Question about NorStar Meridian M7310 Phone
No ring and appear on my Norstar M7310
I have had a problem before wrt the loss of the incoming ringing of my Meridian M7310 handset. I have lost incoming ringing and have appear only. I cat find the software code to correct this. Please help. How do I get the audible ringing back and not only the indication?
Thanks.
F
  • 6 more comments
  • Anonymous Oct 27, 2008
    I can't seem to get my M7310 phone to ring. It shows up as ringing on the line but there is no sound. I'm not familiar with the admin features on the main phone and would need a walk thru...
  • lorir321 Oct 27, 2008
    I can't get my M7310 phone to ring. I'm not familiar with the admin settings so I'm going to need to know how to do this...
  • Guesta Nov 05, 2008
    Same problem and I cant seem to find the system admin pages described byy another user
    Even dialling internally to this phone does not make it ring!
    I have looked at the system admin programming and cannot find anything in the menus to lead me to make changes onn the handset so that I can hear the phone ringing!
    I have tried everything here and nothing works! If anyone has any "worked" solution, I would appreciate it.
    Thanks in advance
  • Anonymous Feb 20, 2009
    how do you find out the line? I know the extension number but I dont know with line each extension is
  • Anonymous Apr 21, 2009
    Woo Hoo!!!...I have been trying to fix this exact problem for ages. Thank you thank you thank you.
  • kristenw Apr 23, 2009
    i have tried that but in the config menu I only have ring or no ring nothing about appear. i can only access this menu from the main phone, the other phones keep telling me that I am denied access.
  • lorir321 May 11, 2010
    Thanks Guest, but that doesn't work for me. I dial Feature 6 and nothing happens. If I then dial 1 after Feature 6 then I get something called Enter Zone: All. I dont know what that means. So my problem still isn't fixed.
    If I dial Feature *6 then yes I can change my ringtone and the phone rings for me so I know it works, but when a call comes into the office it still does not ring.
    All I want to do is have the phone ring at my desk. Its not on mute and/or on Do not Disturb.
This should work on M7310, M7324 & T7316
Feature ** 266344 - password 266344 - configuration - line data - line access - show ext (yours) - line assignment ( which lines you have, usually 1 & 2) - show line - appear only/ring/apprear and ring
Hope this helps
Posted on Mar 12, 2009
If you are familiar with system admin programming.
Access admin programming
terminals and sets
Line access
line assignment
Can set to ....appear&ring, appear only, or ring only
Posted on Oct 23, 2008
  • moemoe96961 May 23, 2011
    Can you please help me with the way to get to the appear and ring section? Thanks
    Can you please help me with the way to get to the appear and ring section? Thanks Moemoe96961@yahoo.com
I just found out how to do it - it is pretty simple
dial "Feature * 6" from your phone
you can choose the ring type you want by pressing next or 1, 2, 3, 4
then press OK
to adjust the volume
dial "Feature * 80"
then press the volume up or down to the desired volume
Posted on Nov 07, 2008
Remove the ringing from incoming calls on a norstar. I have multiple extensions in the building but want the incoming calls only to ring to a few extensions
You need administrative rights to get into the PBX. Once in there, you can assign which phones receive incoming calls. It has been years since I worked on the meridian system, so I can't tell you the way to do it, but it is in the manual. It's not complicated. You can also set it up for DAY/NIGHT mode so that in the evening, if required, all phones could ring on incoming calls so that anyone in the building can answer them.
Feb 04, 2015 | NorStar Meridian M7310 Phone
We have a meridian M7310 telephone system, and have just bought some headsets. Unfortunately we wish to use both headset, handset or speaker phone. Is this possible? Because at the moment we can only...
First of all, make sure you're plugged into the headset port of the telephone and not the handset port. Pressing the Handsfree button should change from handset to headset. You can't use the speaker phone with the headset plugged in.
May 13, 2011 | NorStar Meridian M7310 Phone
Incoming calls only ring on one phone!
that's a setting within the PBX system. See if you can find your user manual, or contact a business telecom company to see if they can provide you a copy.
Jun 11, 2010 | NorStar Meridian M7310 Phone
We have a Norstar - Meridian M7310 phone system. Today for some unknown reason when an incoming call comes in, the ring is two short rings rather that the "longer" ring that we normally have. I have...
The two short rings is telling you that the call is either a transfered call (answered by someone else and transfered) or answered by an auto attendant and transfered. Watch the ringing phone when the call comes in and see if the intercom LED blinks.
Bill C. www.dyna-tech.us
Mar 12, 2010 | NorStar M7310 Corded Phone
Norstar Meridian M7100 incoming calls - no ringing tone
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Jan 12, 2010 | NorStar M7100 Corded Phone
Turn ringer on T7316
T7316 Manual
The volume control adjusts the handset, hands free, headset, and ringer volume. Someone may have fiddled with the buttons and turned the ringer down enough that it doesn't sound when a call is incoming.
Feb 12, 2009 | NorStar Meridian M7310 Phone
Our office has 13 phones all the same. Some of the phones do not ring. I would like to get one of the phones to ring. It is a Norstar Meridian M7310
You will have to go into system programming, under sets, line appearances. You will need to set the lines on the phones to appear and ring, not just appear.
Dec 08, 2008 | NorStar Meridian M7310 Phone
M7310 phone not ringing audibally
If the internal calls dont ring, then there is something with the extension. When a call is ringing the phone, press the UP VOLUME. Chances are that someone accidentally turned the ringer all the way down.
Let me know if that doesnt work.
Nov 05, 2008 | NorStar Meridian M7310 Phone
Help Request
Do you have any programming experience on your system ? Is seems like the line has to be asigned to the phone it is ringing on but you will have to do that in system programming.
Jul 28, 2008 | Lands Phones
M7310
We wanted to find out if you still want our solution for the NorStar Meridian M7310 Phone (NT8B20AF03) Problem we posted on FixYa yesterday.
In case you do, we'd like to offer you our Premium Assistance Plan
By using this plan, our solution to our problem will be given to you.
Our Premium Assistance Plan gives you our solution from our Top Experts delivered to your Email - Money Back Guaranteed. Only $9.99. Great Value!!
Try it - you'll love it!!
Feb 06, 2008 | NorStar Meridian M7310 Phone
NorStar Meridian M7310 Phone Logo
7,963 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
