Question about Belkin Computers & Internet
Belkin Router - not wireless
We're having a very frustrating problem lately with dropped internet connection. Can you help at all?
  • ajecm Oct 03, 2008
    Thanks. I think you are right, though haven't hooked up new router yet. Bypassed router to modem, and haven't been dropped since. Thanks for responding so quickly too.
    Novelist:
  • 169 Answers
As I've stated in many previous posts both Belkin and D-link routers (wired and wireless) are "famous" (for lack of a better word) for dropping connection with your internet carrier.
I *highly* recommend Linksys routers ...whether you get wired or not, they're just plain better ...and powered by Cisco technology. The best part - they're roughly the same price or cheaper than those "other" routers.
Go buy one at Walmart. Hook it up. See the difference. If it doesn't do everything like it should, take it back and you've lost nothing. If it does, take the Belkin and sell it on Craigslist or eBay.
Hope this helps - remember to rate
Posted on Oct 02, 2008
  • Scott Merrill
    Scott Merrill Oct 03, 2008
    My pleasure - good luck to you :)
How to connect Belkin N N 300 Router to Cox Cable Modem step by step instructions. Cox just installed a new modem since the old one "went bad" and was giving a wrong "number". Was working fine before and...
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
================================================WIRELESS SETTING UP A WIRELESS CONNECTION
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Aug 30, 2010 | Belkin Wireless Play Router (F7D4302)
Belkin Wireless N+ router won't connect to the internet anymore.
Please check the range of that wireless router and also connectivity of the router.
Jan 18, 2010 | Belkin F5D9630-4A Wireless Router
I have a Belkin router and i don't know hoe to cennect my laptop to my main broadband at home ,what do i do with the yelow cable do i connect the router to my laptop ? I have no clue and it;s really...
Here's how to connect the router.
From your broadban modem, connect the ethernet cable to the Internet/WAN port of the router. Then using another ethernet cable, connect your laptop to port 1 on the back of the router. Now run the setup CD that came with your router. After setting it up, it will tell you to disconnect the ethernet cable from your laptop to try the wireless function. Good Luck!
Oct 06, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Sep 29, 2009 | Belkin (F5D5231-4) Router
My router drops connection when I try to add security
did you try to upgrade teh firmware of the router ? that could be a probable solution . Also try to change the channels in the router. Make it to 6 or 11. Sometimes that could help
Thanks Ranjit
Sep 24, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
My Belkin n1 router disconnects from telstra every 2 hours - exac
This is a known problem with the Belkin N1 Vision Modem Router. The router keeps time by connecting to a Simple Network Time Protocol (SNTP) server every 2 hours. The solution is to go to www.belkin.com and download and install the pre-release firmware which is supposed to fix "A problem where the router could drop some connections on 2-hour intervals" among other things.
Sep 14, 2009 | Belkin N1 Vision Wireless Router
N1 Belkin to HP notebook - connection speed drops to 24mbps
It might be because of other electronic devices that works nearby in similar frequency...devices lik microwave oven, inverters, modems provided by the ISP which comes along with a battery backup, especially RCA modem which doesnt allows other wireless devices to work nearby it... try to relocate the router to a well ventilated area, and make sure you have kept the router atleast 5 feet away from other electronic devices...it could help....
Jun 16, 2009 | Belkin (F5D8231-4) Wireless Router...
Drops the internet connection and has to be rebooted at least once a day.
Try to reduce the MTU of the router. If you're on DSL, set the MTU size to 1492, for Cable connection size is 1400 or 1463. You can do it on the router's admin page http://192.168.1.1
May 11, 2009 | Belkin (F5D7230-4) Router (587009)
Cant connect from laptop yet can off the desktop???
umm i dont abought this scenario but i think you need a belkin 2 usb connectors one for yur desktop and one for your lab and then try to connect them if u have a wep key u have to put it in it is a password to get on the internet, another thing you can do is fill in the i.p adress specifically , and if all that doesnt work jus connect a 6 foot wire to the desktop or lab it will get you on the internet
Jul 01, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin N1 Router connection drops when phone rings
You may have a phone line connected from the modem to a wall outlet. Count the number of cables coming out of your modem - you should have only three: the power cable (connects to the wall), Cat 5 (also connects to the wall), and ethernet (running from the modem to the router).
Nov 09, 2007 | Belkin (F5D8231-4) Wireless Router...
Computers & Internet Logo
129 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
