Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
D52W19 tuner replacement
What tools are required?
  • RCA Master
  • 8,617 Answers
Tuner is a very critical component to desolder without ruining the board. You can get a replacement signal board at the following site they have a promotion going on leave them a email and you can get a new replacement board for several hundred dollars cheaper than normal. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Oct 02, 2008
REEPLCE ANTENNA INPUT ON D52W19 RCA PROJECTION TV
Often they can be soldered back onto the tuner. But the tuner itself may need replacement which you can get tuners and the entire SSB which has the tuners already on them from www.tvrepairworld.com
Dec 18, 2011 | RCA D52W19 52" Rear Projection Television
The cable outlet on the back of the tv has broken off, how can I replace it and where can I get a replacement part?
This is commonly known as the rf connector. In the shop we can repair such a problem If the tuner is not damaged. Tricky soldering. Ideal you can also replace the tuner which is what the rf connector is attached too just depending on your skill. parts can be obtain a varous places my shop generally gets parts like this at vancebaldwin. There is a temp or another way just use a vcr then use another vidieo input. you will have to tune through your vcr but it will due to you can make the repair
Dec 22, 2009 | RCA D52W19 52" Rear Projection Television
How do I replace the cable connection?
You have two choices--either have the tuner removed and repaired--a new coax fitting installed OR:
If you have Cable, Direct TV, SAT, etc--you can route the signal into one of the audio and video inputs on the back of the set and bypass the tuner connection totally.
You can even use a old VCR---it does not have to be able to play tapes--just hook it to one of the Video and audio inputs and use it or a box to change channels
Repairing the tuner or replacing it may be very expensive--going into one of the inputs could only cost you the need to rent a box if you have cable etc.
If you have questions let me know--I am here to help people.
If this information helps you--rate this solution--I do this here for free.
SD TECH
Nov 02, 2009 | RCA D52W19 52" Rear Projection Television
Antennae & Tuners
most likley it took a fuse out on the board and the set will not run with the source voltage missing
as to the tuner some times they can be repaired or if to much damage has occoured you may have to buy a tuner for your set
Jan 21, 2009 | RCA D52W19 52" Rear Projection Television
Flyback
Yes it has to be resoldered you will need some special tools a good solder iron solder wick to remove solder a solder ****** and good solder without acid core you will need to remove the wires on the flyback be careful
Nov 14, 2008 | RCA D52W19 52" Rear Projection Television
Tuner replacement
You are going to replace the whole tuner module? requires a t20 torx driver.. to take back of. a small flathead screwdriver. solder iron with solder wick.
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Channels wont come in
sounds like the tuner is shot...mine is. easy cheap solution is to use either a cable box or a vcr as your tuner (hook it up to the a/v input if channels 3 and 4 are currently affected)
Jul 27, 2008 | RCA D52W19 52" Rear Projection Television
Not all channels available
Sounds like a bad tuner or more commonly the connector on the tuner is loose and or broken.
Jun 25, 2008 | RCA D52W19 52" Rear Projection Television
Adding HD
YES- and very few TV's have an on-board tuner, some MIts.
did and others,perhaps......................very expensive....T.
Oct 25, 2007 | RCA D52W19 52" Rear Projection Television
Tuner problems
it sound like the tuner to me here is rca part# for the tuner 264658 abour $70.00. good luck
Dec 26, 2006 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
46 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
