Question about HP Pavilion dv6000z Notebook
AUTO SHUT OFF HP DV6000
My HP DV6000 lap top get hot and it shut off! it keeps on doing that eventhough the battery is full!
This morning i turned on my laptop and worked perfectly... for a couple seconds. My HP pavilion Dv6000 froze and i decided to manually turn it on and back on. I pushed, and held the power button until it turned off. Once it turned off i decided to take the battery out (for no apparent reason). So i took it out and put it back it (i didn't really touch anything). Once i put it back in i tried turning it on by pressing the power button, but it wouldn't turn on. The screen is black, there are no blue lights that are on. (These lights are on when you turn the laptop on).
I tried the taking out the battery and hold power button for 30-60secs trick, but no luck. I also have taken out my laptop's ram and re-inserted it (same with my hard drive). Oh and my battery is fully charged. I tried searching the net for solutions but no one really has the same problem as me. Most of the other people with problems said they could hear the fan, but with mine there is noting. No sound. No lights. No working laptop just one really expensive door stop.
HELP!
Posted on May 17, 2010
    Problem Solver:
  • 15 Answers
Youre cpu heatsink is clogged with dust not breathing properly and causing it to over heat and shut down.Must remove keyboard heat sink should be on top right removed heat sink and clean dust .Use air can and spray whole laptop.
Posted on Oct 02, 2008
Partition of acer laptop is not balance, so i format it to make it equal. Unfortunately, along the way of formatting . . . it auto shut down by itself. til then the formatting was unsuccessful coz IT...
One of the bad things that happen with lap tops I have observed owning them is they do get hotter than usual, they make a lap USB fan for them which since I have recommended to all of my clients there seems to not be as many issues with heating anymore. Lap tops are designed with protective measures in the BIOS when built to shut down then they get to hot.
A good feature so the cooler your lap top runs the less it will shut down. Also go into the power options settings when you reload and set this to the factory settings and only change the power side that is when it is plugged in only leave the battery settings where they are. I hope this assisted you. Fix this before it becomes a serious issue. Thanks for using FixYa for all your questions. John
Feb 09, 2011 | Computers & Internet
Is it free: My monitor goes to sleep. How do I stop this?
Right click on power options and remove the sleep option.
Hope that helps.
Jan 22, 2011 | HP Computers & Internet
All my saved pictures have been deleted and the screen continually goes blank
Greetings and thanks for the question, there are various reasons why this happens. Without having your computer here to see what is going on is anybody s guess on how to repair it. If I may offer some suggestions. Since I also do not know what operating system you are using I will assume it is Win 7.
I would personally go to control panel and check my power options to make sure I do not have the settings set you close display or sleep mode or anything set to soon to close your machine down. Often times people have these set to go off there are defaulted usually to save battery usage and your lap top from getting to hot and shutting it down. The thermal switch may be activating sooner than normal. What some folks do is purchase one of those underneath fan coolers to keep their lap tops from getting to hot and constantly shutting down.
This can be the case have this checked out at least set the lap top for more time before closing down or turning the monitor off. Let us hope it is not more serious than appears. Like a lamp in the monitor going out. If it is new the lap top I would not worry about that issue because it is intermittent. Which leads me to believe it is a thermal or a shut down issue. Get the cooler fan for your lap top I recommend anyone that reads this post to also do this as well. Clean your lap top blow them out it is critical to do this to keep dust away and keep it clean.
Now there is recovery software which is free to download Click Here to check this out to retrieve lost files. Also important to get those precious memories separate off your computer and on to separate CD or DVD or storage USB stick so that when this type of thing happens you have not lost your precious memories. I hope this helps you. John
Jan 17, 2011 | Samsung NC10-14GW Notebook
Hp dv6000 lap top will not keep time and date..never has
all computers have an internal battery that runs even when the computer is off. The battery in your computer might be worn out and needs to be replaced by an expert.
Mar 20, 2010 | HP Pavilion dv6000z PC Notebook
I have a HP Pavilion Lap top dv6000 AMD
You PC has crashed, you need to run a recovery (which will lead to format the partition and reinstall the O/s, that means all your data will be lost).
Restart the notebook and start tapping F11 key,you will come to Recovery Manager, click on Advance Options, and select System Recovery and click on next, select No without backingup the files (as this option most of the times fails). Click on next and wait for 30-40 mins for the reinstallation to get completed.
Regards,
Shrey
Oct 11, 2009 | HP Computers & Internet
Computer keeps crashing. After I downloaded the skype for the built in web cam on my hp pavilion dv6000, the computer just shuts down, even when I am not logged in skype. Also, I have taken my lap top to...
turn on machine and hit F8 to into safe mode. If cannot load to safe mode i suspected your Operating system is corrupted. You might need to reformat your machine. Back up your files first before doing so because everything will be wiped out.
Jun 30, 2009 | HP Pavilion dv6000t Notebook
Fan will not shut off and notebook runs hot
Laptops run Hot If you can put a cooler underneath it... My Laptop was so hot I could have moved the stickers around on it.
This is what I got http://bit.ly/dv6000
^URL shortened for convince takes you to Amazon
May 21, 2009 | HP Computers & Internet
Battery not charging; what's the price for a new HP Pavillion dv6000 battery in new delhi?
hi there, if you need to replace the battery hun, the best places to check would be the internet on ebay possibly, or lookup laptop batteries with your model number, most places will not have a problem shipping to you, and usually have a single charge or a 1 time shipping charge no matter how much you buy, it is just a matter of comparing rates and if you want a warrenty, and try hp website, that will be good if your unsure about where to go, cuz if anything happens durring shipping the companay will replace it, another thing you can check is hp websites to find a legite representative for the company....thats about all i can help you with.....good luck hun and hope this helps you....shia
May 21, 2009 | HP Pavilion dv6000z Notebook
Lap top not turning on
Try removing the battery, waiting 30 seconds, then plugging it back in. Plug in power cord and try to turn it on.
Feb 02, 2008 | HP Compaq Evo n610c Notebook
HP Pavilion dv6000z Notebook Logo
591 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
