Question about Frigidaire ATF6000ES Front Load Washer
E20 error code
I have had my Frididaire front load washer less than a year and now it will not run more than 3 minutes and it starts beebing and comes up with E20
Can you help
    President:
  • 2,712 Answers
Check this answer:
http://www.fixya.com/support/t615626-error_code_e20
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 04, 2008
  • Swilin Sampson
    Swilin Sampson Oct 06, 2008
    E20 is not an exact error code. It's indicating a possible pump out
    problem. Here is a few possible causes of an E20 error code:
    1. Restriction in the drain pump
    2. Failed pump
    3. Water not pumping out fast enough (crimped drain hose)
    4. Too many suds ( too much detergent or wrong kind)
    5. Pressure switch (not communicating with control board)
    6. Loose wire at pressure switch
    7. Loose wire at pump or control board
    8. Failed control board
    Most likely there is something blocking the motor spinning. This is from the afore-mentioned article:
    "Thanks to the different postings on the net about a E20 error code I
    took apart my washer’s drain system ATF7000 to find. A pare of little
    girls underpants, one hair band, one plastic green gem, a golf ball
    sized wad of wrappers/stickers/???, and almost two dollars in coins.
    All caught up in the plastic strainer located inside the black rubber
    boot found on the bottom of the tub leading into the drain pump.
    Here is how I did it: After emptying the washer of sloppy contents, I
    sucked as much of the water out with a shop-vac. I then turned the
    washer onto it’s left side gently using a couple of towels as a cushion
    (unplugging the washer and hoses first). From the bottom and back panel
    you can access the drain hose/pump/coin catch. With a pair of pliers
    you can remove the clamp holding smaller end of the rubber coin catch
    to the tub, with a Phillips screw driver you can remove the larger
    clamp of the rubber coin catch to the tub. From the back panel you
    again use your pliers to remove the clamp to the drain line, and
    finally with a Philips screw driver remove the two screws holding the
    pump to the bottom of the washer. Oh yah, do not forget to unplug the
    wire from the pump. Now pull the pump out with the black rubber boot
    still attached. Mark the orientation of the pump to the boot with a
    sharpie pen, and remove the last clamp. Now look inside the black
    rubber boot and gently remove the plastic basket inside, there you will
    find the treasures that just wasted the last hour of your time. Now
    reveres those steps, reinsert the half washed clothes, and enjoy your
    new machine.
    Thanks again to everyone that has posted before me, otherwise I
    wouldn’t have known were to even start looking. I hope this helps
    someone."
    Another possible cause of that is the detergent dispenser door is not
    closed properly. Just need to make sure it's closed all the way. If
    these do not solve the problem, then I recommend calling in the repairman.
    Hope that helps!
  • wrfish
    wrfish Sep 28, 2012
    Frigidaire and their servicing dealers claim there is no such error code, (E20)
Frigidaire front load washer (ATF6000SF1) error E20
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
2. Failed pump
Nov 29, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer (LTF600ES1) Error E20
this is an error that indicates the tub is clogged or draining slowly
to fix this you have to go under the washer and pull the tub hose off and clean all obstructing stuff in the hose and thru the hole on the tub
Oct 18, 2008 | Frigidaire ATF6000ES Front Load Washer
What is error 20 on frididaire gallery washer? Clothes just sitting not moving at all?
2. Failed pump
Apr 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
I have a front load frididaire washer purchased new in May that has stopped working for the second time- mid cycle- the last time it took three weeks to repair- is there a lemon law on washers
often times thear is but hard to get,,3 times same issue within a year,,,in the meantime buy a american car..all this importing of stuff is why we have junk appliances
Dec 23, 2009 | Frigidaire ATF6000ES Front Load Washer
E20 code. Not draining
E20 is a general error code to get to the real problem try this..
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Jun 06, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Your washer is not draining properly. You need to check if the drain hose is kinked and also whether the household drain is running smoothly.
Aug 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
Leaks water
Okay, to check for your source of a leak, start by removing the 2 screws on the lower front panel of the machine. This will let you see inside. As you are running the washer, watch where the water is coming from. If from the front, you may have a hole in your boot (the black rubber up front) If so, you may need to replace the boot (the part comes with step by step instructions). If coming from the middle, your tub seal may be going bad. A quick fix is tighten the 12 or 14 bolts that go all of the way around your tub. This will only be a temporary measure. The tub will have to be taken apart and the seal replaced. (this is a 1 1/2 hour - 2 hour procedure for 2 technicians) If it leaking from the rear, you may have a bad tub bearing. You can remove the back panel to be certain, but usually a bad bearing will be accompanied by a roaring noise durring the spin cycle. As for the dryer leaving brown marks? Usually the front seal has been dammaged. Run your finger around the front of the drum (where it meets the front panel) the gap should be about the same all of the way around. If it is not, you may need a new front seal. (this is much cheaper and less time consuming on the dryer compared to a seal on the washer)
Jun 18, 2008 | Frigidaire GLTF1670A Front Load Washer
FRont loader washer
try this,on next load use NO deteregent/soap.Please leave a rating.
Jun 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
