Question about Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
How to oil a oster classic 76 - Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
SOURCE: I need help!!!
if you have a single speed (on off) clipper, it should only have 2 wires which go on either way. If you have a 2 speed (off low high) clipper there should be 3 wires, and they must go on exactly as they were. you won't blow anything up if you wire it wrong you just wont have 2 speeds . . just keep turning them around till you get it right.
Posted on Mar 11, 2008
SOURCE: oster 76
There can also be a problem with the switch, which can be gotten to by unscrewing the the 2 screws at the end of the clipper . . .you must then test (with the thing unplugged!!!!!!!!!) to see if the switch wires are good or if the switch is broken by flipping the switch and or the toggle and then checking the wires with an ohm meter (easily available from radio shack or ?? for under 10 bucks or any kid who's into electronics. If the switch is good, when its turned on resistance goes to 0, if bad th switch shoes infinite resistance on or off . . .
If it hums and the motor is turning, but the blades don't move you need to replace the gear and or lever . . see this diagram
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
  • 22 Answers
SOURCE: lubricating motor
Here is schematic for repair and service. This is the A5, it is the animal version of the Classic 76.
and if u need parts see the link below for schematic and parts list for the 76.
http://www.clipperrepair.com/parts.htm?mid=106
Posted on Feb 02, 2009
philschneide
  • 448 Answers
SOURCE: I don't know how or where to apply grease to my oster classic 76
The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). If you don’t have a tube of oster grease, a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear and teeth of bakelite gear). Also, the bakelite gear shaft has a hole down its middle and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The small pads on each side of the lever (in the case) are oiled, not greased.
Oster clippers, by the way, are known for getting pretty warm. Oster blade wash will help with that, as well as oiling the blades.
Hope this helps you.
Posted on Oct 11, 2009
askmannyssha
  • 76 Answers
SOURCE: How to connect one speed toggle switch on oster
e-mail askmannyssharpening@yahoo.com he will show you how with photo instruction. he ask for a donation for the cancer for women month
Posted on Apr 18, 2010
Want to use plastic attachment. What blade do I need to use with theses?
Oster 76 clippers can be used with a variety of blade sizes and combs. shaveroutlet.com has many in stock. When using comb attachments, you should use one of the following size blades; 000, 0000, 1, 10, 15, 30
ShaverOutlet com Search results for oster 76
Feb 25, 2016 | Oster Classic 76 Clipper w/ Detachable...
What blade do I use with attachments?
In general, Oster 76 clipper combs are compatible with blade sizes 10, 15, 30, 00000, 0000, 000, 1. Many are available at shaveroutlet.com
How do I take apart razor to lubricate the motor?
Oster Classic 76 hair clipper - take apart to clean or fix ...
? 9:53
https://www.youtube.com/watch?v=nu8UaoCxtxo
Feb 20, 2010 - Uploaded by darwincollins
It is an amateur video demonstrating how to take apart a Classic 76 clipper. ... your clipper with Oster Kool Lube 3 Clipper BladeCoolant Lubricant Cleaner. .... Motor did not slide out but all wires shredded and motor was in pieces ... What's that little button just below the '76' for and how do you know exactly ...
MOTOR TEST Checking the motor on broken Hair clippers ...
? 0:32
https://www.youtube.com/watch?v=TaWUxcdGBSg
Mar 29, 2015 - Uploaded by You can Fix It!!!!
Testing motor on shears clipper trimmer razor shaver. How doyou know if the blades or motor are brok... ... oils oiling oileddisassemble disassembling take apart taking apart .... 3:21. How To ' Change Cord ' Change Switch ' How To Repair Wahl Clippers ' - Duration: 2:24. by ronsclassickuts 13,453 views.
How to sharpen a Norelco electric shaver - Instructables
www.instructables.com/.../How-to-sharpen-a-Norelco-electri...
InstructablesYou will need a small brush to clean shaver and heads, also a flat piece of ... I then take a tool I made from a broken Norelco razor and a writing pen which ... Mix a 1;3solution of White toothpaste [1] and Mineral Oil [3] on the back of a ... Disassemble[keep the screens & blades mated] and spray with Bathroom Cleaner. 5.
Taking Care the Right Way to Keep Electric Razor Like New
Dec 06, 2015 | Health & Beauty
How to fix the switch on my oster 76 classic clippers
Check out My Video on how to replace Oster 76 Switch at Mannys-Sharpening.com Service You can Trust Since 1990
Jan 06, 2011 | Oster 76076-010 Hair Trimmer
Oster Blade 918-306 Size Texturing Fits Oster Classic 76 Clipper, Power Pro, Power-teq And Star-te: Oster class 76 clippers....had them for a week and...
70ca16d.jpg Hope this helps, this is a tongue guide, you hopefully recognise it on your blade. If they are not paralell, then adjust them with pliers, both need to be perfectly vertical. When you put it on the clippers push the latch in as you close the hinge.
If it still wobbles then the next fe wthings need checking
1. The hinge screws on the clipper are tight, located either side of the hinge on the clipper.
2. The drive lever may be worn, thats the maroon peice of plastic sticking up at the top of the clippers, it moves from side to side when clippers are running.
3. If all seems fine up to now, your clipper should be fixed under warranty as it will involve changing parts covered by the warranty.
www.sheareaseltd.com
May 17, 2010 | Sunbeam Oster Blade 918-306 Size Texturing...
How do you oil the heads?
Contact mannyssharpening@yahoo.com they have the tool to oil the Oster A5 or Oster 76 clipper
Mar 21, 2010 | Oster Golden A5 2-Speed Universal Motor...
The metal blade fell off my O classic 76 shaver, how can i put it back on? it is the metal changing part
The part that holds the blades on came loose on my Classic 76 clipper. It turns out that the two holes for the inserts are too big. I fixed the problem by removing the inserts from the clipper body (easy since that is the problem), cleaned the inserts and holes in the clipper body and super glued the inserts back into the holes. Be careful not to use too much glue! It only takes a little.
Oct 31, 2009 | Sunbeam Oster Blade 918-306 Size Texturing...
Lubricating motor
Feb 01, 2009 | Oster 76076-010 Hair Trimmer
Oster 76 clippers
Here is schematic and instructions for service and repair. The model in the picture is the A5 however it is the animal version of the classic 76.
Oct 10, 2008 | Oster 76076-010 Hair Trimmer
Oster Golden A5 2-Speed Universal Motor Clipper 78005-140 Logo
923 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
