Question about Linksys Wireless-G WRT54G Router
I have router 54 been working but not now
I have 54 router it has been working fine but not now it want bring up screen to check network or add computers
  • 298 Answers
What is the model no. of your Linksys router?
Posted on Oct 02, 2008
How to hook up actiontec v1000h
This is a rather general question--I assume you are trying to add the router to your network.
Here is a link to the directions:
http://support.actiontec.com/doc_files/V1000H_Quick_Start_Guide.pdf
Apr 21, 2012 | Actiontec V1000 Wireless Router - 54 Mbps
I am trying to get my belkin 54 router to work but it doesnt show up on the wireless networks screen
make sure you SSID isn't hidden. Should be an option on the router on your wireless tab.
Mar 15, 2011 | Computers & Internet
My laptop won't connect via wireless, and can't even find the network. It used to work fine until a few days ago. I have a netgear DG834G router
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
May 08, 2010 | NetGear DG834G 54 Mbps 802.11g Wireless...
ADAPTER not working
Check the distance bet computer and the Router.
Donot keep your router near television, microwaveoven or any radio active devces, it may reduce the performance.
Check the Antena terminals for any loose connections.
If possible check your wireless signal strength with another Laptop, to diagnose the router is working fine.
If everything seems to be fine, it maybe the issue with the Adapter.
Goog Luck
Feb 12, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
WILL THE NetGear : WG111 54 Mbps WORK WITH ANY WIRELESS ROUTER IF SO WHAT DO I DO TO MAKE IT WORK thank you
Well this adapter works on 2.4 Ghz G standard network. You can use any router that operates at 2.4 Ghz.
To make it work, perform the steps below:
1. Double click on WG111 icon from the right hand extreme bottom corner of the screen, near the system clock, in the system tray.
2. Click on networks tab.
3. Click on the SCAN button - This will show a listing of all available networks.
4. Select the network you wish to connect to and click on the "CONNECT" button.
5. This will automatically take you back to the settings tab.
6. If you are using WEP security then Enter the WEP KEY under the option 'Enter Key manually' under the settings Tab.
7. Apply Settings .
8. This should get you connected to your selected network.
9. Click on the 'About' tab and check the IP address.
10. If you are getting an IP address in the format of 192.168.1.x, try to go online.
11. If you are not getting an IP or the IP is in the format of 169.254.x.x, restart the computer and then try to go online.
If issue persists, please contact the router manufacturer for the exact information on how to find the WEP KEY.
Also, disable any firewalls which you have installed on the computer.
Hope this helps.
Sep 28, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
TURN ON WIRELESS ON LAPTOP
check your wireless working fine
go to my network places.then view your wireless network if any network u see then connect.
also if your router is setup in security mode u have to add your wireless mac addresses in allow list in your router,
type in run "ipconfig /all" then u see mac adreses.
Nov 26, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Internet connection
First up, check that the router is broadcasting SSID and also disable any security so you can test the system and establish a link. Once you have done this you can add security in later
You may find THIS program useful in your testing to establish that the router is transmitting and there are no other routers in the area on the same channel.
Also check that the USB wifi is enabled and transmtting.
It may be suseful to post the exact model numbers of the USB wifi and the router along with your system OS.
Jul 20, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Connection problem
you need to type 192.168.0.1 into address bar on internet explorer if this does not bring up a password prompt then you need to set your ip addresses on both computers this is done by clicking start - my network places - on left view network connections - right click on wireless for wireless and on normal lan for lan - click properties scroll down to tcp ip sttings - right click - click properties - click use the following ip address - type 192.168.0.2  - click sub mask it will auto fill then default gateway needs to be 192.168.0.1  - then click use the following dns server and type 192.168.0.1 click ok and your done for every computer you add to the network you have to change the last digit of the ip address such as 2 then 3 then 4. go back to internet explorer type 192.168.0.1 you will get the password prompt the user-name is admin and password is password
once done you need to check it is connected to the net it should say on the first page. if you need anymore info msm me moc.liamtohat1202gniksirhc
Oct 27, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Router down when copy files
Check in your routers settings via your browser that the file transfer speed is no higher than 54 mbps, as it may be set at 108 mbps or 125 mbps as a 'g' type router should be, but your wireless network adapters can only work at 54 mbps and are crashing the transfers.
Feb 28, 2007 | Belkin (F5D5231-4) Router
Linksys Wireless-G WRT54G Router Logo
23 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
