Question about Singer 5160 Mechanical Sewing Machine
Singer 5160 - stitching mechanism not working correctly
I was in the middle of doing some intricate applique, using the hand wheel instead of the foot pedal, and I started noticing it getting really hard to turn all of a sudden, after an hour of working. So, I cleaned out the dust and fuzz around the bobbin area and the front of the machine and oiled it up and it seemed to do the trick, because it moved smoothly after that. However, when I started back on my project, the zig zag pattern no longer worked correctly. Instead of making a straight back and forth zig zag, it now comes down straight and then curves over to the left and right at the end of the stitch. I was wondering if you could give me advice, maybe I need to take the top off somehow? Thankyou!
  • 980 Answers
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
Posted on May 14, 2009
SOURCE: Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
Posted on May 24, 2009
  • 3 Answers
SOURCE: need to know how to the zig zag stitch on the 132
By turning the bottom dial on the righthand side of the machine, you can change type of stitch. For zig zag, you need to set it to B (seen on the front of the machine). You can adjust the width of the zig zag using the same dial.
Posted on Jun 21, 2009
  • 8 Answers
SOURCE: Singer Athena 2000 won't zig zag
Try pushing the reset button underneath the machine. Mine does that too. I had it repaired a few months ago...apparently it needs a circuit board that is no longer available.
Posted on Aug 01, 2009
  • 2976 Answers
SOURCE: ZIG-ZAG NOT WORKING
Make sure your presser foot is tight down. If the needle is going from side to side, it's doing it's job. If the stitches are coming out straight, the material is probably slipping back and forth to center area. The presser will eliminate this.
Posted on Aug 28, 2009
Can this to freehand machine embroidery?
If you can drop the feed dogs (or have a plate to cover the feed dogs), the machine has a zig-zag stitch, and you have a darning foot or free motion foot, you can do free motion quilting, hand manipulated embroidery (monograms), and applique on a basic sewing machine. It will take some testing and quite a bit of practice. You can also use an embroidery foot to monogram and applique. You will want to sink the needle into the fabric at every corner and frequently when creating curves so you can move the fabric.
Search the internet for instructions & tutorials on how to set up your machine and the best way to accomplish what you want.
How to Monogram with Basic Sewing Machine
How to Use Monogramming Foot
Machine Applique Tutorial
Machine Applique Sewing
Jan 12, 2016 | Sewing Machines
When sewing, mechanism sometimes binds. Bigger problem is when finished stitching, the hand wheel binds completely. Is there a mechanical problem or someplace to insert oil?
Hello Griff
Very likely the thread is kind of bound up in the bobbin area. Just turn the hand wheel a bit forward and backward several times -after you lift the foot. Apply a gentle pull on the fabric and it should "break" loose. Often teh thread is still stretched around teh bobbin and this releases it.
Feel free to reply to this post if this does not do it.
Moses
Dec 07, 2014 | Singer 7436 - INGENUITY
Needle position
Please correct down position and remove the foot and switch off machine. Then set of the up position applique the needle. After machine On.
Nov 21, 2013 | Singer 8763 Curvy
The needle does not move when the foot pedal is used.
Make sure that you pushed the bobbin winder all the way to the left.
Jimmy
Apr 01, 2012 | Singer 7444 Mechanical Sewing Machine
I am trying to applique using a narrow zigzag. I have put on the satin foot and moved thread width lever all the way to the left, but cannot get a narrow stitch. My new machine also seems very noisey. Is...
Look on page 46 of your manual and you will see the correct way to satin stitch. Also, you should use a stabilizer, like interfacing or good old fashioned gift tissue paper. If, you don't have your manual handy, download one for free at www.singerco.com and it will tell you how to clean and oil your machine, change your needle. Your machine should not be noisy, try placing it on a towel if you are on a hard surface. Good luck, it is not hard, you just need a little practice on some scrap material.
Oct 27, 2010 | Singer 7444 Mechanical Sewing Machine
What settings for doing zig zag for satin stitch around applique. I have used 3.5 width and 0.2 length but the fabric has a tendancy to pucker and the stitches sometimes bunch
It depends on a couple of things. Depending on the fabric you're using you might want to use a stabilizer like an iron on tear away. If the stitches are bunching the stitch length might be to tight. Try going to 0.3. if the stabilizer doesn't work. With the stabilizer on, it will keep the fabric firmer so it won't pucker. Make sure you have the decorative stitching foot on the machine with the little indentation for the satin stitch to ride in. If you have the wrong foot on, this will cause bunching too. Let me know if this helps.
Aug 22, 2010 | Janome Memory Craft 4900QC Mechanical...
Sewing machine
Simple solution..
take the thread off your machine, set your tension to the middle setting. rethread your machine up to the needle. before threading the needle, put your presser foot down. If your thread pulls hard, then the machine is threaded right. If it pulls easily, you need to chead the thread thru the tension wheel.
Kelley
Rule of thumb.
Loops on the bottom, problem on the top.
Loops on the top, problem is on the bottom.
May 02, 2009 | Singer 8280 Mechanical Sewing Machine
New singer 8280 needle hits overcasting foot and breaks
so, it sews for a while?  It sounds to me like the screw that holds the needle in place is loose.  As the needle moves up and down the screw loosens until that one fateful stitch, it comes out completely.  Try to tighten with a screw driver.
the other possibility is that it breaks if you are sewing over a bulky seam, like a flat fell.  as the presser foot "toes up" to go over the lump, the needle hits and there you are.
holler if that doesn't help.
Jan 18, 2009 | Singer 8280 Mechanical Sewing Machine
Singer 5160 Mechanical Sewing Machine Logo
75 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
