Question about Lexmark Office Equipment & Supplies
Replaced black ink cart & it say to remove the tape (which i already have)& realign ppr....
Lexmark replaced the black ink cart.
Posted on Oct 04, 2008
Black ink not printing
It could be out of black ink. If you just replaced the ink cart, did you peel the "remove this" tape off the contacts?
Jun 23, 2015 | HP Photosmart Premium C309g multifunction...
Have put new cartridges in and only prints yellow lines
Remove all cartridges, make sure any tape has been removed from over the nozzle. Ensure that everything has been installed properly, then use your printer (prompts on device, or in printer>control panel) to print some test pages, realign heads, etc.
May 05, 2011 | Canon Computers & Internet
Alignment problem. just refilled black ink cartridge..seeing message that printer is not aligned and remove tape from cartridge, but i see no tape
1) remove the cartridge and check it is not leaking. If it is, the printhead area on cart will be flooded with ink. Removing couple of ml from cart will stop it leaking.
2) If the cart looks clean (not leaking), stamp the printhead on some folded tissue paper or paper towell. It should leave a solid black stripe about 10mm long on the tissue. If it doesn't, your refill ink hasn't quite reached the printhead. You can blow little air into the breather hole (on top) to prime the printhead. Stop blowing when ink starts leaking at the printhead.
Clean the cartridge up before installing it.
3) If all above is ok and it still doesn't align properly, repeat above steps with the colour cartridge. The printer needs all colours working to perform the alignment process.
good luck with it
LC1000
www.inkbank.com.au
Dec 10, 2010 | Lexmark X7350 All-In-One Printer
I replaced black ink cartridge and am getting error that says remove tape i already did that it is a lexmark 5495
Is it a truly genuine Lexmark cartridge? Many printers are *very* finicky now on cart. type. If not, try a real one and see if you get that msg.
Good luck.
GuruTim
Jan 05, 2010 | Lexmark X5150 All-In-One InkJet Printer
After repalcing the black ink cartridge on the printer the printer doesn't recognize that it's been replaced and shows that it is still empty. It will print very light in black. What is the problem
make sure that the protective tape has been removed from the cart, and that the cart has no debris on it.Then, run your cart cleaning/testing program. If that still fails, return the cart as a defective item for an exchange.
Oct 26, 2009 | Epson Printer
Hi, please tell me how to install a new black ink cartridge into my epsonstylus D78 printer
Open the cover. Press the Ink/maint button (triangle shape on button) this moves the carriage to indicate empty cartridge. keep pressing until carriage moves to the ink replacement position. Open ink cartridge cover and remove the cart. Ensure you remove the yellow tape on new cart' before installing and be careful not to touch the chip on the cart'. Push new cart' in until it clicks. Close lid (ensure clicks down), close printer cover and press ink button again.
Please take a moment to rate this solution, thanks.
Mar 26, 2009 | Epson Stylus C86 InkJet Printer
Only black cartridge empty, but 3 full color crtrige say empty
Remove the color cartridges. On one end you can see the opaque
ink tank inside the main cart. housing. Cut a piece of black electrical
tape to fit around the three sides visible of the ink tank. Make sure the tape fits inside the housing and adheres to the tank itself. This makes the printer think your ink is always full but you can always tell when you need to refill/replace the ink(right?). Good Luck!
Dec 27, 2008 | Brother MFC-440CN InkJet Printer
900-4in1-align cart.message
probable, but remember, the things we love we also have to depart with.
try a service centre to see if it is worth the money.
Dec 06, 2007 | Office Equipment & Supplies
Printing Red not Black
remove the black cartrige, check if u removed the plastic protection tape then try to clean manually the print cart. with soft cloth when cleaning.. a black ink should apear on ur cloth if not change the black cartridge
Nov 16, 2007 | HP Officejet 7210 All-In-One InkJet...
Printer issue
I can only suggest that you should use genuine HP ink carts. Try all new carts and realign again. Hopefully it is under warranty. HP is good at exchanging.
Aug 02, 2007 | HP PSC 2175 All-In-One InkJet Printer
43 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
