Question about Marantz SR-7200 Receiver
Marantz sr 500 going to "protect" mode when on.
How can I fix my marantz sr 500 of not going into protect mode when putting on?
  • Anonymous Mar 28, 2014
    would like ot connect my Apple Tv so I can use the audio through my marantz sr7000
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Marantz Master
  • 924 Answers
Your receiver has DC Offset, meaning a damaged amplifier. If you are interested in having it repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Posted on Jun 26, 2015
    Genius:
  • 1,550 Answers
Change the audio amplifiers IC´s because are on short circuit
Posted on Oct 02, 2008
Marantz SR-6300 receiver frozen in the CDR mode
It may be weird but it's a small suggestion formerly often occurred at Sony Trinitron TVs building years of 80/90 . maybe the same kind of problem.
A select button internally lingers on the selected matrix usually has priority
Nov 27, 2015 | Marantz SR-6300 Receiver
How to reset marantz sr4003
marantz SR 4003 how to reset (hard reset ) remove power plug from power .Take cover off locate ic 12 (24 c eeprom) short pin 5 to ground while plugging the power in .Unit will show clear on fl screen .if the unit trips again check channels.
Jan 04, 2012 | Marantz SR4003 Receiver
I have a marantz sr 7001 amp and am running canton 4ohm speakers to front and centre should my amp get really hot and go into protect mode when I am giving it some serious volume
it is not made to drive 4 ohm loads.also if you measure the impedance on the speaker,at some frequencies,it is closer to 3 ohms.This will cause the amplifier to shut down.Today's amplifiers are embellished specs.the old marantz 2325 was 125 watts a channel and weighed 80 pounds.It would eat alive some of the 1000 watt home theater amps of today.Marantz is very nice stuff.
Jan 03, 2011 | Marantz SR-6300 Receiver
When i pout on my marantz sr-4320 receiver it is going to potrction mode i want to know how to reset it?
The protection mode is engaged when there's a shor on one of the speakers outputs. This is a major malfunction and, to prevent the rest of the receiver to get fried, the entire system is put in an emergency shutdown mode - the Protection mode.
You must find out if the short is external - in one of the speakers - or internal - in one of the amplifying circuits. For that disconnect every single cable that plugs in the unit and start it .
If the protection mode is still activated then the problem is internal. The only way to identify the faulty circuit is to open the unit and test them all one at a time, starting with the 4 final transistors (2 per channel) - you need a good voltmeter and some basic electronics knowledge. In the worst case scenario the final transistors for both the channels have been shorted - it will cost you about $100 to replace them. Beware, soldering them in place is a delicate job, use grounding precautions and don't overheat them.
If the protection mode is gone then one of the speakers has failed. Either replace both of them or take them to a specialized repair shop, you can't fix speakers at home.
Nov 24, 2010 | Marantz SR-4320 Receiver
No surround modes produce any sound . only have sound on s direct mode. marantz sr 5200
Not having the ability to look at it on the bench, more than likely your DSP chip is bad. If you have a local repair house that is willing to confirm that is the problem without charging you an arm and a leg, that's your best bet. It is an expensive repair, anywhere between 300 to 500. At that point, I would say to replace the unit. Sorry for the bad news, but that's my "best guess" The only other thing to check would be your "Audio input Settings" Make sure it's either on "Auto" or whichever type you are using. "Digital Coaxial", "Optical", or "Analog" (RCA) hope this helps! If you have any further questions, just post a reply and I can help further. Best of luck!
Jun 03, 2010 | Marantz SR-5200 Receiver
Marantz sr4320 will not come out of standby
Sounds like it's in protection mode. Take it to a hifi shop, they should be able to reset it.
Jan 08, 2010 | Marantz SR-4320 Receiver
Hi Guys, Have marantz sr 7000 in for repai and
what is the location number of (c104) part.
Nov 22, 2009 | Marantz SR-7000 Receiver
What type of speaker wire terminals does the Marantz sr8001 allow?
Hello there.
These are blind posts (i.e the unscrew back) but will not allow you to unscrew them fully to use spades.
Only bananas (of any type) and bare wire (do not recommend it).
I own the same SR and faced many issues (even going into "protection mode") due to bad quality binding posts used on this machine.
For any clarifications (specific type of terminals) let me know.
Evangelos
Oct 07, 2009 | Marantz SR8001
What is the error POW 5 on a marantz sr 7500
I have a POW 5 failure on a marantz sr 7500. Anybody know how to fix?
Jun 02, 2009 | Marantz SR-7400 Receiver
Marantz SR5000 Protect mode
The Marantz SR5000 and others of it's make, design type, and year group are prone to this problem. Many such units can be reset by pressing a sequence of three buttons with sporadic results... the SR5000; however, does not provide any such option. If the "Auto protect" mode comes "on" then you know it's not a simple power supply "fuse" problem that can be fixed for a dollar by opening the case and replacing the glass fuse with one of the same rating value that is stenciled on to the power supply circuit board. (Easier than trying to read the old fuse.) If you can get the schematics and know a bit about replacing electronics parts using a low-power soldering iron, then you might want to take a shot at fixing it; otherwise, it's time for recycling. (Tip: Look for discolouration on a part on a circuit board first, this indicates overheating and a possible short. Then trace the schematic circuit for the "Auto Protect" circuit to diagnose which integrated circuits is at fault.) Typically, it costs more to fix it in a commercial shop than it's worth as someone has to pay the cost of benchtime diagnostics... the repair part is fast once the faulty parts are discovered. There are free sources on-line of the service guide for this receiver; however, downloading the plethora of rar files to assemble a complete manual is a challenge.
May 13, 2007 | Marantz SR-5000
Marantz SR-7200 Receiver Logo
1,607 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
