Question about Uniden DECT 6.0 Cordless Phone
Phone says searching
I have had this phone for several months. The upstairs phone is searching, and the down stairs phone works fine.. This is the first time this has happened
  • Uniden Master
  • 5,870 Answers
Bring the handset that says searching into the same room as the base and see if the handset stops searching. Next unplug the handset batteries (yes from all handsets) and the base power cord (from both the base and the wall outlet). Wait a few minutes and then reconnect the batteries and base power cord. Next try to de-register and then re-register the handsets. (If you add a comment with the phone model, I'll help you with this step. Uniden has the manuals for their phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl .)
If this doesn't help, next try a new battery (and make sure that the battery is fully charged) for the phone. (If the phone is under warranty, contact Uniden. Note: batteries lose their ability to hold a charge over time. This includes the time on the shelf in the package.)
If a new battery doesn't help, then there is something wrong with the handset. Decide if it is worth having the unit fixed if the phone is out of warranty.
I hope this helps.
(I'm assuming that both handsets are cordless. If you have a corded/cordless model, then check that the base has power before you go farther with the above diagnostics. The power brick should be warm. We had a cordless phone on a power strip (UPS) that got turned off. The handset was searching for a signal that wasn't being sent. If you have power to the base, try sending the Find Handset message. The problem could be either the base or the handset not sending and receiving the signals between them.)
Posted on Dec 12, 2011
SOURCE:
2 level townhome- the upstairs is heating to 68 degree-thermostat is located but the downstairs is like 58 degrees.The vents are open in ceilings downstairs. How can we do to get more heat downstairs
close ceiling vents
the hot air down stairs rises through the vents and adds to the upstairs heating
same as hot air goes up the stairs to the upper rooms
Dec 27, 2017 | Heating & Cooling
Have a leak in my downstairs zone, can drain and fix problem while ye upstairs zone is functional
Depends whether the down stairs heaters are hooked to same lines as the upstairs. Some houses are and some are separate.
Nov 19, 2017 | Heating & Cooling
My upstairs temperature is 80 degrees and the downstairs is 69 Honeywell focus pro th6000 is set at 69. Why is the upstairs so drastically hot?unit is located upstairs& thermostat is downstairs
if there is no control of air movement between floors and you have it on cooling then any cold air will go down to the lower floor
or alternately if you have it set on heating all the hot air will rise to the upper floor
where is the system located (upstairs or down stairs ) and where is the thermostat located
to get control close any upstairs to down stairs doors or erect a heavy curtain across the stair well
Dec 17, 2016 | Honeywell Heating & Cooling
Hello there, I have a split entry home with a finished basement. I was wondering: on nice warm days, with a wind blowing through the upstairs, if I can leave my windows open upstairs while the...
Connie, it will only work if all of the interior doors to the basement are closed during this time. Even putting an old towel at the bottom of the door(s) leading to the basement will stop the air flow.
Hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | Dehumidifiers
Just moved in yesterday and the Honeywell thermostat is not working properly. the down stairs has diffent kinds but the up stairs rooms have the Honeywell thermostat. we set the temp. to 60 degrees but it...
Sounds like the programming on your thermostat needs to be reconfigured, but I need more information like the Honeywell Model number which can be found behind the front cove, but becareful to unsnap the t-stat properly not to damage the pins that connect t-stat to its base.
Jul 25, 2011 | Honeywell Programmable Thermostat Heater
We have 2 units (upstairs and downstairs) the upper unit no longer cools, we've had several calls done and a coil was replaced, issue persists and it will not cool below 85 degrees. The downstairs unit...
Check the supply air tempeture and the retun air temp.. to do this you put a termitor where the air come out and take the temp. then you check the air at the return where it goes back to the blower. you shoudl see a 15-20 degree diffrence. the oterh thing MIGHT be that cold air is heavier than warm air so it sinks down stairs. close off all the rooms upstairs might help .
Jul 18, 2011 | Heating & Cooling
We have a tv upstairs and one down stairs, they
Since the antenna is on the roof the signal has further to travel to get to the downstairs antenna and as a result the signal is weaker. Install a device on the antenna line before the first TV called a signal booster. This unit plugs into the wall and gets connected to the antenna wire too. It will improve the signal for both televisions.
Aug 14, 2009 | Televison & Video
Downstairs toilet won't stop filling, upstairs toilet won't fill
for the upstairs if the valve is fully on there is not much you can do other than replace water service to the house or heaven forbid repipe.Valves usually don't restrict fill volume.But you can take the supply loose from the tank and stick it in a bucket turn the valve on and check the flow.this should narrow it down.Down stairs repair or replace flush valve
Aug 04, 2009 | Home
I DO EVERY THING THE WAY I AM SUPOSE TO
took my time and had to move it to computer upstairs wont work down stairs o well Jim thank you any way
Aug 26, 2008 | Epson Stylus 1400 InkJet Photo Printer
Slow connection
Your slow connection could be affected by poor location wireless router (therefore poor signal strength), electrical interference, or even someone else with a wireless router transmitting on the same channel as your wireless router.
Try relocating your router away from solid walls, and/or move your computer or router to another location.
If your connection speed varies, could be electrical interference with appliance/s in your house, turn off all appliances, test your internet speed connecting then turn on one appliance at a time to determine which appliance is at fault (could have a faulty capacitor in the appliance)
Jul 24, 2008 | NetGear MR814 Wireless Router
Uniden DECT 6.0 Cordless Phone Logo
730 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
