Question about GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 (JVM1851SH06) Smoke
Help...smoke just started pouring out of the inside right side exhaust/intake, inside the microwave. Should I just trash it and buy a new one....the warrenty just expired.
  • 706 Answers
It all depends on what is generating that smoke..Where there is smoke. there is cost associated with it.. By virtue of diagnostic time or component replacement or both..If your micro is a potential fire hazard then don't compromise your safety. If your warranty JUST expired, you might be able to convince the service people at the place you bought it that it is defective.. and they just MIGHT surprise you by replacing it free. Why not take a shot at it? In fact, if they try to adhere to the letter of the date. then get LOUDER and LOUDER in front oif as many customers that you can.. In some cases, you might be better off talking directly with the dept manager insead of the normal service reps.. Good Luck.. Be Safe...
Posted on Oct 03, 2008
Black smoke coming from exhaust of GE profile microwave
Possibly something cooked that shouldn't have been
Sep 13, 2017 | GE Microwave Ovens
I have a GE microwave model JVM1851SH06 that is completly dead. I replaced the Fuse and power came back, but 30 sec in it was dead again. What should do next.
You need to first verify that your outlet is correct at 105 to 125 volts AC.
If so, then you may have a failing high voltage transformer (rare) or possibly a failing magnetron, etc.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
May 26, 2010 | GE XL1800 1100 Watts Microwave Oven
Micro starts up but will not heat products.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dssd
Apr 04, 2010 | GE XL1800 1100 Watts Microwave Oven
Microwave shuts off after running for five minutes
I'd be careful because you do not know what caused it to spark. How old is the microwave? Do you need a new one?
Jun 14, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave xl1800 has stopped spinning
if the microwave still heats then the turn table motor will need to be replaced.. very easy repair
Jan 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How to replace a magnetron?
Sort of rare these go unless it started to arc and smoke!! Most probable failures are high voltage diodes, control electronics.
If you are sure that is your problem then
Remove outer panel and short high voltage capacitor with a jumper wire, then disconnect all wires to magnetron and unscrew the nuts from it and pull out. Check the condition of the rf seal at base of magnetron and inspect waveguide to verify no burn marks.
Also sometimes a mica diffuser will smoke and burn right at the waveguide entrance to the oven cavity. Make sure to note where wires go where. If you put the wires in the wrong places you will get a blown fuze or a nice light show
Oct 21, 2008 | GE XL1800 1100 Watts Microwave Oven
GE JVM1440 over the counter microwave
If the internal cooling fan is not working (I don't mean the hood / vent / exhaust fan) then you should not use the microwave until it is fixed.
The cooling fan is essential to prevent the magnetron from overheating and being damaged.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 01, 2008 | GE JVM1440 Microwave Oven
Microwave
check inside the microwave oven , at high voltage section wiring probem, change the wiring, and magnetron, other related spares.
Nov 03, 2007 | GE Advantium SCA2001BSS Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
286 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
