Question about Sharp XR-10X Multimedia Projector
Fan making noise
Hi, my projector is working great, but the fan is making some noise and buzzing. Is this something that I could fix myself?
Thanks!
  • write_rp Nov 23, 2008
    I also have a weird buzzing noise, but I know it's not the fan. When changing image modes (ie, if the projector changes resolutions from 480i to 720p) or when only black is displayed (such as when movies fade to black for transition), the buzzing calms until the next scene appears.
    I may try a new bulb assembly because after the bulb turns off during the cooldown period, the buzz is gone while the fans are still pulling air out of the unit.
  • r_pyles Feb 13, 2009
    buzzing noise when it gets hotter. Doesn't take long for the buzzing sound to come. I have air to blow out. I going to take the bulb out first. Build up on a fan blade could be the noise, or a broken blade or worn out fan blade from getting to hot. Just a guess. I could not take the top off. White powder on the inside screen of the bulb unit.
  • 3 Answers
Hi, you probably have something rubbing against the fan or a faulty fan. To investigate, you'll have to open up your projector and look at the fan.
To start the process, you'll have to remove the cover of the unit. I just opened my Sharp xr-10x DLP projector today, which had no power, no lights, no functions. A previous post worked for me...Remove the 6 screws on the bottom of the unit (you'll need a longer phillips) and the two screws on the back, toward the top of the unit. Obviously, be sure to keep these handy for reassembly (I have two curious dogs and a 4 year old to contend with). Then, to remove the housing...use a std screwdriver and slightly pry the cover off from the rear of the unit. This should losen allowing you to pivot the cover forward and then off from the projector lens. Once removed, look toward to rear of the projector...the fan is located here...it's a small unit that vents out the rear. Before removing this, check to see if there is any debris in the vent area that will be need to be removed. If you need to remove the fan, you can do so with the screws attached to the fan unit. Once this is done, you'll be able to plug the unit in and see where the noise is coming from. If it is from the fan unit itself, you'll have to order a replacement from Sharp. Just contact their service/warranty dept and tell them the make/model and they can obtain the part for you. At this point, reassemble the unit by reversing the above instructions. At least your projector should work while you await a replacement part to arrive.
Good Luck...Hope this helps you out.
Posted on Sep 28, 2009
Laptop making noise
You need to get pressurized air and blow the vents to remove dust particles causing over heat. Or if possible remove keyboard to expose cooling fan and chip and use pressurized air to blow off dust
Aug 06, 2013 | Toshiba Computers & Internet
My compaq mini is making a buzzing noise
If it's under warranty it should be covered. It might be the fan, dvd drive or hard drive that is making the noise.
Jun 01, 2012 | HP Compaq Mini CQ10550CA Netbook
Optoma HD65 Fan Replacement?
im after a fan for the optoma hd65 projector its a sunon 12v 3.0w 20x60x60
Mar 14, 2012 | Optoma HD65 DLP Projector
GE bottom freezer has been making low noise as though condenser or fan? is trying too hard and not keeping up. And stuff in my freezer is melting even though it's set to the coldest temp. Can I fix...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 15, 2011 | Refrigerators
I replaced the lamp and the projector is make a very loud buzzing noise. How do i remedy this problem?
There may be a fan rubbing against a cable or something, but more than likely there is a vibration damper clip that has come loose off of the colorwheel and will have to be fixed by a technician.
Oct 02, 2010 | InFocus ScreenPlay 5700 Multimedia...
Dryer making a buzzing noise
It sounds like your motor has gone bad....it will buzz or hum when it is trying to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
Apr 13, 2010 | Frigidaire Electric Dryer
Color wheel sounds like a buzz saw. Fan is quiet because there is no noise in the cool-down mode. Can this be replaced by user?
Baily, I have had my HC1500U color wheel replaced two times due to the color wheel's unpleasant "buzz saw" effect showing up every few thousand hours of usage. It is happening again for the third time and I am still within Coscto's warranty so I am going to have it replaced again...will never buy a DLP projector again...too many moving parts that can break!
Would love to be able to replace it myself if you ever find a place that sells the color wheel.
Feb 09, 2010 | Mitsubishi HC1500 DLP Projector
My projector was working fine then a error message came up saying to check airflow. The temperature light and the lamp light are on as well. Is this something I can fix myself? If so, how? Thanks....
the projector is probably dusty. the dust keeps in the heat that the projector is trying to expell. use canned air to blow out the dust. also, check to see that all of the fans are working. if one of them is not, replace it.
Dec 22, 2009 | 3M X50 Multimedia Projector
EP719 Projector is "Buzzing"
Could be something touching the color wheel
Dec 19, 2007 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Horrible noise
it is the color wheel i have a similar problem and am looking for the part, the color wheel is a small electric motor that spins at a high speed and it can go bad. which will lead to the horrible squeel/hum/buzz.
Apr 24, 2007 | InFocus ScreenPlay 4805 Multimedia...
Sharp XR-10X Multimedia Projector Logo
255 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
