DeLonghi DH40P Dehumidifier
Problem for DeLonghi DH40P Dehumidifier
Works well but
By nursetom on Oct 02, 2008
...I have a damp basement and need to leave it on.Some people say it is as expensive to run as an air conditioner.Please give a factual answer as to its'energy efficiency. Thanks, Tom
Comments:
Oct 07, 2008
- Very informative and knowledgable.I love an answers that you can take to the bank.For bank credit ratings go to www.bankrate.com.Thanks ever so much for your time and effort.nursetom
Oct 07, 2008
Best Solution
posted on Oct 07, 2008
Very Helpful)
throrope
Rank: Master
Rating: 79%, 12 votes
Yup, they eat energy.
An electric dehumidifier includes a refrigeration cycle that is very similar to a window AC units and refrigerators. They cool the air in the basement to condense and collect water and remove humidity, heat the air as a required consequence of the refrigeration cycle and dump it back to your basement.
Two sources of humidity in basements include warm outside air that naturally cools due to below grade earth contact and water passing from the ground though the floors and walls and evaporating into the basement. Dehumidifiers do most of the work in the summer when higher temperatures outside enable air to hold more water content.
In the winter, cooler outside air contains less moisture by weight eventhough it may be raining and the relative humidity in basement will be less because the air is warmed relative to the outside. The lower moisture content in the winter also absorbs the water passing through the walls and floor.
From an energy perspective, you may want the humidity set NOT below 50%. This will keep humidity below the level mold desires, but prevents the dehumidifier from doing more work and eating more energy than needed. A cheap battery powered temp/humidy meter left in your basement will help. Sources that include the "mold triangle" (temperature, water & food) often separate fact from expensive hype.
If the dehumidifier doesn't keep up, consider adding a moisture barrier to the basement walls and floors such as Dry-lock and floor paints to ****** moisture entry. Moisture barriers act very similar with water as insulation does with heat. They don't eliminate the need for a dehumidifier, but they reduce the work they do and energy they eat.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for DeLonghi DH40P Dehumidifier
Questions and Unsolved Problems for DeLonghi DH40P Dehumidifier
Do you recommend DeLonghi DH40P Dehumidifier?
Answer
Answer
I have a Kenmore dehumidifier model #106.953501 that runs fine but will not shut off automatically... (More)
Answer
My DeLonghi DH40P used to work fine with the water going out the external tube....then that didn't... (More)
Answer
my delonghi DH400P drains through the hose not the tank. however, about 30 seconds after closing the... (More)
Answer
My DeLonghi Always Dry humidifier no longer collects moisture. Is it worth fixing or can it be... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dehumidifiers Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
