Question about Sony Cyber-shot DSC-W55 Digital Camera
Battery compatibility battery is fully charged when it was replaced after charging the camera display says ' for use with compatible battery only' this is the original battery and has not been replaced with a sustitute.My husband has the same model camera and i have tried his battery but it still says the same thing, also i tried the battery from my camera and it works perfectly fine in his.
  • 69 Answers
There's not much you can do about the problem because the problem is inside the camera. A faulty component is probably the cause. (I think its receiving more or less that the needed amount of power so that's the error with compatibility)
If still within warranty, take it back to the reseller and ask them for a replacement or get it fixed. If they refuse, ring up SONY.
Posted on Oct 09, 2008
Lcd turns off
You probably have a malfunctioning charging unit, a bad battery, or a defective display,
  1. Borrow a compatible charger and fully charge the battery.
  2. Install a new battery and see if the problem persists,
  3. Replace the display though it's it's and expensive procedure for such an old camera. It will be much cheaper to go on eBay and upgrade your Kodak EasyShare CX7300 Digital Camera.
May 26, 2012 | Kodak EasyShare CX7300 Digital Camera
Even after putting a new fully charged battery camera shows battery empty
The reason you are still getting this error despite the fact that you've placed a new fully charged battery means that the battery is not compatible with the camera. The fact that it states this is because the battery isn't capable of handling the Olympus camera. I would suggest for you to buy a recommended battery pack by Olympus, or a rechargeable battery pack to avoid these errors.
Jun 30, 2011 | Olympus Cameras
The camera comes on when the powere button is
Usually this is a sign that the battery is weak or not charged enough.
Make sure you have either a new battery or the battery is fully charged, then test the camera again.
This camera takes a Sony NP-BK1 Li-ion rechargeable battery (or compatible).
If the battery is good and is fully charged, then there is a problem in the camera, and needs repair or sell it as parts or as is (if repair cost is too much) on a site such as Ebay.
Apr 15, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
My Sony VSC 1 camera is not turning on!!!! The charge went out and the camera turned off. After that it's not turning on. What do I do?
1. Please make sure that you're using the fully charged battery.
2. Try resetting the Camera. To reset the Camera, remove the battery from the Camera, press and hold the Power button for 30 seconds and then, reinsert the battery.
3. Please make sure that you're using the compatible battery with the Camera.
4. You may also try using a different battery to check whether the issue is with the battery.
Feb 17, 2010 | Kodak EasyShare V1003 Digital Camera
Compatible Battery problem
Try clean contacts of the battery. If problem persists, note what is on the LCD when it turns off. Only symbol of an empty battery, or is there any text? If there is written "For InfoLithium/compatible battery only", it does not mean that the camera thinks the battery is empty, but that the battery do not communicate with the camera. If other batteries are OK, you should replace the bad one.
Sep 03, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Card error with compatible memory card (Z30fd - Fujifilm)
Try doing a "format" of the card through the set-up menu.
Jun 07, 2009 | Fuji Finepix Z20fd Digital Camera
Charge batteries while camera is docked
what is the model of your camera and what specific battery are you using( what is on the label of the battery?)
when the camera is docked on the printer, you should get a little light indicating the charging status. Once it is fully charged, all 3 green lights would come on.
But, we need to know what is the model of your camera and what type of batteries are being used in order to determine if they are compatible or not.
Apr 10, 2009 | Kodak Easyshare G600 (1633379) Dock /...
Kodak Easyshare Z1285
Are you using the batteries listed as compatible according to the cameras battery door? Or are you using NON-compatible Alkaline or Ni-Cad batteries? Only Li-Ion and Ni-MH are compatible. Hope this helps...
Jun 29, 2008 | Kodak EASYSHARE Z1285 Digital Camera
Camera powers off
I think battery went on protection mode and if you give couple of hours rest to battery by take out from camera and place it on shelf. Hope this trick will work.
May 28, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
205 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
