Question about Lexmark X6170 All-In-One InkJet Printer
My fax accepts faxes but I cannot fax out going
I faxed to my employer and they rec'd a blank page with a very bizarre phone number which wasn't mine. I've tried faxing several times since then but nothing will go through.
  • Lexmark Master
  • 4,338 Answers
Sounds like your lamp leds are out. These are what read the info and transfer it as data.
Please remember to rate all users who assist you for free :)
Posted on Oct 02, 2008
I Cannot Receive a Fax - the pages are blank
A second line isn't needed, this wouldn't cause blank pages to be printed. This could cause fax's not to be received if the line is in use. There could be 2 causes of blank fax's. Either the obvious which is the person sending the fax is faxing the document the wrong way up. Or the fax board on your copier has a malfunction. Because of the copier's age, this seems likely, although i hope not. hope this helps.
May 07, 2013 | Sharp AR-M355N Copier
Is there a Fax modem available to be connected with scanner, copier and printer (three in one already with us.)
your unit has a fax installed in the unit.
Look at page 29 in your manual it will show how to send and receive a fax.
send a fax page 29
receive a fax page 32
print reports page 33
feature purpose
1 Phone Hook: the green LED in the shape of a phone indicates that the fax
line is in use when lit.
2 One-Touch Speed-Dial Buttons: use to access the first 6 speed-dial entries.
3 Auto Answer: when the green light is on, fax transmissions will
automatically be accepted.
4 Speed Dial: use to access speed-dial numbers that have been set up from
the front panel or with the HP Director software.
5 Redial/Pause: redials the most recently dialed number when in the ready
state. Inserts a pause (hyphen) when in the dialing state.
6 Keypad: use to dial fax numbers, and enter numbers such as the quantity
of copies or percentages when reducing or enlarging. You can also enter
text using the keypad for fax header, use speed dial entries, and specify
menu items.
7 Fax Resolution: use to set the fax resolution to Fine, Standard, 300 dpi,
or Photo. It will remain at the most recent setting until changed.
8 Start Fax - Black: starts a black and white fax.
9 Start Fax - Color: starts a color fax
Apr 27, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I have a Brother IntelliFax-4100e fax that speed dial button 04 needed to be changed when we changed our phone system to include a 9 at the beginning of the number. Did that, it was 'accepted', but still...
go into menu, then to fax (hit set) then one touch speed dials (hit set) then hit the 04 one touch button and it should show you what is programmed. You can hit number 1 to change, type the number with a 9 in front of it(ie. 9+1+area code+7 digit number) then hit set and program a name for the number, hit set until the fax beeps to accept the change. You can test it with a blank cover sheet. That's how I have mine at work set up and it works fine. Hope this helps.
Jan 29, 2010 | Brother IntelliFax-4100e Fax
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
Receiving fax
Hook up a regular phone to the line and dial *69.
The number should also show up on the display if the other party has programmed it in the sending fax.
Feb 16, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Lemark 5400 can't faxor rec fax give phon lone error message
If u have DSL modem ..u need to have a splitter for the fone line.....and then....the connections need to be right...
Phone line to splitter -splitter to Fax mech(Line Jack)...
Problem Receiving--
Make sure ur answering Mech rings are set more than the fax mech...i.e (if ur answering mech is set to 3 then fax mech should be set to 4)....
If u r using DRPD(distingtive ring pattern i.e If u have one line and two numbers.....) then set double ring for fax and single for Phone or answering mech....or vice versa...
Jun 15, 2008 | Lexmark X5470 All-In-One InkJet Printer
Auto-answer issue: fax beeps on line when voicecall received
Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
Mar 27, 2008 | Office Equipment & Supplies
Fax Number Issue?
just put anything in or leave it blank, you wont be able to use the fax part of your mfc without a land line attached to it
Jan 19, 2008 | Office Equipment & Supplies
Lexmark X6170 All-In-One InkJet Printer Logo
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
