.
Jan 25, 2009 | Canon DR 2080C Path-Through Scanner
CANON 2080c scanner not scanning bottom quarter inch of page
Check your scan settings. If you have chosen A4 and the paper is slightly bigger, this can happen. It is also possible when the scanner does not pick up the paper in the first attempt because it is worn out. In such an event, you may find a blank on the top of the image. Clean the rollers with a damp cloth. Dont use solvents.
S. Mohan, Chennai, India
Jan 15, 2009 | Canon DR 2080C Path-Through Scanner
Canon 2080C scanner software causing monitor issues
Some sort of feedback through the scanner it seems Delete the scanner software and reinstall. Check Canon website for software updates Consult the Tech support team whilst you are there
May 31, 2007 | Canon DR 2080C Path-Through Scanner
Open Questions:
See all Canon DR 2080C Path-Through Scanner Questions
Canon DR 2080C Path-Through Scanner Logo
402 people viewed this question
old marine
old marine
