Question about Sharp AL-1655CS Laser Printer
AL- 1540 CS PAPER WILL NOT FEED CORRECTLY
WHEN USING THE FEEDING TRAY OR MANUAL FEED THE COPY GETS JAMMED AROUND THE DRUM AND I HAVE TO OPEN THE DOOR OF THE MACHINE AND PULL OUT.
THE PAPER COMES OUT LOOKING LIKE A FAN!
  • gregory_w_co Oct 02, 2008
    THE PROBLEM HAPPENS MOST OF THE TIME.
    WHERE IS THE BAD FUSER UNIT LOCATED ON THE COPIER OR DO I HAVE TO BRING IT IN FOR SERVICE?
  • Sharp Master
  • 4,338 Answers
This is usually caused by a bad Fuser unit.
Does it happen all the time?
Did you take the Toner/Cartridge out and check if there is some paper debris in side?
Posted on Oct 02, 2008
  • JDTec
    JDTec Oct 02, 2008
    It is best for a Tech to do it.
    The fuser is usually accessed through the rear panel.
    Please remember to rate all users who assist you for free :)
How to fix a paper Jam?
quality of paper and the paper thickness setting may have something to do with it.
Jun 28, 2015 | Brother MFC-7440n Laser Multifunction...
The printer is showing a "p" on the display. what does this mean?
The "P" means that you need to add paper into the paper tray or in the manual feed tray. Odds are that you are getting a paper jam from the paper tray? I would try to fill the paper tray with paper & make sure the copier is on a level surface. You may need the paper feed tire's or you may have a paper present sensor broken? I would just use the manual feed tray. Good Luck
Oct 17, 2010 | Sharp AL 1631 Copier
My Brother MFC-9840CDW keeps jamming every time I print mailing labels. I've had it four 1.5 years with no trouble. The label gets stuck and I have to pull out the toner tray to fetch it. I also...
hello, sounds like there are many possible solutions for you machine, first with paper jamming, are labels going thru manual feed tray, or paper tray, it might be possible that mp feed roller needs cleaning or replacing. if paper tray, simple would be feed roller, clean or replace, if jams continue with normal paper from paper tray, the problem will be front door, i have yet to be able to repair paper jams when front door assembly fails. as far as colors, both drum and toner can cause this problem, if using 3rd party toner, this will also cause some color problems. sorry no real quick fix for this machine, i've tried.
Sep 24, 2010 | Brother MFC-9840CDW Laser Printer
Hi my printer jammed at the beginning feed, and eventhough I cleared the paper, now each time I try to print the same jam happens. Anything I can try other than bringing it to a service center ?
Carefully inspect the paper path and find what stops the paper from moving. Sometimes there is a piece of paper, paperclip or staple stuck in the paper up turn. Usually the paper is wrinkled on that place after removal.
Try manual feed (yes, there is manual feed tray behind that narrow long door in front between the paper tray and the toner access door)
Clean the pickup roller. If it's worn out, try to remove it (there are plastic latches that hold it on place) and turn the rubber part in a way that non worn area covers the protruding part.
Aug 01, 2010 | HP LaserJet 1320n Printer
My Brother MFC8220 Keeps jamming the paper as it starts to enter the drum, is this a feed issue? or a Drum Issue? It appears to feed from the tray correctly, but then starts jamming as it enters the drum.
Using a cloth damp with water clean the feed roller. You will see it when you pull out the paper tray. If it starts feeding good it was a feeding prob.. If it keeps doing it look at the leading edge of the jammed paper for any signs of dings or bends. if you find any paper damage look in that area for what is causing the damage. Thank you, Steven 805-520-3003
Jul 26, 2010 | Brother MFC 8220 All-In-One Laser Printer
Sharp AL-1540CS Single By-Pass works, regular copying get flashin
Could be dirty feed rollers. I am assuming you are selecting the lower tray as your paper source when you get the "P"
OK, so take out the paper tray. Remove all the paper and look for 2 felt pads on the metal spring loaded plate where the paper sits. Spray these 2 pads with glass cleaner. Wipe of the excess spray from the metal plate. Install the tray, select that tray as your paper source and hit the print button. You will get the "P" of course so just hit C then print again. Do this several times. What you are doing is having the feed rollers rotate against the pads and thus cleaning them. After you do this 5 to 10 times then remove the tray. Dab a dry cloth on the pads to dry them somewhat, add paper and re-install the tray. If the problem was dirty feed rollers then this will fix it. The other cause of your feed trouble could be a paper feed clutch going bad. This was somewhat of a common problem on these machines. You would need a service tech to get to the clutch, remove, clean, lube and re-install it. But only if the above procedure does not work.
Jan 08, 2010 | Sharp AL-1540CS All-In-One Laser Printer
Sharp AL 1551 CS RSPF not feeding
This can be a fault of the controller of the direct current. Apply to service This fault can be not eliminated by you.
Mar 23, 2009 | Sharp AL-1551CS Copier
IN MX-M350N SHOWS "REMOVE PAPER FROM TOP TRAY" AND DOESN'T PRINT
You probably have a paper jam in the auto feed unit. Open the auto feed and check for bunched up paper and if you don't find any open the side doors and check for paper jams there. Let me know what you find.
Feb 13, 2009 | Sharp AL 1631 Copier
Mfc 8460n paper jam
Check to see if this happens when you use the drop down manual feed tray. If your printer works fine using the manual feed tray the problem is with your paper tray. Check to make sure it is set to letter size. I've found that sometimes the 'teeth' holding the paper stop on the paper tray wear out and when the printer goes to pick up paper, it pushes the paper stop out of position causing the printer to think it's using a different, much longer size paper thus preventing it from feeding all the way through. You'll probably need a new paper tray if this is the case.
Jan 06, 2009 | Brother MFC-8460N All-In-One Printer
Sharp AL-1655CS Laser Printer Logo
143 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
