Question about Sharp EL-1801P Calculator
Changing the printing ribbon on Sharp EL-1801
Please tell me how to change the printing ribbon.
  • neener86 Oct 02, 2008
    Anyone ever figure out how to change the ink roller? I am not even sure I have the right one but this is what Staples suggested. If anyone knows the trick for putting the new roller in, or a item # for the roller, please let us know! Thanks...
  • neener86 May 11, 2010
    Still can't get this darn thing to print. The roller fits but appears to not be touching the print wheel. I am gonna jam this thing in the river! Anyone have any success with this problem?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sharp Master
  • 102,366 Answers
Follow the illustrated instructions on the first page of the manual at http://files.sharpusa.com/Downloads/ForHome/HomeOffice/Calculators/Manuals/cal_man_EL1801P.pdf
Posted on Jun 10, 2013
SOURCE: ribbon installation
I searched this online, and have found the following instructions:
1) Set the power switch to OFF
2) Remove the printer cover
3) Remove the ink roller by turning it counterclockwise and pulling it upward.
4) Install the correct color new ink roller and press it in the correct position. Make sure that the ink roller is securely in place.
5) Put back the printer cover.
Posted on Dec 29, 2008
SOURCE: Need to change tax function on Sharp EL-334A
I had the same problem and finally figured it out. Here's what you do:
Press C-CE twice
Press +TAX (Rate set)
Key in your new tax rate as an integer (e.g. 5)
Press +Tax (Rate set) again
Press C-CE
Then you're ready to calculate with the new rate!
Now what's the GT button for?
Posted on Nov 27, 2007
  • 207 Answers
SOURCE: I need to change the time on my Sharp EL-1750PIII calculator
You can access the .pdf manual for your particular calculator here:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Page 1 for how to set date/time:
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Posted on Apr 27, 2009
  • 566 Answers
SOURCE: WHAT KIND OF RIBBON DOES THE SHARP EL-1801V USE
Ink roller type EA-772R
You can find it in any good (refer your machine make and model). There are compatible roller with different references. Also check online (do a gGoogle search or check Amazon.com and you will find several links fopr different seller.
Note that the same type of ribbon is use by diffrent calculators, evem from different brands, so lok for the image of the print roller to see if it looks like t he roller of your machine)
Posted on Jul 25, 2009
SOURCE: hi! I am using the Sharp EL-735 and I don't
Setup DSP TAB
then you can choose between 0-9 decimal places
Posted on Jun 17, 2010
Sharp EL-1197PIII Calculator won't print using the blank ink. Ribbon is correctly installed.
I still have to believe that your ribbon is not quite seated properly on this. I would check that again. If this is not a "cartridge" then Check to see if it is upside down.
Jan 15, 2015 | Sharp EL-1197PIII Calculator 12-Digit...
I have replaced the ribbon twice now but the print still comes out very light
I'm having the same problem. This is my second Sharp EL-2630PIII calculator and the first one did not have this problem (prior job). I can change the ribbon and the print is still so light I cannot scan it as part of my work papers... which is a huge problem as an accountant.
May 21, 2014 | Sharp EL-2630PII Calculator
Ribbon Smudge
The only thing I can think of is the ribbon is not threaded properly. (ex. in front of carrier instead of behind or vice versa)
Jan 29, 2014 | Sharp EL-1801P Calculator
HOW TO CHANGE RIBBON
how do I change the ribbon on my sharp EL-1197P calculator?
Aug 20, 2010 | Sharp EL-1197P Calculator
Sharp EL-1801V 12 Digit 2 Color Printer
if your trouble is repeated after you switch the calculator off and on again your printer needs service in workshop.
Nov 01, 2007 | Sharp EL-2630P Calculator
Sharp EL-1801P Calculator Logo
582 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
