Question about Whirlpool RBD305PDS Electric Double Oven
How to remove the control panel on Whirlpool double oven Model RBD305PDS14
How do I remove the control panel on my Whirlpool electric double oven Model is RBD305PDS14?? THank you.
  • Anonymous Mar 13, 2014
    Think there is a dead mouse in the insulation
  • Anonymous Mar 30, 2014
    How do I remove the oven door on a whirlpool oven model #RF375PXYO0...and will the oven door from a Whirlpool model #RF114PXSQ3 in it's place?
  • 42 Answers
Remove the doors by turning toward you a little toggle apparatus located on each hinge. Locate a small screw on the lower inside edge of the left and right hand trim and then slide off the trim. Remove the lower trim then raise the upper trip and put the left end of the panel inside the top opening. This allows you access to the control panel. Test both the keypad part #8300440 and the control panel part #830219 to see which one needs to be replaced. Order the replacement part, plug it in, reverse the precess above and it should work like new..
Posted on Aug 11, 2009
  • BERNIE BYNOE
    BERNIE BYNOE Nov 09, 2013
    MY OVEN CONTROL PANEL WENT BAD AND IT IS COSTING ME A FORTUNE TO GET THE CONTROL PANEL REPALCED. IT IS FAIIRLY NEW.
Emge & Associates is investigating gas and electric ovens manufactured by Whirlpool, including such popular brands as Whirlpool, Jenn-Air, KitchenAid and Maytag.
The firm is investigating reports that the electronic control panel on certain models is subject to failure after a limited number of uses of the appliance’s “self-cleaning” setting. While most foods are cooked at temperatures reaching 375 degrees, the “self-cleaning” setting raises the interior oven temperature to 1,400 degrees. Due to defects in the design and or manufacturing, the electronics contained on many ranges are damaged by extremely high heat. Repairs to damaged control panels typically cost in excess of $300 per replacement.
If you have experienced failure of the control panel in your range after using the “self-cleaning” setting, you can join this investigation by contacting Emge & Associates at (800) 629-3409 or (619) 618-2974.
Posted on Dec 19, 2009
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
Tip
Related: F2 E6 on Whirlpool RBD305PDS14 double oven - blank display
Equipment is Whirlpool double oven RBD305PDS14 built-in.  After a very stormy summer 2007, I thought a power surge may have zapped the control board.  Problem initially presented on display as error & fault "E6 F2"; simply pressing "Timer Off" would usually clear this error & fault code.
However, some months later, the display would often go completely blank followed by the beep sequence "short-long-short-short-short" (Morse code: dit dah dit dit dit).  No error & fault code would appear.  Pressing any keypad oven control did not work at all in this condition.  When power was cycled at the breaker panel, the usual "PF" with clock display did not appear.
[TURN OVEN POWER OFF AT BREAKER!!!]
After following the excellent information on "how to remove the control panel" posted in this forum, I first tested the "control panel thermal fuse" (refer to the tech sheet that should be behind the control panel once it is removed).  It showed a closed circuit.
I turned my attention to the "flexible" keypad connector cable (error & fault code "E6 F2" is a keypad or keypad connector problem; again, refer to tech sheet).  The control panel has a board mounted female connector with two tabs that may be gently pulled upward to release the flexible cable.
I cleaned the flexible cable contact area (it seats into the board mounted female connector) carefully with a Q tip and some isopropyl alcohol.  I reinserted the flexible cable and gently pressed down on the two tabs (noted above) on the board mounted female connector.  VERY GENTLY tug on the flexible cable to insure it is gripped by the connector.
After all of this monkey business, I re-mounted the control panel display panel on the oven and restored power.  So far, so good.  After applying power, the "PF" with clock display always appears.  I am able to set the clock and press "Start".  Over functions normally.  The clock displays as normal and I no longer observe the problem I described above.
BTW, I noted the incoming 240V has transient suppression (no surge protection, however).
on Oct 21, 2007 | Whirlpool RBS245PDS Electric Single Oven
How do I remove the cirucit board on Whirlpool double oven Model RBD305PDS14?
Looks like you have the stainless steel model. It's not too difficult. Once you get behind the oven and can see the control board, it will be held to the back of the keypad with about 4 - 8 screws. Typically it is surrounded by a black plastic shroud. Make sure you take a picture of how everything is plugged in so that you can plug the repaired or replacement board back in. If you are sending your board to a company for repair we suggest you send the shroud with it, and even the keypad as well so they can test it.
Nov 21, 2015 | Whirlpool RBD305PD Electric Double Oven
How to clear F2 E1 error on a whirlpool double oven
E1 F2 is most often due to a failed keypad. Depending on your exact model the original part may be no-longer-available. However, there are replacement membrane switches available here:
Introducing the Ledgestone Technologies Touchpad
Models: RBD305PDB10 RBD305PDB11 RBD305PDB12 RBD305PDB13 RBD305PDB14 RBD305PDB15 RBD305PDB7 RBD305PDB8 RBD305PDB9 RBD305PDQ10 RBD305PDQ11 RBD305PDQ12 RBD305PDQ13 RBD305PDQ14 RBD305PDQ15 RBD305PDQ7 RBD305PDQ8 RBD305PDQ9 RBD305PDS12 RBD305PDS14 RBD305PDS15 RBD305PDT11 RBD305PDT12 RBD305PDT13 RBD305PDT14 RBD305PDT15 RBD305PDB1 RBD305PDB2 RBD305PDB3 RBD305PDB4 RBD305PDB6 RBD305PDQ1 RBD305PDQ2 RBD305PDQ3 RBD305PDQ4
Jan 08, 2014 | Whirlpool RBD305PD Electric Double Oven
RBD305PDS14 The top oven of this double oven is not baking or broiling. I replaced the baking element and still no go. Bottom oven is fine. Any suggestions?
Perhaps item number 37 has opened (died) killing the circuit to the elements from L-2. Looks like it $35 bucks.
Better verify it is bad before ordering. Now I know the following video ain't a bult in oven but I want you to see how important it is to turn off power to this oven before attempting repairs:
Sep 27, 2010 | Whirlpool RBD305PD Electric Double Oven
How do you remove the control panel from the RBD305PDS14 double oven?
Here is the service manual for this unit. The instructions for removing the control panel start on 4-2.
Service Manual
May 21, 2010 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool electric double oven #RBD305PDQ14 control panel blank
I suspect a poor connection at the wiring to the EOC is the cause of the failures.
Apr 21, 2017 | Whirlpool RBD305PD Electric Double Oven
Whirlpool RbD275pdq10 double oven E6 F2 error
I have a "double oven", Model # RBD275PDQ10 and it has Error Code E6 F2, What is the part that I need to fix it?
Dec 20, 2008 | Whirlpool RBS245PDS Electric Single Oven
Display is black
I had a very similar problem (I was observing the error & fault code "E6 F2", but not always.  I did always have the beeps.) on a Whirlpool RBD305PDS14 double oven built-in.  I spent time today (Oct. 21) and traced the problem down to the keypad flexible cable that connects the keypad to the oven control panel.
[ALWAYS WORK WITH POWER OFF!!!]
I cleaned the flexible cable contacts that seat into the board mounted female connector on the control panel board using a Q tip and isoproply alcohol.  This did the trick.
(Elsewhere in this forum, there is information on how to remove the oven control panel and gain access to the control assembly.  I posted this information - keywords in subject: Whirlpool RBD305PDS14.)
Sep 25, 2007 | Whirlpool RBD305PD Electric Double Oven
Whirlpool RBD305PDS Electric Double Oven Logo
6,067 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
