Question about HP Officejet 5510 All-In-One Thermal Printer
No power- no anything
Everything is connected - get a musical rising notes signal. Worked fine yesterday.
  • janetcoye Oct 02, 2008
    Sounds like running up the scale - never heard that one before. Has worked fine for a couple of years.
  • 234 Answers
Try the steps mentioned bellow
Unplug the power cord from the All-In-One as well as the power outlet when there is still power in the All-In-One. and wait for atleast 1Min
Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Then check and see
Good Luck
Posted on Oct 02, 2008
My go go elite traveller plus worked fine yesterday took it apart then back together it was totally dead nothing at all
You did not forget to plug in all connection. Or should I say by setting it up again, you did not forget anything?
One cable not plugged in correct, or forgotten, can spoil the fun. Don't assume you did everything right, till you (or someone else) checked everything.
Nov 01, 2014 | Pride Go Go Elite Traveller Plus 4 Wheel...
Signal not connecting
https://contactus.netflix.com/contactus?locale=en-PS
Jan 16, 2014 | Netflix
Epic 450mx console lights up but nothing works not even the fan, worked fine yesterday
1) Adjust the REED switch,clean, and tigh the connector wires.see the diagram attached.
2) See inside for any fuse blown adn replace, or c.breaker reset
3) Reset the machine. Tight any connector, and wires looses, or breaker use the DVOM , see the diagram
God bless you
May 08, 2012 | Epic 450 Mx Treadmill
Yesterday had Cable Internet hooked up at new house--when done modem had all lights green, and wireless router connected and worked fine. Now router won't connect to Internet, and USB connection direct to...
Sounds like a problem with your cable connection. Check your coaxial cable, and the splitter from where the cable enters your home. The tech will use a signal meter to measure the quality of your cable, and then replace the wiring if necessary.
Jan 04, 2011 | Motorola Computers & Internet
Loss of Signal
Please make sure the antenna is tuned to proper SWR.
Also double check the power wire connections.
Let me know if you have no clue about tuning the SWR.
May 26, 2010 | Cobra 19 DX IV CB Radio
Everything is connected, i can hear it, but cant see it
The previous answer is partly right. Are you both using HDMI, or are you changing connection method. If you change method, you must reset the graphics settings, which can be a bit tricky without a screen. Turn off your PS3, then Press AND HOLD on the Power Symbol for some time, or until you hear the beeps, and the flight flashes green, then, it should work.
Sep 24, 2009 | Sony Playstation 3 (PS3) Console
Lost connection when trying to play online
hard wire the ps3 to the router first to see if connection is lost.............if not it's interference between ps3 and router
Aug 01, 2009 | Sony PlayStation 2 (PS2) Console
7 inch digital picture frame
Where do I go to have my picture fram serviced???? It has worked fine. Then it shut off and will not turn on again. I pulled the power cord and left it off for a couple of days and then plugged it back in. That had worked before and now does not.
Jul 15, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
No sound from anything but FM
Disconnect whatever's connected to the blue wire behind the unit, and re-connect it to the blue/white wire instead.
Aug 05, 2007 | Kenwood KVT-617DVD Car DVD Player
HP Officejet 5510 All-In-One Thermal Printer Logo
74 people viewed this question
Ben Johnson
