Question about Symbol LS3578-ER Rugged Barcode Scanner
Symbol LS3578-ER Rugged Scanner Manual Needed
Can someone post the scanner manual
I need the "add CR Suffix" and "USB Keybaord (PC) to set up my scanner
How do i program the natural return or 'enter'
123Scan2 is an easy-to-use, PC-based software tool that enables the quick and easy set up of Motorola scanners.
Oct 31, 2013 | Zebra Symbol LS3578-FZ Barcode Scanner -...
After scanning a bar code I need it to enter and go to next row in excel
This can be possible, therefore it is not an Excel setting. You would need
to use the software that comes with your bar-code reader to configure this.
Try looking in your bar-code reader documentation for "Append Enter" or
"Append Carriage Return"
May 21, 2011 | Symbol LS 4000i Handheld
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit <Enter>? Thanks, -john
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
Apr 06, 2011 | Symbol Spark LS 1004
Hi, how do i downgrade the firmware for LS3578? Thanks
The Symbol LS3578-ER has a "single flow" frimware system. Meaning you can inly upgrade.
You may be able to contact symbol and they will create a special file for you.
Mar 14, 2011 | Symbol LS3578-ER Wireless Handheld Barcode...
My symbol barcode scanner beeps 4 time while I try to scan. The Manual states that the battery is bad. I replaced the battery & it does the same thing.
This 4 beeps also stays for communication error. Please check the connection to the cradle and also the connection between the cradle and PC.
You can start by pairing the scanner with cradle with the Pairing barcode, then defaulting the scanner to the standard settings - use the barcode "Set All Defaults" from the manual. Then select the right host type USB, RS232 or another.
After this procedure should the scanner work.
Sep 07, 2010 | Symbol LS3578-ER Rugged Barcode Scanner
I have Symbol scanner(1908T-I300) USB Type. It can read bar code but can't move next cell or line when testing Excell or Note Pad.
In the barcode is usually no order, which would say to the computer to change to new line or cell.
You would need to add an suffix to the barcode, check the manual for the procedure or use the following tutorial http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12295&sliceId=SAL_Public&dialogID=189588227&stateId=1%200%20189576907
Aug 16, 2010 | Symbol LS1908T Wired Handheld Barcode...
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Feb 26, 2010 | Symbol LS2208 Handheld
WILL NOT READ 2D BARCODES
That is correct this LASER scanner does not read 2D barcodes. It contains a long range 1D laser engine.
Light source: 650 nm visible laser diode
Datasheet can be found:-
http://www.motorola.com/staticfiles/Business/Products/Bar%20Code%20Scanning/Bar%20Code%20Scanners/Rugged%20Scanners/LS3578-ER/_Documents/Static%20Files/LS3578ER_SS_1208.pdf
If you want to read 2D barcodes you would require an imager. For long range try the Intermec SR61 it contains an EX25 imager.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Dec 01, 2009 | Symbol MOTOROLA LS3578-ER EXTENDED RANGE...
Does LS 3578 ER SCANNER HAVE A DRIVER ?
it can work with ether of them mainly then driver is needed. so i hope that is the answer you wanted and please rate the help i have been to you.
THANK YOU!
Apr 21, 2009 | Symbol LS 2208 Barcode Scanner
How to add CR to ls3578
To set the scanner to do a CR you will need to scan the following barcodes:
Scan Options.
<DATA><SUFFIX>
ENTER
You will be able to find them on the product reference guide.
Me aware that if this is a wireless scanner, you may need to scan the barcode that says Send Configuration to Cradle.
I hope this helps.
Get back to me it you still need more help.
Mar 27, 2009 | Symbol LS3578-ER Rugged Barcode Scanner
Symbol LS3578-ER Rugged Barcode Scanner Logo
750 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
