Question about Brother Office Equipment & Supplies
I have just purchased a Brother QL 500 label printer and having inserted the disc and using standard installation as per the getting started guide, it will not allow the installation to procedd due to "error 1324 in My Pictures invalid character" Can you please advise what to do next? John Troughear
scrodamoon
  • 659 Answers
SOURCE: Installation
please click here to download the drivers for you printer please select your operating system and follow the screen setup.
im gonna guess off the top of my head that you have a antivirus/firewall on.
this ushally prevents software to be installed expessually when you get a error on the install.
please uninstall then software then reinstall the software without the firewall or antivirus activated. here is what you need to do.
Start--->Run--->type: msconfig---->in the general go to diagnostic startup---->accept, close and reboot
Install the software it should install now.
Then reboot
then goto
Start--->Run--->msconfig---->in the general options to to normal startup--->accept, close and reboot
Posted on Aug 11, 2008
siawolf
  • 749 Answers
SOURCE: Lost my installation disk for my Brother Label Printer
the drivers and manuals are available here (free) at brothers' website. http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=lpql500eus save them to a usb flashdrive or cd so you can put them on the next computer. make sure you choose the correct operating system so that you get the correct software.
Regards
Posted on Jun 30, 2010
Testimonial: "Thank you very much =)"
  • 1456 Answers
SOURCE: QL-500 keep flashing - P-Touch
Hello
Check if your battery needs replacement,The P-Touch 1280 uses six AAA-size alkaline or rechargeable batteries. An optional AC power supply can be purchased for the unit (model AD-30), to be used with the AAA batteries as backup.
make sure to use a functioning Brother TZ tape that can accommodate widths of 3.5 mm (9/64 inch), 6 mm (1/4 inch), 9 mm (3/8 inch) and 12 mm (1/2 inch).
Posted on Nov 22, 2010
SOURCE: I have a P-touch QL-500
This solution from loquiter worked for me on my Vista PC
noavatar_s.gif loquiter
I am assuming that your hard disk is not actually full. I am guessing that you are running Windows 7. Click through your start menu until you can see the entry to launch your P-touch Editor. Right click on the entry and click "Properties". Click the "Compatibility" tab. Under "Privilege Level" check the box labeled "Run this program as an administrator". (You can do the same for all users of this computer by clicking the button immediately below, labeled "Change settings for all users".) Click OK, and you're done. The next time you launch the editor, you will get a message asking: "Do you want to allow the following program from an unknown publisher to make changes to this computer?" Click yes, and you should be able to edit and print your labels. Of course, all this assumes that you have sufficient privileges to actually edit permissions and run something as an administrator. Hope this helps. .g_thread_answer { overflow:visible !important; } Was this solution helpful?
Posted on Jun 30, 2011
P touch QL 560 wont work with new paper
brother touch ql 560 Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on brother touch ql 560 related issues. ...i just set up a new computer with the vista windows and i have a brothers ql-500 p touch the install disk will not work with the vista what can i do go ... QL 550 won't print I have a Brother PTouch QL550 that won't print anything on the label.
[PDF]Creating Labels - Top Edge Engineering
www.topedge.ro/info/USER-GUIDE/.../OL-500-560-650-1050.pdf
pe nd ix. Software User's Guide. QL-500. QL-650TD. QL-560. QL-1050/1050N ..... This manual describes how to create labels using the P-touch Editor software .... want to create a new label layout or open an existing label. .... When this check box is not checked, labels won't automatically be cut ..... Used to select the paper.
Oh Brother! - Compatible Brother Labels saving you money
www.ohbrother.co.uk/
Compatible with Brother P-touch QL-500, QL-550, QL-560, QL-570, QL-580N, ... Thermal Quality Grade A Paper with Strong Adhesive and Sharp Print. ... Oh Brother! you won't find Brother replacement labels any cheaper on the internet.
brother QL-560 - Oh Brother! - Compatible Brother Labels ...
www.ohbrother.co.uk/index.asp?search=QL-550
Feb 03, 2016 | Office Equipment & Supplies
My Brother P-Touch QL 500 stopped printing and keeps blinking
Either the wrong printer is selected or the wrong size label inserted. Another possibility could be the incorrect size label in the format.
Sep 15, 2017 | Brother P-Touch QL-500 Label Printer, 300...
Regards
Jun 30, 2010 | Brother QL-500 (Bundle) Thermal Label...
Need to download 98SE driver/software for Brother QL-500. Brother no longer supports win98 and all driver download sites link back to brother site. Anyone able to help? Thanks...
Without an original CD I fear that this is not going to bode well for you. The system requirements on this printer state that it requires 2000 or XP. You may want to try using the windows 2000 driver. If that does not work you may need to contact Brother and see if they can send you an original CD.
Apr 20, 2009 | Brother QL-500 Thermal Label Printer
I just want to know how to install a Brother QL-500 Label Maker.
Download and install the driver, like any other printer. What seems to be the problem?
You can get the driver here:
http://welcome.solutions.brother.com/bsc/public/us/ca/en/dlf/download_top.html?reg=us&c=ca&lang=en&prod=lpql500eus
Mar 08, 2009 | Brother QL-500 Thermal Label Printer
41 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
