Question about Oreck XL21 Bagged Upright Vacuum
Please send Oreck schematic to: kevinrntz@aol.com
Thanks! Too bad pic is too small to make out wires. Tried to blow it up but it got very fuzzy.
Appreciate your quick response!
  • kevinrntz Oct 02, 2008
    email addy is in the title.
    Thanks
  • svehrhard Oct 06, 2008
    need wiring diagram for XL21
    President:
  • 1,673 Answers
Do you want me to email you the diagram, if so, I need your email addy.
Posted on Oct 02, 2008
  • Lauren Junge
    Lauren Junge Oct 02, 2008
    Ok it is on the way. Hope you can read it better.
  • Chrissey Terrill Jun 02, 2013
    Plz can u send the diagram to me too?
Wiring schematic oreck orbiter
Would you please email me the wire diagram for the Oreck Orbitor xl floor machine? I had to bring it on a plane, which meant that the handle had to be removed. We need to know where the blue wire goes. Thank you!
Apr 28, 2014 | Oreck Orbiter Floor Machines ORB-500,...
Hi, I appreciate your wiring diagram for the Oreck XL motor --but it is too small to read. Could you send me a readable copy. Thanks very much for your help! Nels Klyver
Print out the diagram u have, then scan it and blow it up to a larger size (all scanner allow u to enlarge the image), this is what I do with hard to read electrical diagrams.
Apr 28, 2009 | Vacuums
Model Oreck 2600HH- need schematic
white to motor terminal,black to other motor terminal,green is always ground to housing there is a small terminal tucked away its s small spot for the lights
Feb 01, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Wiring schematic oreck xl2600hh
I have a Oreck XL and the propeller that is in the housing will become hard for the moter to turn. I have took it apart and do not see a problem, but when I reinstall the parts it will run for about 15 sec. and the moter will stop turning. When the propeller housing is off the motor turns ok and doesn't stop. Do I need a new propeller/housing?
Nov 06, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL upright
I just sent you tge diagran to your email, hope this will help.
Oct 18, 2008 | Oreck UPR014T XL Pro 14 Upright Vaccum...
Clear oreck schematic
Here is Oreck's motor wiring diagram, if it isn't big enough to make out, give me your email addy and I will send it to you.
Oct 01, 2008 | Oreck XL21 Bagged Upright Vacuum
XL2525 changing motor
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=723450
Posted by geoffjackie on Jun 30, 2008
Please forward the wiring instructions for changing the motor in my Oreck XL 2525
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can contact the Oreck factory for the wiring instructions but you need to give them the model # and the serial # if needed and I will supply you with the Oreck website and the cust serv phone # listed below. Also, you can check the owner’s manual and sometimes there is a schematic that shows you if information you need for changing the motor. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 30, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Wiring Schematices
I had the same problem after not paying attention to the connections when replacing my motor. I spent days searching for information and only found several non-answers with small photos that no one can read.I contacted Oreck for wiring information. They explicitly stated that they can't provide any wiring information for safety and liability reasons.
I found the Ametek schematic which shows the LINE and TAP locations on the motor.
Note: I have a 2600HH XL with 2 headlights.
Connect as follows:
3A, LINE: White lead w/piggy back terminal from light harness #1 & white lead from the power harness to the piggy back terminal
2A, TAP: Black lead from light harness #1
3B, LINE: White lead w/piggy back terminal from light harness #2 & black lead from the power harness
2B, TAP: Black lead from light harness #2
Mar 31, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL
I would advise you to ALWAYS to FIRST UNPLUG THEIR VACUUM before beginning any service procedure. The motor has 5 wires to the motor as stated in the Oreck owners manual, tow are for the headlights, one is a ground wire, and the other two are for the motor. There are two screws that hold in the Oreck motor and a good suggestion is to use tape the wires leads and mark the wires so that you will not make a mistake as you take it apart and reassemble the motor. That way you will not make any mistakes, whether or not you have wires for a headlight or not, the rules are the same. Also refer to the owner’s manual schematic and the exploded view. Questions? 1-800-989-3535
www.Oreck.com
Oreck XL21 Bagged Upright Vacuum Logo
138 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
